Battery Ground question
In by BJ44, the neg terminal of the low side battery is grounded to the battery tray itself. I'm not an electrician, but that doesn't sound too good.
Where is the stock grounding point? If I am going to move it, is there a better place to ground it than even the stock location? Should I run it to the frame? Thanks! __________________ 1981 JDM BJ44 RHD - Going under the knife soon! |
You can never have too many grounding points.
If you think the current one(s) may be iffy, adding several more to various points will be beneficial. Just make sure you have good, solid contact between the lug and grounding point, and smear some copper slip over the lug once bolted in place to prevent corrosion.
I would have at least one ground to the frame rail and another ground to the engine.
__________________ John G. 姉 ![]() Join the Import Vehicle Owners Association of Canada: Fight for what is right |
Size and length of grounding wires is important. I once had a SBC powered boat that would crank okay, but wouldn't fire until you stopped cranking - it didn't have enough voltage while cranking to fire the spark plugs.
Highest current draw is the starter, so ideally, the most direct ground should go there, with the engine also connected to the frame. It is also a good idea to have redundant grounds, so if one connection goes bad, you don't end up grounding the engine through a clutch cable, fuel line, or some other bad path. __________________ '74 Bronco - RIP '75 FJ40 - Gone '81 RamCharger - Gone '95 XJ - recently Gone '85 SR5 - Going '90 HZJ73 - 24V winch, Lift, Auto
what is copper slip?
I was using that red stuff in the spray can. __________________ 1981 JDM BJ44 RHD - Going under the knife soon! |
#6 | |
http://commaoils.com It's in the maintenance section. Due to the fact that it contains traces of copper, it protects whilst not running the risk of acting like an insulator, as grease can. |
Mod in Hibernation
if it's called dielectric then it's an insulator and not good for connections. I used a conductive grease on planes in salt water once.....darn if I can remember the name.
Copper antisieze should be conductive. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
The red spray sutff is stuff you use to protect battery terminals. I did alll four terminals on my bats, but not the grounds or anything else.
If I want to get a grond that connects to both the frame and the engine, do they make split cables liekt that? how long will I need? __________________ 1981 JDM BJ44 RHD - Going under the knife soon! |
#10 |
You can make your own cable. Oh and I forgot the body in my first post. So you should have a good solid ground connection to body, frame and engine.
#11 |
How do I make my own? I can see where I would buy cable and then put two ends on (battery terminal and eye for frame). How do I make mulitple 'arms' off of one cable?
#12 |
Go to any commercial supply electrical shop and say you want a water proof bus or terminal to connect three ground cable wires off of the one ground wire coming from the battery. They will be able to give you some options. Don't expect anything from your every day run of the mill automotive place like Crappy Tire or say from the electrical department at Home Depot.
#13 |
Mod in Hibernation
why do you need multiple arms? for the positive you use a post with a stud on it, then the cables that connect to it they have ring terminals.
I like 2/0 cable for battery cables my self. The ends are best soldered on. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#14 | |
Now why didn't I say that? Much better this way than a bus.
#15 |
Makes sense!
Duh,
I put a new one of those on on the 214v POS just the other day. I can make a few separate cables that each go to the engine, frame, and body. So, I know where I can go the body, and the frame, but where is the best place to attach to engine? Thanks for all of the help! __________________ 1981 JDM BJ44 RHD - Going under the knife soon! |
Buy Anything On eBay | Loans | Mortgage | Property for sale in Spain | Debt Consolidation |
