Old 11-07-07, 03:07 PM   #1
Glow plug testing question
I am a newbie to testing electrical systems and had a question about testing glow plug health.
I tested the voltage at the front cylinder glow plug and got a 20.5V reading for a second or two and then it dropped to around 10v. it sat there until the relay shut down the glow (around 10-15 seconds).
I read in the FSM that you also need to test the Amps getting to that plug. I have a cheap combination meter from Sears that has mulitple settings of what you want to read, V, Ohm, and Amps in different ranges. I have to admit I barely know how to use it properly.
What setting should I use and how should I place the sensors to get the right reading?
Where can I get a good set of not too expensive glow plugs?
1981 JDM BJ44 RHD - Going under the knife soon!
BreckenridgeCruiser is offline   Reply With Quote
Old 11-07-07, 04:30 PM   #2
MattF's Avatar
To test current, you need to break the circuit and connect the meter inline to again complete the circuit, with the meter range selector on whichever Amp range you want to measure.
There's a Toyota guide on testing glowplugs here:
http://forums.bauchan.org/portal/vie...ds.php?dcid=14
MattF is offline   Reply With Quote
Loans | Mortgage calculator | Advertising | Exchange Newsgroups | Per Insurance
