LinkBack (11) Thread Tools Display Modes
Old 08-28-08, 04:36 AM   #121 (permalink)
jabxyz's Avatar
TLCA# 18735
Matt,
Can you give a quick step by step how to for guys like me who clearly just lost all mental cohesion and can't seem to figure out how to download the EPC via the bit torrent system that you have setup. Please include links etc. As a start I have already loaded Filezilla and am ready to rock now. Thanks and cheers
'80 BJ 40, B engine, H41 4spd (split case) 4:11s, 4" lift, 33" Toyos, Front end: Long 30 spline birfs and inners, Rear End: FF Axel
Just looking for a straight answer in a twisted world
Build thread: http://forum.ih8mud.com/40-55-series...storation.html
Member Mudders in Latin America
http://el-salvador-mud-4x4.blogspot.com/
jabxyz is offline   Reply With Quote
Old 08-28-08, 05:46 AM   #122 (permalink)
MattF's Avatar
No problem.
That Filezilla programme will only do ftp transfers, so firstly, you'll need a different client programme. There is an extensive list of the more widely known clients here:
BitTorrent client - Wikipedia, the free encyclopedia
and this section:
BitTorrent (protocol) - Wikipedia, the free encyclopedia
gives you a basic idea of what it does.
Personally, I use UTorrent on M$. Seems the most configurable with the least phaff that I've found upto just.
Torrent - The Lightweight and Efficient BitTorrent Client
In a nutshell, download and install that programme, (or fire up your existing torrent client if you have one installed), then click upon that little green torrent icon on the downloads site. You will then be prompted to open or save the torrent file. (A small file which just contains the info required to download the actual main file itself). If your torrent client has been set as the default to open .torrent files, click on open and your torrent client will take over from there, (prompting for any options it may require), or click save and it will ask for a location to which to save the .torrent file. Save the file to wherever you normally would for something you download. Then, open your torrent client and tell it you wish to add a new torrent. Point it to the location of the .torrent file you just downloaded and then it will, (again, if required), prompt you for any options it may require before adding the torrent.
After adding the torrent, just leave the client to do its work. You may find that it takes several minutes to find any available seeders. That's nothing unusual, so no need to worry if it does.
What will happen using this system over the ftp method is that your torrent client will connect both to the seeder running on the server and to anyone elses machine which is in the process of downloading or seeding that same file as you are downloading. What then happens is that you literally share the file between yourselves, as well as getting missing parts of the file from the server. The server seeder is there to make sure that a seed for each file is always available. The more people who are downloading or seeding that particular file, however, the faster your download should become, as you will be getting parts of the file from several different machines.
At a push, if you can't get to grips with the torrent system, a couple of ftp connections have been left in place as a secondary download system, so the ftp option is still available, (when it has a free slot). You should find that the torrent system performs better, however, especially if there are other seeders/downloaders for that file.
That's why I've put this system in place in preference of the ftp system. I used to get no end of grief about the ftp server being busy and having no available download slots, but with this system, it isn't as dependant upon the server itself for the data transfer, so the availability should, theoretically, be better, especially as more people leave their machines seeding the file(s).
The server is still completely in control of tracking and the initial seeding, (just to allay anyones concerns), but the distribution system should improve the file availability notably eventually, (one hopes).
Once a download is completed via the torrent system, btw, it would be greatly appreciated if you could seed the file(s) you've downloaded for a while from your machine. That way, it will give anyone else downloading the same files the benefit too.
Workshop Manuals
MattF is offline   Reply With Quote
Old 08-28-08, 06:57 AM   #123 (permalink)
wildsmith's Avatar
Originally Posted by 83bj60 View Post
I would like to take the opportunity to thank you for an EXCELLENT PDF conversion. Most of the text IS text instead of simply pictures like one can see in other 'photocopy' manuals, which contributes to its very compact small download size. Nevertheless, the pictures are very clear. Kudos on the OCR and for a job VERY WELL DONE!!!
Thanks for the compliments, I did put quite a lot of effort into trying to get it right and it has obviously paid off
Someone was asking about suggested scanning resolution - all my manuals were scanned at 300dpi on a cheap and chearful Epson RX600 one page at a time in various busts of activity over a couple of years I have a Photoshop filter sequence recorded as an 'action' I use to clean up each scan to remove what's showing through from the other side of the page. Then they go through ABBYY Fine Reader for OCR and becoming PDF's.
Jon.
Jon m0zxj
01 UZJ100 auto - lifted, locked, front bumper, sliders, snorkel, big tyres etc.
93 HDJ80 12v auto - lifted, oem locked, front bumper, sliders, big tyres etc
wildsmith is online now   Reply With Quote
Old 08-28-08, 07:02 AM   #124 (permalink)
wildsmith's Avatar
I leave my machine running BitTorrent as often as I can remember to help with the seeding. How hard was this to set up on your server? I have a dedicated server running Fedora 5 with spare space and bandwidth that I could seed from your site if it isn't too time consuming to set up.
Jon m0zxj
Old 08-28-08, 01:54 PM   #125 (permalink)
MattF's Avatar
By crikey. Now that's dedication and patience.
Thanks.
That would be absolutely spanking if you could put some space/bandwidth to one side for it. All in all at the moment, I think there's around 12G of files up there, (excluding the old EPC's, which aren't on the torrent setup).
In truth, the client prog that is doing the seeding is simplicity itself. Took me ages to find it, but it's a gem.
BTPD - The BitTorrent Protocol Daemon
Most of the aggro I had with this torrent system was due to having to adapt and rewrite the tracker/scr@pe scripts to fit in with the downloads server. That client prog is about as simple as it gets, however. No external dependencies or suchlike. A quick config, make and install and it's sorted. Best part is that it only requires a single instance to be run to do all the transfers/seeding. It doesn't need a separate instance for each torrent. It has a nice little commandline interface too, and only needs a simple one liner to add a new torrent, and then it reloads them all automatically on each restart, so there's no phaffing about once they've been initially added.
The only caveat, (if it can be called such), I've found so far is that it does ever so occasionally exit for no discernible reason, but I just run a shell script from cron every quarter hour to take care of restarting it if needs be, so that's no biggie. I seem to remember it's only happened twice this month, so it is a rarity rather than the rule.
If you want to give it a whirl, PM me your e-mail address and I'll e-mail all of the torrent files and the shell scripts, (one for startup and the cron monitor script), over to you.
Thanks ever so much once again.
Workshop Manuals
Old 08-28-08, 04:23 PM   #126 (permalink)
wildsmith's Avatar
Yep, no magic 'just do it' button just lots of patience. I still have 4 suppliments and some EWD's for the HDJ's to go
PM sent.
Jon m0zxj
Old 09-01-08, 04:31 PM   #127 (permalink)
MattF's Avatar
I'll be truthful and say that I don't envy you the task. Awfully appreciative that you do so, however.
Workshop Manuals
Old 09-01-08, 04:36 PM   #128 (permalink)
MattF's Avatar
Question. I've got hold of another F engine manual and was just curious, (with me not having any LC knowledge to brag of), what the main difference will be with this one versus the existing one. It's the 1966 version, PN: 97213, whereas the one that's up there at the moment is PN: 98087. Is it just an age related thing more than anything else? Managed to get the 1964 FJ40 owners manual too.
Workshop Manuals
Old 09-19-08, 12:27 PM   #129 (permalink)
MattF's Avatar
Thanks to astr, the A440L/F manual is available now too. Cheers again for that.
Workshop Manuals
Old 10-09-08, 10:41 PM   #130 (permalink)
14bt and 15b manuals
Any good news on these manuals?
thank you
Spallet is offline   Reply With Quote
Old 10-10-08, 08:18 AM   #131 (permalink)
MattF's Avatar
Not quite sure what you mean?
Workshop Manuals
Old 10-10-08, 01:37 PM   #132 (permalink)
jabxyz's Avatar
TLCA# 18735
thank you
Matt,
This refers to Snail trail and my collaboration on getting these manuals scanned. I got them not too long ago after what seemed like months in the mail from NZ. There are actually two manuals (1)the 3B, 14B, 15B-F and 15B-FT and (2) the 15B-FTE. I am scanning manual both this weekend and hopefully will get them to you early next week.
John
Old 10-10-08, 07:07 PM   #133 (permalink)
Matt and Jhon
That is great, I need the manuals for a conversion.
Thank you for your time
Old 10-10-08, 10:48 PM   #134 (permalink)
jabxyz's Avatar
TLCA# 18735
Spallet,
This isn't a thread hijack but what conversion are you doing, the 14B or the 15B and where did you get the engine? ( possible conceptual hijack over)
John
Old 10-11-08, 08:57 AM   #135 (permalink)
Hello Jhon
14bt engine in a 85 bj70....
Old 10-11-08, 10:16 AM   #136 (permalink)
jabxyz's Avatar
TLCA# 18735
Interesting. In case you haven't done so already, you may want to check out this thread on this and similar swaps.
John
http://forum.ih8mud.com/diesel-tech-...-bt-15-bt.html
Old 10-13-08, 09:51 PM   #137 (permalink)
Hello
Any updates on 14bt manuals?
Old 10-14-08, 03:35 PM   #138 (permalink)
jabxyz's Avatar
TLCA# 18735
Hello
Scanner broke down. I'm taking it in to get looked at this week. I'll let you know.
Old 11-04-08, 04:02 PM   #139 (permalink)
MattF's Avatar
Originally Posted by jabxyz View Post
Matt,
Cheers for the explanation John. I'd completely gone into muppet mode on that one.
p.s: Apologies for the belated response.
Workshop Manuals
Old 11-26-08, 04:13 PM   #140 (permalink)
brisveganbj42's Avatar
Originally Posted by brisveganbj42 View Post
This where previously not working but I can now confirm that they are.. sorry for the inconvenience.
'84 BJ42 with all the fruit - fun to drive 7 days a week!
Got a BJ42? Join the crew @ PHAT42!
my 'shed'
3rdrock4x4 club
QLD 4WD Spares and Repairs
brisveganbj42 is offline   Reply With Quote
Old 12-03-08, 07:36 AM   #141 (permalink)
BinaryDude's Avatar
TLCA# 19047
Does anyone have the FSM for the H Diesel?
BinaryDude
Twitter - Harrakis
2004 ChevyS10 Crew 4x4
FS: 1980 HJ45 TROOPY - "Oswald"
DixieLand Cruisers
Cruiser Wines have arrived!
Wine fundraiser for a great cause!!
BinaryDude is offline   Reply With Quote
Old 01-21-09, 07:39 PM   #142 (permalink)
HJ60Samoa's Avatar
Need some help please. Can someone send me a copy of the manual for HJ60, and 2H engine? I live in Samoa and dont have acess to paper copies, and only internet is a cafe (slow and expensive, and cant download those files from the site) Any one could email them to me would be a huge help!
peace,
D
HJ60Samoa is offline   Reply With Quote
Old 01-27-09, 10:07 PM   #143 (permalink)
HJ-45CrewCab's Avatar
TLCA# 10465
I have this manual. Ordered it from SOR.
1980 HJ-45 Mining Conversion
1995 4Runner
2007 FJC
2005 BMW F650GS Dakar
1968 M105 trailer
HJ-45CrewCab is online now   Reply With Quote
Old 02-14-09, 05:34 AM   #144 (permalink)
TLCA# 03672
sor has the manual, and also check aussie suppliers like roodogs on ebay- and a few others in canada-
recyclingthepast is offline   Reply With Quote
Old 03-05-09, 04:06 AM   #145 (permalink)
Hey all, just bought a 14bt for my 40 series.. just wondering if anyone has a online manual i can download.. i was seaching though this thread and noticed that it was being scanned???
any success??
cheers
James
James_witham1 is offline   Reply With Quote
Old 03-05-09, 04:57 AM   #146 (permalink)
drexx's Avatar
Post
05Mar2009 (UTC +8)
Hiya James,
Check this out: Downloads - Page: 1
Drexx Laggui - TLCA; 4x4PH
UZJ-100; FZJ-80L; FZJ-80; HZJ-80L; LN-166
Metro Manila, Philippines
Action and adventure pics!
UZJ-100W; FZJ-80L; HDJ-80L specs
drexx is offline   Reply With Quote
Old 03-08-09, 05:00 AM   #147 (permalink)
hey mate i loved the site , but failed to find anything on the 14bt. if you could send me the link that would be fantastic. cheers James
Old 03-08-09, 07:10 AM   #148 (permalink)
drexx's Avatar
08Mar2009 (UTC +8)
Sorry James, it's all I know :( My hard disk had a catastrophic failure a few months ago, and I lost all my Toyota repair manuals...
Old 03-08-09, 11:01 PM   #149 (permalink)
ah thats coool man. is there anyone on the site you know of who might have an electronic copy? im sure there would be one out there?
thanks for your help
James
Old 03-10-09, 02:21 AM   #150 (permalink)
60 Series manuals available for download
All,
I've posted the manuals I collected for my 60 series to:
workshop_manuals and they are available for downloading.
Engine manuals for 2H and 12HT
Gearbox for ,H42,H50,H55F fitted to 60 series cruisers
Maintenance procedures.
Tim-HJ61 is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/184462-online-manuals.html
Posted By For Type Date
Factory service manual for 99 FG - Expedition Portal Forum This thread Refback 10-20-09 03:22 PM
Untitled document This thread Refback 09-11-09 09:25 AM
Ôîðóì ñåòè Toyota4X4.RU > Ðîäíîé ìàíóàë íà <80>-êó This thread Refback 07-02-09 05:18 AM
Outer Limits 4x4 Board :: View topic - searching owners manual This thread Refback 04-11-09 10:28 PM
4Runner Repair Manual, 4Runner Performance Parts, 4Runner Taillight Converter Auto Circuit Protection - Freemanpeugeot This thread Refback 03-08-09 09:36 AM
Ôîðóì ñåòè Toyota4X4.RU -> Ðîäíîé ìàíóàë íà 80-êó This thread Refback 08-26-08 11:26 PM
Outer Limits 4x4 Board :: View topic - fuel adjustment on 2H This thread Refback 05-19-08 05:30 AM
Untitled document This thread Refback 04-13-08 03:31 PM
Outer Limits 4x4 Board :: View topic - searching owners manual This thread Refback 04-12-08 04:30 AM
Outer Limits 4x4 Board :: View topic - searching owners manual This thread Refback 04-02-08 05:48 AM
Outer Limits 4x4 Board :: View topic - searching owners manual This thread Refback 01-10-08 08:08 PM
