Diesel rookie needs DD tips.
I recently sold my daily driver (300e) and replaced it with an hj60 that has recently been resurected from a 3 year hibernation. Anything I should look out for like any common hj problems? Mine has a 2h with an auto. tranny. Thanks in advance.
Iron oxide infestations are quite common.
__________________ John G. 姉 ![]() Join the Import Vehicle Owners Association of Canada: Fight for what is right |
TLCA# 16387
John's comment on rust is very true if you're in Canada. If the truck was out of use for 3 years be prepared to replace a few seals as they leak if they are unused for a while.
__________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
I would check/change the transmission fluid and check the condition of the batteries. I would also make sure the PO was not running any accessories off of one of your batteries (I am assuming it is 24 volt).
The only problems I have had with mine were electrical. If you're in Canada or somewhere else that is cold, check glowplugs. |
The only real issue you'll ever have with a diesel early on in it's life, are fuel, and if someone hacked the electrical... I've had both of these problems, the fuel issue, was from rusted vent tubes, and the electrical issue was from someone hooking up some really sketchy trailer lights...
__________________ 1986 BJ70, 24v with a 3B |
3 years is a long time for a vehicle to sit unused.
Go through it, especially seals, all brake components and change all fluids. Shocks and springs may need replacement, just an excuse for a new lift. Let us know how you make out and post some pictures. __________________ JoeTLCA # 6363 Yankee Toys Gotham City Land Cruisers Connecticut Open Access Land Trust Northeast Association 4 Wheel Drive Clubs Tread Lightly - Tread Trainer National Off-Highway Conservation Council 1977 FJ55 - for fun (x2) 1979 FJ40 - the wife's 1986 HJ60 - my dd 2007 FJC - my second dd? |
Thanks Y`all,
I`ve been going through this truck for about a month now and thanks to everyones help on here, I started driving it full time today. I replaced about 20 seals and gaskets, replaced a bad t.case and fixed my leaning OME suspension. I am a total hack when it comes to the wrenches but got through it with no major hang ups. I drove 320 kms today without a glitch, love this truck!!!! |
#8 | |
I thought you also replace all your fluids .. |
#9 | |
BJ addict
__________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#10 | |
So: find out how/where the vehicle was stored, and check the condition of those steel fuel/hydraulic lines, for safety's sake. Good luck. __________________ Current rig(s): 1992 HZJ80 LHD 215Kms SOLD: 1982 BJ60 3B H42 230Kms and counting Still planning an expedition... |
#11 |
Thanks again, I did have to replace all of the brake lines, as they were almost all leaking. Rotors are next, this truck has so much frame rust I`m not sure that it`s safe. The rear section is worst and should at least be re-enforced. I live in the states, always wanted a diesel 60, every time I start it I smile.
#12 |
Too bad about the frame rust, it's a killer on those trucks for sure! Thankfully, mine is quite solid front to back.
I'm sure others on the list here will suggest to you that if the frame is that bad, you might consider transplanting the diesel drivetrain onto a relatively rust-free Southern FJ60. Will give you a longer lasting solution in the end, with that diesel powerplant that you like so much. For some people, that kind of drivetrain transplant is easier than for others (experience, skills, tools, space), but it's always possible to pay someone else to do it, if you find a good LC mechanic near you. All depends how bad the frame is (and possibly, the body too). If it's more than just the rear portion that's going, you may want to consider that FJ60 transplant route sooner than later. Your call. Good luck, and glad you like the sound of that diesel! __________________ Current rig(s): 1992 HZJ80 LHD 215Kms SOLD: 1982 BJ60 3B H42 230Kms and counting Still planning an expedition... |
#13 | |
Mod in Hibernation
I would find a clean fj60 frame to convert over on your hj. Also if the body is really rusty if you look here on mud you might get a real good deal on a rust free 60 with a shot engine. Then transfer all the diesel goodies in there. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
Xecuter 3 Mod Chip | Enertia electric motorcycle | Mobile Phones | Debt Consolidation | Advertising |
