remote start 24 volts
Can you tell me if a remote starter system can be installed on 1988 BJ-73 (J.D.M) 24 volts 3b engine 5 speed manual
Yes, but the install is a little more work, you will need a 24V to 12V converter (it you don't already have one), and at least 4 relays.
When connecting the remote starter, the power leads of the remote starter will connect to your 12volt converter, the outputs from the remote starter to the starter, accessory and ignition wire's (should be 2 wires for IGN) will conect to relay's (on the coil side), on the contact side of the relay one terminal will connect to a constant 24 volt power source the other terminal will connect to the starter/accessory or ignition wire. If you plan on connecting to power locks or power windows you will need to use relays in the same way. __________________ 91 LJ78 -My TOY- RHD JDM import, 2" O.M.E. lift 99 Mustang Conv -Hers- (totalled) |
Shares | Remortgages | Mortgages | Auto Loans | Quick Collect |
