Old 11-12-07, 08:40 PM   #1
mystery diesel motor
Hello to diesel guys! I have gas FJ60s and am clueless about diesels, but interested. Here is my question. While I was on a trip to Argentina this summer, we were transported in a late model Ford crew cab pickup that was a diesel. I got a very brief look under the hood and to my amazement, it was a straight six cylinder. Furthermore, unlike my F250 diesel here in the US, I could actually see the ground on both sides of the engine when I looked in the engine bay. The thing looked really simple as compared to my truck in the states.
Question#1: What do you think the motor was? It was obviously stock and the truck was badged Ford F150 even though it appeared to be the size of the US F250.
Question #2: Could an engine like that be found in the US?
Question #3: Could an engine like that fit easily in a FJ60?
86 FJ60, Champagne Bronze, 33X9.5s, Desmogged, Dynamat, ARB in rear, 4.11 gears. OME lift, bedliner on rocker panels. Tint.
1987 FJ60 Dark Blue Metallic, 31X10.5s, 130K, Desmogged.
"We have enough youth, how about a fountain of "smart"?
Heartworm is online now   Reply With Quote
Old 11-12-07, 09:11 PM   #2
watrob's Avatar
It won't be simply, if you want a diesel stick to a Toyota diesel, you also have to marry the gearbox to the diesel motor as the shafts are differents lengths and can have different spline counts to a gas motor.
So you need to get a diesel motor gearbox combination with toyata diesels. 60 series came out with 2H diesels and there is the turbo version the 12HT.
Also the 75 series came with diesel.
If you search the diesel thread there quite a few conversions to diesel so there should be some adapter plates for other brand of diesel motors. If it was me I would do a conversion that has been done before on this forum, would make it a lot easier for you.
Rebuild 1974 FJ40 2F into a 1984 HJ43 2H Diesel.
http://forum.ih8mud.com/40-55-series-tech/173333-rebuild-my-fj40-1974-rhd-down-under.html
watrob is offline   Reply With Quote
Old 11-12-07, 10:42 PM   #3
junkyard dog
Henry James the 47th's Avatar
TLCA# expired
"...60 series came out with 2H diesels..."
Actually, the 2H premiered in the last of the 40 series, the HJ47, at the same time as in the 60 series, though the precursor to the 2H, namely the H motor, saw service in the HJ45 trucks.
My 1982 HJ47 rebuild: http://forum.ih8mud.com/fj45-owners-...come-here.html
Henry James the 47th is offline   Reply With Quote
Old 11-12-07, 10:53 PM   #4
73 and 75 series also came with 3B, 13BT, 2H and 1HZ.
60 had 2H and 12HT
just so you know the 1 at the front means it is direct injection. the others are indirect.
My personal recomendation would be a 12HT
pantheas18_hj47 is offline   Reply With Quote
Old 11-12-07, 11:31 PM   #5
Diesel for blood
roscoFJ73's Avatar
It could have been a European Ford design or maybe a Nissan (United Diesel) implant.
There is no 6 cyl diesel car or 4wd engines in production anymore so it was probably a dedicated truck motor.
The easiest non toyota engine to install is a 6.5 chev diesel
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 11-12-07, 11:38 PM   #6
mac
rust and moth consumables
mac's Avatar
There was an ebayer selling 6 cylinder diesels with PowerStroke on the valve cover a while back. They were from South or Central America (Venezula?) and were manufactured under licence to Ford. He was selling them fro something like 5grand and they seemed to be popular with the Rover crowd.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 11-12-07, 11:41 PM   #7
Diesel for blood
roscoFJ73's Avatar
They were the V6 and a IH design I thought??
33 in BFG A/T
Volvo 740 GL
Old 11-13-07, 02:05 AM   #8
IH/Navistar redesign of the old rover 300TDI.
It's a 2.8L 4 banger.
But central america has plenty of engines which don't see the light of day in other places. Check out MWM and others.
Old 11-13-07, 02:57 AM   #9
Diesel Trucker
This isnt always correct.
On the earlier engines 3B Vs 13B or 2H Vs 12HT the "1" does indicate direct injection.
The 1HZ is not direct injection. Toy uses a different naming convention for these overhead cammers - 1HD is direct injected.
lynchmob is offline   Reply With Quote
Old 11-13-07, 05:31 AM   #10
watrob's Avatar
Around 1989 the 2H diesel went OHC, yes they did come out in the HJ45 & HJ47, then the 60 series, 75 series, the later 75 series got the OHC version. Very, very common in Australia, not so in the US I heard.
I prefer the diesels without computer application in a FJ40, when your out on the trial keep it simply I say.
http://forum.ih8mud.com/showthread.php?t=173333
Old 11-13-07, 08:33 AM   #11
HJ61TurboDiesel's Avatar
1HZ would fit your 5 speed h55f box (if you have one) from the 60 series. This providing you change the input axel into your gearbox. The 75 series came with this setup 2H/h55f.
I think this means that if you have a h55f with the different input axle you may put the turboed 4.2 litre (1HZ?) into it as well.
Both these solutions provide that you move the engine mountings on the frame.
HJ60(1) 4 liter TurboDiesel. 10" Mickey Thompson, 33X12.5X15 Goodyear MT/R. Frame-off rebuild: full-floater rear. Brakes, hubs, steering, drive shafts, transfer, H55F and turbo rebuildt. PTO. Frame rust-free and galvanized, Working on rusty body %#!+? )%¤# Nordic Blue
HJ61TurboDiesel is offline   Reply With Quote
Old 11-13-07, 10:11 AM   #12
It is a 2.8L TGV made by MWM International motors. Old British Wheels of Canada imports them to North America. Advance Adapters makes an adapter kit for that allows you to mount it to anything you can mount a Chevy small block in. It is turbo charged and intercooled. It does not use a computer, it is direct injection. It makes 135hp at 3800rpm. It makes 276 foot pounds of torque at 1400rpm. It is Euro II emissions compliant. It weighs in at 208Kg or 458lbs.
dan1983 is offline   Reply With Quote
Old 11-13-07, 01:07 PM   #13
Rig of Mortis's Avatar
60 had 2H and 12HT
Just to add, the 60 series also came equipped with a 3B (in Canada).
Rig of Mortis is offline   Reply With Quote
Old 11-13-07, 03:27 PM   #14
Tapage's Avatar
Interesting how diferent engines come bring to life many diferent trucks and aplications. We never see a 6 in line engine in a F-250 .. but certanly most that we see here are V8 diesel ..
And for your 60 series .. 12H-T ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 11-13-07, 04:27 PM   #15
Diesel for blood
roscoFJ73's Avatar
We had some F 250 in the 80s that had a diesel .It was a 5.9 inline 6 cyl I think. Possibly a International Harvester engine. They weren't fast anyway
33 in BFG A/T
Volvo 740 GL
Old 11-13-07, 04:58 PM   #16
Interesting article
See the following article posted by OBW up in Canada, first post, towards the bottom. He talks about a stock straight 6 in the F-250 in South America.
Interesting-
http://www.pirate4x4.com/forum/showt...57133&t=436037
1978 FJ40 mostly stock - 33x9.5
nickwood48 is offline   Reply With Quote
Old 11-13-07, 11:51 PM   #17
jasonmt's Avatar
The Argentinean F100 is a rebadged Brazilian F250 which is a 2007 back US F250 with a 3.9L CUMMINS "B" 4 cyl 200HP engine (common rail) which replaced a 4.2L MWM Sprint inline 6 (which was a 6 cylinder version of the 2.8L PowerStroke) used previously:
http://translate.google.com/translat...hl=en&ie=UTF-8
http://www.motoresdiesel.com.au/Sprint%20brochure.pdf
http://www.motoresdiesel.com.au/Spri...cal%20Data.pdf
jasonmt is online now   Reply With Quote
Old 11-14-07, 08:09 AM   #18
60 had 2H and 12HT
thanks for the corrections boys. info similated chief!
Loans | Enertia electric motorcycle | Problem Mortgage | Novela histórica | Loans
