LinkBack (25) Thread Tools Display Modes
Old 05-31-08, 07:49 AM   #121 (permalink)
lshobie's Avatar
Dyno's are fun!
Louis
Check out my youtube videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 05-31-08, 10:47 AM   #122 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Luck .. nothing to do here dude .. you goes in the right way and make top upgrade in your engine .. sure the results gonna be impresive ..
keep us posted !
HJ-60 2H-T Intercooled Tencha
Old 06-04-08, 10:57 PM   #123 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
Matt.McInnes
Spent the evening calculating Turbo outlet temps for the Garrett GT3082R @ 70F/21C ambient and from what I can work out at 9psi the outlet temp should be around 180F/82C at 15psi the outlet temp rises to 227F/108C.
Well after a day on the Dyno and at 9PSI setting the fuel map and timing the inlet temp does not exceed 104F/40C
Power is 155rwKw/208rwHp@5000rpm don't have the torque numbers yet. I will hold and test at this for now as I really don't think I will need any more power and have more reliability as a result.
The ambient temp was around 52F/20C. Temp at the air filter in, was around 104F/40c it's a lot warmer under he bonnet/hood.
I have yet to get a thermocouple on pre intercooler as well as boost gauge so we can see the before and after results in black and white, but so far it looks very promising, if the inlet temps I calculated are correct then we are dropping around 76F/25C out. It would be nice to test it further by pushing the boost but for now I'm very happy where I am.
The engine temp sits on a constant 194-199F/90-93C so thats looking good too.
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 06-04-08, 11:19 PM   #124 (permalink)
Excellent to hear.
Most importantly, everything went smoothly. How nervous were you beforehand?
155kw at 5000rpm is 296Nm. But that's engine torque translated to the wheels, if you've got 35% driveline loss (that figure plucked from thin air) then you'll have 455Nm at the crank.
Some dynos are smart enough to calculate a driveline loss from coast-down. Others just throw in a rough figure. RWKW is what really matters, you've got plenty and possibly room for more.
Old 06-04-08, 11:28 PM   #125 (permalink)
Lifer with a 2F-ETI
Originally Posted by Dougal View Post
Excellent to hear.
I went home at 3000RPM on the Dyno it was jsut tooooo much.
Last 10 sec is just before I left is just wooooohoooooo, sounds a little poor from the digital camera.
Links
Mac's Space
On the rev limiter
Old 06-05-08, 07:06 AM   #126 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Congrats dude .. I would expect more powa in a real run .. with real air ( ambient ) flow into the engine bay ..
Old 06-05-08, 07:43 AM   #127 (permalink)
lshobie's Avatar
Very cool! Do you have a print out to post?
Louis
Old 06-06-08, 06:58 AM   #128 (permalink)
Lifer with a 2F-ETI
Links
Mac's Space
On the rev limiter
Old 06-06-08, 09:50 AM   #129 (permalink)
Lifer with a 2F-ETI
Excellent to hear.
I have a little more than your gestimate
642Nm @ the Rear Wheels
Links
Mac's Space
On the rev limiter
Old 06-06-08, 05:50 PM   #130 (permalink)
Awesome.
Is there a thread here for dyno charts? There should be.
What I'd really like to see is the same vehicle done on a roller dyno and then a hub dyno to see what difference the tyres make.
Old 06-07-08, 07:00 PM   #131 (permalink)
rchalmers3's Avatar
Location: Playas de Nosara, Nicoya Peninsula, Costa Rica
.........I'd really like to see is the same vehicle done on a roller dyno and then a hub dyno to see what difference the tyres make.
Why? What purpose would that serve?
Rick
rchalmers3 is offline   Reply With Quote
Old 06-07-08, 10:52 PM   #132 (permalink)
Lifer with a 2F-ETI
Tuesday I'm off to buy a second air temp sensor which Awill4x4 will tig a holder to the inlet side along with a second point next to it to check the air pressure.
This will give us hard numbers of Air Temp and Air Pressure pre and post intercooler. From these we will be able to see the pressure drop and temp drop and it's true efficiency.
The Wolf V500 has the advantage of been able to plug the lap top in and data log runs on either road or dyno. So I can recorded and review the results.
Stay tuned were not finished yet
Links
Mac's Space
On the rev limiter
Old 06-08-08, 01:31 AM   #133 (permalink)
Rick
It takes the tyres out of the equation.
Depending on the roller/tyre combination you can lose a lot of power to noise and heat which may not happen when the vehicle is driven on the road or track.
Basically change your tyres and it can make a big difference to the dyno reading. Hub packs avoid that.
Old 06-10-08, 03:40 AM   #134 (permalink)
Please excuse my behind the timeness.... but I see dyno printouts these days (and for some time) show kph (mph) readings in stead of the old fashioned rpms along the bottom. Does anybody know why this has changed... or why they don't show both readings (rpm and speed) along the bottom? Good work Matt... and as an old engineering boss of mine used to say "in god we trust... all others bring data..."
ozwallaby is offline   Reply With Quote
Old 06-10-08, 03:52 AM   #135 (permalink)
RPM and km/h are interchangable if you know all the gear ratios in-between. I suspect most dyno operators don't so that's the default.
The only vehicles I've seen dyno'd live were on hub-packs. They stuck a clamp lead on a spark plug and run the engine at 3000rpm to calibrate the dyno. Once they know the overall drive ratio it's run and plotted with wkw vs rpm.
The other advantage of hub dynos is no slippage. With a rubber wheel on rollers the actual rolling radius isn't quite your wheel radius.
Old 06-10-08, 04:02 AM   #136 (permalink)
Yes I understand the hub type dynos and I do like them more than the tyre type dynos.. as you mentioned, it takes another variable out of the calcs. I just didn't know if there was a "real" reason to change to something that I thought was quite satisfactory... ie rpm v mph .. thnks for the info
Old 06-13-08, 08:01 AM   #137 (permalink)
Lifer with a 2F-ETI
Had a run into work tonight and warmed the Turbo up frightening the living daylights out of a Ford XR6 and Commodre V8 racing each other off the lights just before I got to work.
The inter cooler when I arrived at work 2 min later was toasty warm on the intake sdie and you could keep your beer chilled on the out
Ambient temp was 5C can't wiat to get the sensors on it's looking real good.
Links
Mac's Space
On the rev limiter
Old 06-13-08, 04:18 PM   #138 (permalink)
Lifer with a 2F-ETI
All ready to tig on to the inlet to the intercooler.
The Wolf EMS's input for the external MAP sensor can be reconfigured to check air temp so on the data logging I should be able to run and record on the same graph both pre and post air temp side by side. Also the same should be possible with the MAP if I buy and external sensor. The only draw back been I can not do both air and Map at the same time, although I can do both air and one MAP.
Awill4x4
Links
Mac's Space
On the rev limiter
Old 06-13-08, 04:51 PM   #139 (permalink)
Yeah, Yeah, I get the hint Matt . As they said in the "price is right" "Matt Mcinnes come on down".
Regards Andrew.
awill4x4 is offline   Reply With Quote
Old 06-17-08, 04:12 AM   #140 (permalink)
Lifer with a 2F-ETI
Popped down to Awill4x4 today for a little Tig time.
Tks Andrew and hope you Enjoyed the ride
Now I can measure pre and post intercooler, once connected up.. Also braced the rear intercooler radiator.
Links
Mac's Space
On the rev limiter
Old 06-17-08, 08:07 AM   #141 (permalink)
Turbo Diesel Lover
Tapage's Avatar
dude ... please another shot of your engine bay please .. I should print it and show to Tencha, maybe she learn how she need to looks always ..
Old 06-17-08, 08:32 AM   #142 (permalink)
Yes, I enjoyed the ride very much Matt, it certainly surprised me just how quick it really is, it justs gets up and boogies very nicely.
It'll be great to get some accurate temp and psi figures pre and post intercooler but seeing how cool it was after you fanging it down the road a few times I think it's working very well indeed.
We've just got to convince Darren now
Regards Andrew.
Old 06-17-08, 03:05 PM   #143 (permalink)
What are those sensors and where do you get them?
Old 06-17-08, 04:13 PM   #144 (permalink)
Lifer with a 2F-ETI
The one on the left is a 1/4BSP Allen Cap grub screw which will be replaced by a 1/4bsp hose tail connected to an external 2 Bar MAP sensor.
The Wolf V500 can then data log this side by side on the same graph with the internal MAP sensor.
The second is a A/C Delco SCR-12V-3 air temp sensor, the same as the post intercooler sensor all ready fitted.
This then too can be data logged real time.
Links
Mac's Space
On the rev limiter
Old 06-25-08, 08:51 PM   #145 (permalink)
Lifer with a 2F-ETI
Ok both temp sensors are now operational but my lap tops battery is shot so I can only connect in the garage. Marin will be up this eveing after work with his for some real time data logging.
Early signs however are after a run out and back to the garage are good. The Per intercooler temp is 51c Post 26c ambient 13c
Links
Mac's Space
On the rev limiter
Old 06-26-08, 06:18 AM   5 links from elsewhere to this Post. Click to view. #146 (permalink)
Lifer with a 2F-ETI
I've been testing NOT Hooning
Pre inter cooler cruising temp is 50C/122F
Full boost rises to 82C/180F
Post inter cooler cruising temp is 25C/77F
Full boost rises to 31C/87F
Note the heat rise was only on the second run first run showed a 1C drop post intercooler. After 5 runs no post intercooler temp over 31C/87F
Ambient 12C/53.5F
Calculated Temps are spot on too
The photo of the graph below shows 2nd to 3rd to 4th
The Red line in the top graph is Pre intercooler temp, I am using the external map sensor input to read it so the scale is wrong, you have to multiply it by 1.82
Yellow is correct, Post intercooler. hope that makes sense.
Links
Mac's Space
On the rev limiter
Old 06-26-08, 08:12 AM   #147 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Damn .. you are droping huge range ºC thought your ambient temp helps a lot .. but the air that it's getting your intake it's freaking cold !
Old 06-26-08, 05:37 PM   #148 (permalink)
So your intercooler effectiveness = actual temp drop/total temp difference
Cruising.
(50-25)/(50-12)
= 66%
Giving it death.
(82-31)/(82-12)
= 73%
That's a very good result. Do you know what your cooling water temp levels out to?
Old 06-26-08, 06:30 PM   #149 (permalink)
Lifer with a 2F-ETI
Cruising.
(50-25)/(50-12)
= 66%
Giving it death.
(82-31)/(82-12)
= 73%
No idea what the intercooler water temp rises too.
Later runs saw the intake temp drop to 23C and max out at full boost 29C as the night air cooled even more. But 29C is short lived.
A water wetter should see the above improve a little too.
I think the more boost the more efficient it will become as it soaks more heat up.
Links
Mac's Space
On the rev limiter
Old 06-28-08, 05:08 PM   #150 (permalink)
Lifer with a 2F-ETI
Well just one job left to do, something that should have been thought about at the start but as we all know you always miss the simplest things
Going to drill and fit a small bleed nipple to one end of each of the end caps to remove the air from the the system this should help with the heat exchange too. Then it will be even better
The Snorkel should also see intake temps drop closer to ambient as it's dam hot under the bonnet.
Links
Mac's Space
On the rev limiter
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/178335-home-brew-intercooler.html
Posted By For Type Date
inside intercooler - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-19-09 06:23 PM
Saturn Ion Cooling System, Saturn Intermittent Wipers Stop, Saturn Ion Mpg - Demonmax This thread Refback 03-08-09 04:14 AM
Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 02-21-09 06:05 PM
inside intercooler - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 02-15-09 01:51 AM
most hp out of the 4bd - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-29-08 09:41 PM
Water to air intercooler - Miller Welding Discussion Forums This thread Refback 11-27-08 11:01 PM
fj40-2f-eti-locked-n-loaded.com Blog Archive I see the light This thread Refback 10-26-08 07:36 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 10-01-08 12:03 PM
has anyone considered - Page 9 - Saturn ION RedLine Forums This thread Refback 08-28-08 09:03 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 03:01 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 01:44 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 12:36 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 12:28 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-27-08 11:46 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-25-08 02:26 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-20-08 08:17 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-18-08 04:20 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 09:09 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 07:42 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 05:19 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 05:12 PM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 08:49 PM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 06:10 AM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 05:53 AM
has anyone considered - Page 8 - Saturn ION RedLine Forums This thread Refback 05-08-08 11:23 AM
