1981 diesel pickup 1l
I need a cylinder head, mine is cracked beyond repair. I do not know if I`m in the correct section or not, if not my apologies.
#2 | |
Diesel for blood
Yours is probably a 1L , 1.8 litre __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Thanks again Roscoe, I figured out that it`s a 2.2 diesel called the 1L. I found a head and gasket and I will be putting her back together over the weekend. Do I have to re-time the inj. pump. How should I set cam timing?
#4 | |
Diesel for blood
It should have marks etched on the timing gear . Usually the pulleys or gears will only fit one way onto a camshaft, pump shaft and crankshaft. They are each aligned with a point etched onto the engine block Its easy if you have a manual. Major disasters can happen if you dont. The 1HZ has 2 lots of marks. One set is for putting the belt on,then you rotate it and the other set of marks should align if you have done the 1st step right. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Credit Card | Loans | Credit Cards | Shares | Credit Counseling |
