Old 12-10-07, 06:22 AM   #1
_Mitcho_'s Avatar
What are these for??
hey guys,
im putting my bj40 back together and i forgot to label a few plugs so if anyone has any idea of what they are for post up.
This one is with the plug that goes to the dash cluster:
This one is just coming out of the main loom about half way across the dash:
This is coming out of the main loom again and is around the center of the dash:
This is a positive wire coming from the battery and is with the main power supply to the car and is only a one prong plug?? i have no idea, after the plug the wire has been broken off
any help at all would be appriciated.
thanks mitch
_Mitcho_ is offline   Reply With Quote
Old 12-10-07, 09:27 AM   #2
marting's Avatar
Location: I live in Oslo.. the biggest village in Norway
On my HJ60 there are a number of unused plugs... so they might be redundant.... i guess extras for equipment my car never had...(same wire-loom regardless of equippment) The last picture looks like some hobby-wiring for extra lights or something..
HJ60..OSLO
marting is offline   Reply With Quote
Old 12-10-07, 04:18 PM   #3
Diesel for blood
roscoFJ73's Avatar
x2 Maybe you didnt label them because there was nothing attached.
The one with the 2 pin plug is the same as my cig lighter plug.
The yellow one off the battery looks like its part of a fusible link.
Got a manual? You should be able to check the wire colours from the schematic.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 12-10-07, 05:35 PM   #4
Mitcho, 1_ For the dash, typically the plugs are specific. i.e. They would not fit if not the corresponding plug. On the other hand, you can check each ones function with a test light; without key, accessory, ignition, etc ...
I used my extra plugs for added options.
As to the battery, I agree it does not seem like a "Toyota".
Hope this helps.
earabadj is offline   Reply With Quote
Mortgage | Loans | Bad Credit Mortgages | Cheap Loan | Keyword Suggestion & Research
