Originally Posted by wombat_831
guess ill just have to save up then but wether its worth it or not is another matter as i fitted my egt sensor from ThermoGuard Instruments to the inlet manifold pipe as it exits the turbo today and all i got was 90 degrees at 9psi @ 2700rpm i can hold max boost for ages on the highway as the poor old 2h struggles to sit on 100kmh held flat even though its only done about 15000 km since rebuild mabe ill try the fuel delivery screw and see if i cant get a bit more out of her http://forum.ih8mud.com/diesel-tech-...ery-screw.html
90 degrees is about right for 9psi I have about the same, after my intercooler it's down to below 30 degrees. Ambient at around 12 will be better once I have a snorkle back on too.
But a rebuilt 2H should sit on a 100kmh in 4th without a turbo on the freeway, The Troopy's I have had with far more k's on the clock would bo that.
Rule of thumb is for evey 1 degree you can take from the intake temp you take 1 degree for you exhauste temp.
I would expect a Turbo 2H to purr all day at 100kmh after a rebuild.
Also an itercooler like mine cost me all up around $800Aus the water pump alone is a quater of the cost, I was lucky and picked my 4 cores up for $50US, cost more to ship them and thats if you can machine and weld all the parts cheaply as I could, you should still be in under $1000Aus, to have one made, well I was quoted as the first post says $3000 and that was only for 3 cores and I doubt it would have fitted or been as well made as mine, it maybe as the post says home brew but it a dam fine one
Another thing to think about, Air to Air is far cheaper and works well for road aplications such as freeway driving and towing, I built mine with more off road in mind low range, low speeds, high revs where an Air to Air is not effective. Horses for corses
