Old 10-18-07, 07:06 PM   #1
Talos's Avatar
12H fuel adjustment
So I upped the fuel on the 12H the other day, at least that´s what I think I did (man that sounds wrong)
There was a cap covering a screw, the cap had a seal on it, I cut the seal, took the cap off, loosened the nut on the screw and turned it 2 circles CCW then put everything back together.
didn´t see any increase in EGTs or any black smoke but I could swear I have more power now.
so my question is this: was it the fuel screw I was fiddling with?
...or did I something horribly wrong?
-1971 Toyota FJ-55 44" 302 etc.
-1993 Toyota Carina E 2,0 GLi
-1987 Toyota HJ-61 38" 12H-T http://forum.ih8mud.com/60-series-wagons/134457-hj-61-project-pics-ahoy.html
Hj-61 intercooler: http://forum.ih8mud.com/diesel-tech-24-volts-systems/181830-hj-61-intercooling-thread.html
Talos is offline   Reply With Quote
Old 10-19-07, 03:33 AM   #2
I believe what you adjusted was indeed the screw that controls the fuel delivery over the full RPM band. You should try to adjust the boost compensator so that you´ll get more fuel only when there is boost. To get to that adjuster you´ll either need to take the injection pump off the engine or take the intake manifold of, since that adjustment is on or better yet, in the top of the pump. I´ll try to get a diagram later to day. Or you could try to find an online FSM.
HTH,
Mark
1982 BJ 45 Troopcarrier
12H-t, H55-f, 60 series PS, cable lockers, HZJ73 rear axle w/disks, parabolics, 255/85/16
troopie is offline   Reply With Quote
Old 10-19-07, 08:01 AM   #3
Talos's Avatar
you´re turning out to be quite the godsend, thanks
and a diagram would be great.
so should I turn the fuel back to normal and just add fuel via the compensator?
-1987 Toyota HJ-61 38" 12H-T http://forum.ih8mud.com/showthread.php?t=134457
Hj-61 intercooler: http://forum.ih8mud.com/showthread.php?t=181830
Old 10-19-07, 08:18 AM   #4
If your EGT´s are not flying thru the roof i would let the adjustment you´ve made alone and do the rest of the "tuning" with the compensator.
Do you have acces to a fax machine? I can copy that page from my FSM and fax it to you.
PM me a number if possible.
Later,
Mark
Old 10-19-07, 07:05 PM   #5
Tapage's Avatar
Coul be not the same in you case .. but if help ..
2H
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 11-14-07, 09:38 AM   #6
i think there got 2 type of increament power.
1. i think what u said remove the cap and turn the screw few circle, and in front of it using a small allen key to adjust it, AM I RITE? i turn it to loss, then use the allen key to adjust almost to fit, little bit loss, then screw back with the 10mm nut.
the boost i set last time is about 1.7bar on stock and standard without intercooler, the power was crazy, the the standard auto4 gearbox can support. unless rolling start, this what i did .
(question: how to upgrade the fuel pump?? change the pump heart? i think got 6 , original i think is 9mm? change to 9.5mm? will it better?)
2. there got one screw, open using a screw driver, the cap is about 2inch diameter, u need to hack it to open it, it located near the diesal handpump, which is under the fuelpump. After u open the Cap, there some black oil leaking out, but its ok, u can see a thing like hammer, which is 2 side, located 180degree each, if u cant see it, u need to turn the ENGINE, how to say turn the engine, either u use ur hand to pull the fan cable to turn the engine crank, or u use to starting the engine, dun start the engine on, just click a bit a bit a bit so the engine will move, then ask ur friend to observe it, then there will got a hammer look a like, which u can use the sharp plyer turn it 1 circle got a CLICK sound , then in horizontal, still got one same thing, then u need to click start the engine again,, there got another same thing come again, then u circle using the sharp plyer to the circle u turned just now. finally u close the cap back, hack it a bit stiff.
BTW dont prepare to go away, ur engine RPM is HIGHER, and u need to adjust it, and also the aircond that rpm, the selenoid part rpm step u also need to adjust, if not when u open aircond ur car will flying forward hahahaha.
my english not so good, home dont mind
pioneer411 is offline   Reply With Quote
Old 11-14-07, 09:43 AM   #7
HTH,
Mark
can send to my email?
if yes here my email,
pioneer_411[at]hotmail.com
Pacotes Carnaval Salvador | Credit Cards UK | Credit Card | Refinance | Loans
