Injection pump
I am wondering if my injection pump is packing it in. It was cool this morning and my HZ was smoking a lot. The glow plugs are good but it was running really rough. Is there a preheater before the injection pump? It runs great when it is warm. Anyone have this problem?
__________________ 416 DoKa Mogs Real Trucks Don't Have Sparkplugs!
#2 | |
Diesel for blood
If the pump had something else wrong inside ,it would be running bad non stop. Have the injectors been done? What colour smoke was it? Running rough at start up is nearly always bad glow plugs,air entering the system overnight or low compression No pre heater. Wouldnt need one unless the fuel is gelling __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Dude sorry for asking? FU
Bad attitude
. You just got some good advise for something you could have used "search" for and you give Rosco the salute. Oh, I forgot something. ![]()
__________________ John G. 姉 ![]() Join the Import Vehicle Owners Association of Canada: Fight for what is right |
I was under the impression this was a website used by many for helpful advice . Using the search function is sometimes not as helpful or easily understood as we might believe . I hope that the trend of responding with rudeness to a legit question doesn't catch on . Just the way I perceived it .
__________________ 1977 fj40 1985 bj60 for sale 1993 80 series |
Yes, perception is everything.
It looked to me like Rosco gave good specific advise - even though he might of shown that the question was a bit annoying. He didn't exactly do a ![]() ![]() ![]() ![]() ![]() :m ad:![]() ![]() ![]() ![]() .I did a search using the key words "cold" and "smoke" in this section and pulled up 5 pages of hits. Search isn't hard - maybe the reading is hard if you don't have patience? I find that by sorting through all the search hits, I learn a lot of stuff along the way. Not exactly a waste of time.IMHO, Rosco did not deserve a "Dude sorry for asking? FU ", especially by a Rockie.
It is blowing smoke because it is cold, try glowing the key twice then start -- will probably work better.
__________________ Louis Check out my youtube videos at: www.youtube.com/lshobie Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/ |
Diesel for blood
FU too crybaby
![]() ![]() ![]() ![]() If you want some more precise answers ,why dont you add some more precise info like how many klms its done,last diesel service (if ever )and importantly ,the colour of the smoke which is where all diesel diagnosis starts.And sorry,diesels aren't for crybabies
Why am I a crybaby I just asked a question and I am dumped on for that! I believe my problem is in my glow plug relay not staying on long enough.
I don't think it was a stupid question.
#10 |
Also I ment F'd Up NOT WHAT YOU THOUGHT!
#11 |
Why can't we all just get along...
![]() BlackSmoker: More info would be helpful. Likely so would the search, even if it is sometimes not that intuitive. Check your preheat system (maybe cycle this twice like isobie says), injectors and look for air intrusion (this could be worse if it is cold). If you have a 416, you should already know diesels can sometimes belch a lot of smoke on a cold start. Rosco: HZ's have a heating screen, don't they? Preheaters are usually a necessity up here in the Great White North. Sometimes diesels won't start if it gets below -15 to -20 C with out a heater or being plugged in. Fuel won't gel at those temps. The Kootenays have probably had a couple below freezing nights already this year. -kevin __________________ If at first you don't succeed, then skydiving is probably not for you... |
#12 |
OK the injection pump has 130000KM on it pretty new I think concidering my 6.9 in my Ford gave up at 300000 and 600000KM. It has rebuilt injectors and glow plugs this year. It was cold in the morning and is white smoke the light in the dash stays on for only 3 seconds. Once warmed up it runs perfectly fine. I think the glow plugs aren't staying on long enough or the pressure in the pump isn't high enough. I would like to wire a switch in to go manual on the glow plug like I have for my other diesel vehicles. I have 24V glow and would like to keep it 24V. I think the pump pressure is to low because it doesn't have a lot of power and drops off at 3000 RPM. It runs low smoke when warmed up and only runs black when you give it full throttle. I adjusted the timing with the dial indicator to the specs in the Toyota manual. How do you increase the pump pressure? I have had this lack of power for a long time. I though it being an inline 6 it would have tons of torque but it doesn't looked at putting a turbo in or a 5.9 Cummins. The engine just seems guttless it will barely do 100 kmh. it consumes no oil and idles better than any diesel I have owned. Is this right?
#13 | |
Diesel for blood
For me a cold day is about 65c and about the limits of endurance for humans I would catch a cold just watching their weather forecast If the ambient temp is so low that can make them run rough although I cant recall too many canucks complaining about the 1HZ and HD T running rough when cold. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#14 | ||
Diesel for blood
Ok then ,abbreviations are confusing.
The pumps on these wear out around 2-300000 klms. Mine is still good at 217000 and my friends is good at 450000klms with no major work ![]() But some do wear out at 150000 according to my diesel shops.(I cross check info with various diesel shops )My glowplug stays on for about 3 seconds ,so if yours is too, in cold conditions, maybe that is where you should start. My understanding is the various temp sensors in the glow plug system adjust the glow period to the engine temp. I know there is one in the manifold and one in the block. My mechanic says they are not worth fawking around with and rips em out and replaces them with a button. I kind of like things kept stock to a point. Another way would be to install a relay with a built in timer that can be adjusted up to about 10 seconds of glow. You could warm the glow plugs direct from the battery for say ten seconds as a test and see if runs better at start up. You may have some problems with the pump adjustment. Both my 1HZ will do about 135-140kph flat out but it takes time to get there and I dont make a habit of it. The 75 has 217000km and the 73 has 17000klm on a rebuilt pump and engine. Both can maintain 120kph on the highway most of the time with no smoke. I dont think you can adjust the pressure on the pump,,its there or its not. Even leaks can affect the pressure so Im told. You said you had the injectors done,did that make any difference? I dont know your diesel shop ,but did they set the opening pressure and flow match them? Looking through the FSM there is a few areas of adjustment to the pump.Are the wires still there or have they been cut? If they have been cut ,then the screws are probably not in their factory set position. Finding someone who knows how to set the screws may be the final solution. Only problem I have with taking pumps near diesel shops is they want to rebuild them before they test them. Most of the parts are $250-$500 each and add labour and the bill quickly reaches $2000 and you dont even get to look inside ![]() Which is why I angle towards the cheap stuff 1st
#15 | |
#16 | |
Diesel for blood
You have to remember 3000 is fast for a diesel. The motoring journos use to refer to these as high speed diesels when they 1st come out. If they are running right they wont leave you with a red face in city traffic or on the open road. Hi Gazza ,where have you been lately? Im going to have to make a video of the non smoke from my 1HZs
#17 | |
.LOL.![]()
#18 | |
End of hijack !
#19 | |
#20 |
I checked the resistor and it seems fine. Where do you install the glow plug switch or button in the wiring.
#21 | |
Back to the glowplugs,,, The glow plug preheating timer is under the dashboard on the passengers side and the glowplug relay is on the left side of the engine bay. You will also need to check the water temperature sensor as the system will not operate if this is not working as it also controls how long the system stays heating for while the motor is running. Really not sure which system you have as there is a 12v and 24v system and I think there is another fixed delay system also. I am not aware what truck you have as I have probably missed that. cheers |
#22 |
I found the preheat box and tested it for voltage and continuity I have narrowed it down to the coolant temp sender I was told by Toyota to pull the sender out and they can get on if I get the part # off of it. I adjusted the injection pump and it seems to have better throttle response.
#23 |
It is a 24V glow. Does the full load injection screw have to be set on the bench or can it be set on running engine I adjusted this and idle screw for 700 - 750 rpm at idle now the is a little black smoke at full throttle. It runs way better. I checked the resistance and got 1.489- 1.456 k/ohms it looks to be in spec? The relays work fine too. I checked the resistance over the glow plugs too. The timer with the temp sender plugged in gives about 2-3 seconds @ 9 deg. cold start. When unplugged 5-6 seconds fires up perfectly then after a few seconds runs rough.
