LinkBack (25) Thread Tools Display Modes
Old 03-01-08, 03:04 PM   #91 (permalink)
Originally Posted by matt.mcinnes View Post
His welding is second to none the guy is a genius.
I would not take my welding any where else.
Aw shucks Matt you're making me blush.
I've just welded up a big Garrett 4.5" thick cored air to air going on a big horsepower RB30 engined Commodore and that came up very nice too.
Regards Andrew.
awill4x4 is offline   Reply With Quote
Old 03-22-08, 05:48 AM   #92 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
Well DJB excelled himself again, My sliders, rock, my wide mouth winch, rocks and now the 4 way splitters for the water supply to the intercooler are space age
Also some interesting reading for Laminova all be it in a Mazda MX5
http://www.kennebell.net/techinfo/ma...no-results.pdf
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 04-08-08, 01:04 AM   #93 (permalink)
Lifer with a 2F-ETI
Intercooler is mounted just the pipe work to complete.
Links
Mac's Space
On the rev limiter
Old 04-11-08, 03:20 AM   #94 (permalink)
Lifer with a 2F-ETI
Done, just need to swap the water fittings to 90 degree ones.
Now for cooling the intercooler.
Links
Mac's Space
On the rev limiter
Old 04-11-08, 08:43 AM   #95 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Looking pretty clean .. congrats dude .. very impresive job.
HJ-60 2H-T Intercooled Tencha
Old 04-11-08, 05:13 PM   #96 (permalink)
Looks great.
But that corrugated hose from the intercooler to the throttlebody, is that needed for movement of parts?
A smooth hose would give a lot less turbulence to the flow.
Old 04-11-08, 07:51 PM   #97 (permalink)
Lifer with a 2F-ETI
Originally Posted by Dougal View Post
Looks great.
The hose is just for set up awaiting one with a custom bend in smooth silicon.
Links
Mac's Space
On the rev limiter
Old 05-03-08, 03:30 PM   #98 (permalink)
Lifer with a 2F-ETI
Wiring for the air temp sensor is done Monday will see me pick up the 90 degree hose tail water fittings water fittings.
Then all I need to do is mount the radiator, water pump and connect the lines.
Dyno is booked for the 19th May
Links
Mac's Space
On the rev limiter
Old 05-04-08, 06:52 PM   #99 (permalink)
_Mitcho_'s Avatar
hey matt
that motor is awesome, well done!!
_Mitcho_ is offline   Reply With Quote
Old 05-04-08, 09:49 PM
Otterav
This message has been deleted by brownbear. Reason: put each other on ignore lists
Old 05-05-08, 12:10 AM   #100 (permalink)
Lifer with a 2F-ETI
Looks great.
Originally Posted by Otterav View Post
I guess 99% isn't good enough for some folks, I will say NICE FRICKEN job!!!!!!! Awesome install!!!!!
eric
Dougal is right, as of today it looks like this.
Links
Mac's Space
On the rev limiter
Old 05-05-08, 10:01 AM
Otterav
Old 05-05-08, 02:21 PM
Dougal
Old 05-05-08, 04:06 PM
matt.mcinnes
Old 05-05-08, 08:52 PM
Otterav
Old 05-05-08, 09:13 PM
matt.mcinnes
Old 05-05-08, 09:33 PM
Dougal
Old 05-05-08, 09:59 PM
Otterav
Old 05-05-08, 10:16 PM
Dougal
Old 05-06-08, 01:00 AM   #101 (permalink)
Lifer with a 2F-ETI
Picked up the fittings for the inter-cooler but ran out of time today. These will replace the quick connects we used for testing.
Links
Mac's Space
On the rev limiter
Old 05-06-08, 03:12 AM   #102 (permalink)
I hope, when you do your testing, you give us a not i/c kw/nm as well as an i/c kw/nm output. Temps/pressures as well would be nice... Looks the goods Matt, keep it up
ozwallaby is offline   Reply With Quote
Old 05-06-08, 06:07 AM   #103 (permalink)
Lifer with a 2F-ETI
We will only be testing with I/C on, although it would be interesting, but @ $160 Per Hr and 5-6 hours work dynoing, time is money as they say.
But we have a very good idea of of inlet temps without an intercooler. More interesting will be the pre and post air pressure readings of my design. along with post air temp.
Links
Mac's Space
On the rev limiter
Old 05-07-08, 12:17 AM   #104 (permalink)
Hell that's nice work!
Awesome!
GM60 is offline   Reply With Quote
Old 05-07-08, 12:59 AM   #105 (permalink)
Lifer with a 2F-ETI
Tks
Fitted the hose tails today, came across a new problem the Mazda 121 radiator I picked up to cool the inter cooler, it has difficult sizes when it comes to conneting the hoses I can't buy off the roll, only lengths of a meter/yard. Hmmm
Will sleep on this problem have a few ideas, as I don't want a lot of joints. 27mm or 32mm I can buy to length, Mazda is 29mm, May get a little of both stock sizes and see if I can get away with one of them.
Nothing is ever simple
Links
Mac's Space
On the rev limiter
Old 05-07-08, 06:39 AM   #106 (permalink)
I mean test with the i/c not operating not removed... but yes I hear what you're sayin' abt the $$$$.....
Old 05-07-08, 08:01 AM   #107 (permalink)
Lifer with a 2F-ETI
With it not opperating it would still act as a heat soak until up to temp with the water pump off, so the reading would not really be valid.
Links
Mac's Space
On the rev limiter
Old 05-10-08, 05:55 PM   #108 (permalink)
Lifer with a 2F-ETI
Inter cooler cooler is coming along
Links
Mac's Space
On the rev limiter
Old 05-17-08, 03:52 PM   #109 (permalink)
Lifer with a 2F-ETI
Been a slow week or so it seems.
The intercooler is now piped all the way to the rear with the return line connected to the radiator.
The intercooler feed from the Craig David pump has been a little more fun, the pump comes with 3 alternative sizes all to big to match the Mazda 121 radiator I picked up. So I needed a machine a new aluminum stright flange to bolt on to the pump this has taken longer than expected, but we are winning and it's almost complete.
The radiator brackets fit and just need a little bracing now to stiffen them up
One down and one to go
Links
Mac's Space
On the rev limiter
Old 05-18-08, 05:25 AM   #110 (permalink)
Lifer with a 2F-ETI
Calculated the surface area of the cooling fins to be .723 Square Meters per core.
So all four cores have a combined surface area of 2.89 Square Meters.
If anyone cares to check these figures feel free, verification is always welcome.
Links
Mac's Space
On the rev limiter
Old 05-19-08, 02:57 PM   #111 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Did you know how much CFM you have in this electric fan . ? how muchs amps it need ?
Amazing job dude ..
Old 05-19-08, 03:50 PM   #112 (permalink)
Lifer with a 2F-ETI
Amazing job dude ..
No idea it's a pretty small fan and radiator out of a Mazda 121 tiny little car, amps are no issue as the fan and the Craig David pump will run off a 100 amp solid state relay like these I use for my head lights. I have a big alternator
If the radiator is not big enough to remove the heat from the inter cooler I will just go to a larger twin fan. I guess it depend how much time I spend on boost
Links
Mac's Space
On the rev limiter
Old 05-19-08, 04:56 PM   #113 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Oooooooooook .. definately no more questions in the fan section ..
Old 05-20-08, 01:01 PM   #114 (permalink)
IH8HILLS
Granite Grinder's Avatar
TLCA# 1539
Where do you find those skookum relays? 100A solid state... I like the looks of those.
GG
Phil
1977 - FJ40-V8-SM420-ARB's,SOA (Ducky)
1988 - FJ62-Belton, Warn Powerplant, (Liliana)
Granite Grinder is offline   Reply With Quote
Old 05-20-08, 01:39 PM   #115 (permalink)
canucksafari's Avatar
KG Technologies, Inc.: SSR
Nothing on price though.
John G.
Naturally Exhasperated
Join the Import Vehicle Owners Association of Canada: Fight for what is right
Old 05-21-08, 01:17 AM   #116 (permalink)
Lifer with a 2F-ETI
My intercooler cooler cools
All done and no leaks. It's running in the pic's and a lot quiter than i was expecting, very happy with the result.
Now to test the other end
Links
Mac's Space
On the rev limiter
Old 05-21-08, 06:08 AM   #117 (permalink)
lshobie's Avatar
Wow, nice set up! I doubt you would need a bigger fan though, the other glycol.air intercoolers have alot smaller rad and fan than that. You should solder those relay connections though, makes em look better
Will that rad mount be stable on a washboard road?
Louis
Check out my youtube videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 05-21-08, 10:01 AM   #118 (permalink)
Lifer with a 2F-ETI
The radiator mounts will be fine once it has a little bracing.
No Glycol in this just a rust inhibitor, Glycol is a far less efficient as a heat exchange medium than water. a necessary evil if you live in a colder climate.
Links
Mac's Space
On the rev limiter
Old 05-21-08, 10:06 AM   #119 (permalink)
lshobie's Avatar
Very impressive, well done.
Louis
Old 05-30-08, 09:51 PM   #120 (permalink)
Lifer with a 2F-ETI
Dyno is on Tuesday so time for some results for those watching and waiting tks for your patients were almost there.
Wish me Luck
Links
Mac's Space
On the rev limiter
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/178335-home-brew-intercooler.html
Posted By For Type Date
inside intercooler - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-19-09 06:23 PM
Saturn Ion Cooling System, Saturn Intermittent Wipers Stop, Saturn Ion Mpg - Demonmax This thread Refback 03-08-09 04:14 AM
Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 02-21-09 06:05 PM
inside intercooler - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 02-15-09 01:51 AM
most hp out of the 4bd - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-29-08 09:41 PM
Water to air intercooler - Miller Welding Discussion Forums This thread Refback 11-27-08 11:01 PM
fj40-2f-eti-locked-n-loaded.com Blog Archive I see the light This thread Refback 10-26-08 07:36 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 10-01-08 12:03 PM
has anyone considered - Page 9 - Saturn ION RedLine Forums This thread Refback 08-28-08 09:03 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 03:01 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 01:44 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 12:36 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 12:28 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-27-08 11:46 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-25-08 02:26 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-20-08 08:17 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-18-08 04:20 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 09:09 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 07:42 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 05:19 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 05:12 PM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 08:49 PM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 06:10 AM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 05:53 AM
has anyone considered - Page 8 - Saturn ION RedLine Forums This thread Refback 05-08-08 11:23 AM
