napa belt #s for '89 3B
Looking for napa or equivalent part numbers for the following OEM parts for an '89 3B:
water pump & alternator belt: 90916-02240 power steering belt: 99343-11510 (I think Napa 24607 works; can anyone confirm?) A/C belt: 99322-01045 Why does Napa have none of these OEM Toyota numbers in their catalogues? Is it because they are JDM parts? Can Toyota Canada provide translations between the JDM part #s and NA ones? I'm compiling a list of 3rd party part #s for the 3B manufactured between 88/08 and 90/01. Seems like there are quite a few differences to the earlier 3Bs. I'll post the list to the parts thread once it's done. Cheers Dave __________________ 1989 JDM BJ73, 3BII |
The alt. belt on my 82 3B is Gates 15A1205 (Bought at NAPA). Not sure if it will cross with your 3BII, but I suspect so? The other two I can't help you with because my utilitarian beast does not have those options!
__________________ 1982 BJ60, 3B, 245,000km, Deblinged Freeborn red. |
25-22607 for napa power steering belt...used one this summer...it works fine...it is just a tad to big, you still have adjustment space left to tighten it more, it just starts out about 2/3 way through the adjustment range.
I used it on a 85 bj60 Daryl __________________ 74 fj/bj40 88 fj/bj62 , full OME lift kit , home brew turbo , 4 runner brakes . |
A little research with the Toyota EPC (Japanese model data only) revealed the following:
Alternator belt was unique to the BJ7x series from 88/08-90/01. Power steering belt is common to BJ7x from 84/11-90/01, BJ4x from 81/10-84/10, and BJ6x from 81/10-86/10. A/C belt is again unique to 88/08-90/01 BJ7x The easiest way out may be to pull all three off and get myself over to a napa to match them manually. __________________ 1989 JDM BJ73, 3BII |
Are they the same belts as a 13bt? If so these part numbers from the diesel part number thread stickied at the top of this forum should help.
BJ74 13B-T Belts Alternator: 22474 (NAPA) Power Steering: 22607 (NAPA) A/C: 17405 (Goodyear) __________________ '89 BJ74 '85 BJ70 - Sold (Frame rotted away )
3B 13B-T engine belts
WP Fan & Alt 99343-01195 (Toyota) (Metric Part Nos.) PS pump 99343-11510 (Toyota) 15A1510 to 15A1595 AC compressor 99343- 01045 (Toyota) 13A0915 to 13A1045 NOTE that "to" indicates a range of sizes. The metric size number is the belt width in millimeters and the belt length in millimeters. thus 15A1195 to 15A1205 indicates a belt length between 1.195 meters and 1.205 meters, or ~47 inches to ~47.5 inches note that the correct Toyota part numbers are also indicating the length in millimeters. it ain't rocket science Last edited by M John Galt; 11-14-07 at 10:07 PM. |
The PS and AC belts match with the 13B-T; the metric sizes and OEM numbers are as M John Galt lists above... still haven't found the metric size for the fan belt (90916-02240). The local Toyota dealer has never heard of the part number... predictably.
Just give 15A1205 a try.. If it doesn't work, take it back.
Yep, that's what I'm going to do... I have a feeling I'm going to get very used to bootstrapping this kind of thing, owning this truck... :-)
Credit Cards | Loans | Xbox Mod Chip | Web directory | Car Credit |
