Increased head size for improvements
Just wondering if bolting on a bigger head size would show any improvements or changes.
What I am thinking of doing is putting the head of a bigger engine from the same family on top of mine. Specifically I have an isuzu 4fb1 1.8ltr (bore 84mm) the options are 4fc1 2ltr (bore 84mm) 4fd1 2.2ltr (bore 88mm) 4fg1 2.4ltr (bore 89.3) I am not sure if the different bore size will mean anything but put it in just in case Or just tell me I have no idea what i am talking about and to give up this one ![]() Cheers |
I'm not familiar with those engines. But in general installing a head from a bigger engine will lower the compression ratio. This could be an advantage if you need to lower the compression ratio due to large numbers of turbo boost. But otherwise lowered compression will lose power and hurt fuel economy.
__________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
retired maths geek huh
you could get bigger valves on the "bigger" heads for increased max. hp but then if they don't fit the smaller bore that will be of little use
__________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
Mortgages | Mobile Phones | Cell Phones | Shops 2006 | Secured Loans |
