#31 | |
I was in the process of doing so too when I realized that my oil spots weren't from the pipe itself; they were from the cover it attaches to and its shitty cork gasket. __________________ "... the motor car, after woman, is the most fragile and capricious thing on earth." - London Daily Mail 1908 1982 BJ42 "Krull" |
#32 |
I used a Mann Hummel ProVent 200 on my Jetta TDI to catch the crankcase vapors before they make it to the intercooler. Maybe a ProVent would be the perfect solution for this problem too? Provent on a TDI
#33 |
BJ addict
Does it have a turbo? like the ad mentionned? if so, you may want to read this
http://forum.ih8mud.com/diesel-tech-...pping-oil.html __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#34 | |
BJ addict
#35 |
The vehicle matches the ebay listing, turbo and all. The turbo kit is from ATS in NZ. It looks to be a nice setup. However, there's no wastegate. No boost gauge either. I think I'll install one.
#36 |
BJ addict
No waste gate?, no wonder why you have alot of blow by from the crank case vent. Get a boost gage and report back. Well if you had to choose from pyro to boost, go with a pyro meter, if you can afford both go ahead. Good investement in the long run for your engine.
#37 |
I'll plan to install both.
I changed the fuel filter today. I filled the new one with Seafoam before installing it. I ran it for 30 minutes and let it cool down. It appears to be much easier to start now. Only time will tell. I ordered a diesel compression tester this evening. The blowby is pretty serious. If I put my hand at the crank vent tube I can feel very strong puffs of vapor. It's not as strong as an exhaust but it's fairly strong. I did read the other thread and there's a few good pointers on diagnosing compression problems. |
Online Advertising | Classifieds | Mortgages | Credit Cards | Loans |
