LinkBack (25) Thread Tools Display Modes
Old 11-22-07, 09:42 PM   #31 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
Well after a night on test for the water not a leak to be found after final assembly.
Each end cap is now sealed with an O ring and Loctite 515 flange sealant which is what the inner grove was machined in for in the end cap, the smaller outer grove that can be seen was just to mark the distance for drilling to mounting holes.
I also dropped it in to have the air flow tested today just out of curiosity results will be in tomorrow.
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 11-23-07, 08:58 PM   #32 (permalink)
Lifer with a 2F-ETI
Well the verdict is in.
Flow of an unrestricted inlet 65mm/2.5"(straight tube) 400CFM
Flow through my inlet and intercooler 390CFM 65mm/2.5"
Pressure drop 2% under vacuum, this I'm told will be less under positive pressure.
Now not understanding too much about this stuff I asked for an lay mans explanation
The reply was it flows as well as a ported and polished big block and has one of the lowest pressure drops he has ever seen in an intercooler
Links
Mac's Space
On the rev limiter
Old 11-23-07, 10:19 PM   #33 (permalink)
Flow figures are good.
But too low drag in an intercooler means you may not have enough turbulence for good heat transfer.
Hurry up with the real testing.
Old 11-23-07, 11:21 PM   #34 (permalink)
Lifer with a 2F-ETI
ll
Testing will be early next year
All the air has to pass between a 0.3mm gap over a huge surface area of 1 of 4 heat exchanger fins that are only 0.2mm thick, but I agree until in place and tested it remains an unknown quantity. But so far so good the low pressure drop means not having to run higher boost to have the same pressure at the inlet manifold, not having to run higher boost means generating less heat compressing the air, less heat, less to cool.
http://www.opcon.se/www/files/lamino...cool_21apr.pdf
Links
Mac's Space
On the rev limiter
Old 11-27-07, 01:59 PM   #35 (permalink)
Lifer with a 2F-ETI
Air Temp Sensor fitted
Links
Mac's Space
On the rev limiter
Old 11-27-07, 04:20 PM   #36 (permalink)
This job just keeps getting better.
Old 11-27-07, 07:18 PM   #37 (permalink)
Lifer with a 2F-ETI
Going to take a punt and say it will freeze Eskimos nipples
That's my $10
Links
Mac's Space
On the rev limiter
Old 11-30-07, 09:45 PM   #38 (permalink)
Lifer with a 2F-ETI
Cores Close up
Links
Mac's Space
On the rev limiter
Old 12-02-07, 09:46 PM   #39 (permalink)
Lifer with a 2F-ETI
Some of this is worth a read. They quoted me $3000 for a custom intercooler to suit my needs, hence this thread started
http://www.hi-flow.com/HPIC3.HTM
http://www.hi-flow.com/HPIC2.HTM
Links
Mac's Space
On the rev limiter
Old 12-02-07, 11:58 PM   #40 (permalink)
I've seen pictures of these for about a couple of years now. But yours is the first time I've seen someone actually make one.
I think you need to revise the title. Homebrew to me conjours up visions of almost undrinkable, foul smelling liquid. Not the piece of artwork you've got there.
$3k is about what an aluminium fab shop would need to charge for such a thing.
Old 12-03-07, 08:33 AM   #41 (permalink)
Lifer with a 2F-ETI
I found them by accident while looking on the net for someone to ceramic coat my headers, the same place did intercoolers using these cores.
Though the Laminova set up seems to use up to 4 cores but in series so each core works less efficently than the first, by the time the water has reached the 4th core it's already had to absorbe the heat from the first three.
My set up runs all 4 in parallel this however requires a bigger water pump as each core requires 20lts per min minimum. I have on order a Davies Craig EWP110 http://www.daviescraig.com.au/docume...0_Brochure.pdf
The other draw back to my set up is the number of coolant lines, though this I have a solution too I think.
My only disapointment is the lack of information I have been able to find on the net. Air to Air to me is not suitable for our application as we never achive the speeds to make use of that kind of intercooler efficiently. Water to air seems much more usable but when you start to look at what's available it's pretty limited and expencive. The ricers are well covered by Air to Air, it is at the end of the day a pretty cheap solution. Water to air requires pumps, radiators, thermo fans on top of the cost of the intercooler. The pump alone is $250, plus the cores and Aluminum say $250, welding $180 with still a radiator and thermo fan to go as well as piping. Overall I would say total cost is around $1000 by the time I'm done. Still by far cheaper than the quote for the intercooler alone though.
So this could be a fine home brew of great distinction that out shins it mass produced competitors, on the other hand it could as you say be undrinkable and foul smeeling gut rot. Time and testing will tell.
Either way I have had a ball designing this from scratch to building and soon testing it for my up coming 2F-ETI
Links
Mac's Space
On the rev limiter
Old 12-06-07, 11:12 PM   #42 (permalink)
Lifer with a 2F-ETI
Picked up 2 x 65mm o/d aluminum round bar 100mm long, this will be machined into the converter from the Davies Craig pump to the 8 lines for the intercooler as well as a feed for the Turbo cooling. Just a ruff idea off what I have planned, this will be machined in 2 parts one to fit the hose tail water fitting seen in the photo and the other half to match the Davies Craig outlets. Once both halves are complete they will be welded together by Awill4x4 and then welded to the intercooler. this means the water lines to the cooler are kept to minimum. Rather than having 8 water lines running around the engine bay. The four larger fitting will be splayed like a 4 legged stool.
Ruff drawing/idea or how my brain works lol conical design inside to help split and flow the water evenly.
Links
Mac's Space
On the rev limiter
Old 12-07-07, 09:54 AM   #43 (permalink)
nickw's Avatar
Very nice looking project. Beauty job.
A couple of questions though. (and I don't mean to sound mean).
What made you decide to go air-water-air intercooler over air to air?
When I did some looking into it, air-water-air intercoolers where only recommended for short racing applications, where ice water could be fitted, and you could bring the compressed air temp down below ambient air temp. It seemed that having the heat transfer from air to water and back to air was not efficient enough for long term applications (more than a few minutes) and couldn't cool the compresses air to ambient air temp (like and air-air can). Seems like a lot of extra work (and cost) over an air to air style of intercooler, and due to it higher complexity (for no additional gains) adds more points of failure in the system. And I see you need a flow of 80L/min. Just wondering how many liters of coolant you need in the system? And how big the rad needs to be?
Anyways, I could be completely wrong on all of the above. I am just going off what I read when I was looking at intercooling. But everything I found recommended air to air (Unless doing short races. IE. Drag racing).
Cheers, and I look forward to seeing the project progress.
I am very interested to hear the results.
N.
1988 BJ74 / Lots of goodies - Sold
1990 HDJ81 / Fully outfitted loaded beautiful truck - Rolled
1985 BJ60 / Beautiful Stock truck - Stolen
nickw is offline   Reply With Quote
Old 12-07-07, 10:53 AM   #44 (permalink)
nickw's Avatar
Hello Matt.
Was just reading the thread again and found the below comment.
Just wondering what speeds you are going that will not allow an air-air intercooler to work for you? Usually when going slow, wheeling or other, you don't need lots of power.
Even pulling a load, most trucks have plenty of power in the lower gears, its in the upper gears and the higher speeds where more power is needed. For either towing or passing power. But in this case your probably traveling at 50kph+ (and more likely 80kph), at which case, wouldn't an air to air cooler work well?
As I said above, I am still working all this out for myself.
Just curious, as to air.air, and air/water/air
Cheers,
N.
Old 12-07-07, 10:57 AM   #45 (permalink)
nickw's Avatar
And I like your idea of having one line carry the water to the intercooler at which point its split into 4, and then merged back into one, once it leaves the intercooler.
But will the center line be able to carry enough water flow to feed the 4 other lines? Would it need to be bigger?
Cheers,
N.
Old 12-07-07, 01:51 PM   #46 (permalink)
Lifer with a 2F-ETI
Cheers,
N.
Center line is for cooling the Turbo
The feed is 30mm O/D with the five fitting flowing the same way.
Links
Mac's Space
On the rev limiter
Old 12-07-07, 01:59 PM   #47 (permalink)
Lifer with a 2F-ETI
Hello Matt.
Cheers,
N.
As for what we get up too
Vic Winch Challenge 07
Links
Mac's Space
On the rev limiter
Old 12-07-07, 02:15 PM   #48 (permalink)
Lifer with a 2F-ETI
N.
Air to air tend not to work well after these situations and neither does my radiator, but I can clean my radiator if their is no intercooler in the way.
Links
Mac's Space
On the rev limiter
Old 12-07-07, 02:24 PM   #49 (permalink)
Will running the turbo coolant into your intercooler plumbing place a lot of unwanted extra heatinto it?
Most turbo water jackets are plumbed into the engine coolant.
Old 12-07-07, 02:41 PM   #50 (permalink)
nickw's Avatar
Okay, I gotcha now. Makes sense.
Slow speed, and you require every once of power you can get to keep them wheels turning and you going forward. Looks like the type of wheeling my buddies do. (only in allowed spots of course )
Mounting in the rear seems like a good idea.
Even mounting your rad in the rear seems like a good idea.
So how much coolant do you need for the system for it to work right? Also how big of rad? Having the rad in the back should add a fair bit of coolant just in the lines. Perhaps you also might want to run the lines through the inside of the vehicle, as covering them in mud, would probably only insulate them, and stop heat from escaping through the line itself. You also might want to insulate the line running to the intercooler.
Also just curious. With an overkill type water intercooler like yours, how close to ambient air temp do you think you can get?
Here is idea as well:
Depending on how long of runs your do, you might want to even consider running your intercooler through a big a big electric cooler/freezer (with icewater (or dry ice) ) or something. Have it full of ice water and put another smaller raditor in the water. That would allow you to compress the air below ambient air temp. Probably keep it as ice water for awhile if the ARB cooler is running in freezer mode. Especially if your air-rad gets the coolant to ambient air temp. Then the cooler/freezer takes it down below). Have it come cold out of the rad, then info the cooler, then out to the intercooler. Just an idea. Probably get a lot more power from that much colder air You could probably get your air sub freezing. And you could run all around higher boost as well.
Cheers,
Nick
Air to air tend not to work well after these situations and neither does my radiator.
Old 12-07-07, 02:41 PM   #51 (permalink)
Lifer with a 2F-ETI
Let me ask you this question Nick, if air to air is so good why do 99% of us use air to water to cool the engine
Yes it's cheaper and simpler but its not as efficient, drag cars are a different story they don't want to carry extra weight such as a radiator and thermo fan for cooling the intercooler, no need for such a short sprint, iced water is ideal.
Links
Mac's Space
On the rev limiter
Old 12-07-07, 02:43 PM   #52 (permalink)
Lifer with a 2F-ETI
I just need to make sure the radiator is big enough, should be no issue, I can also run the electric pump on after engine shut down to cool the Turbo
I was wondering though if the intercooler water maybe too cold for the Turbo
Links
Mac's Space
On the rev limiter
Old 12-07-07, 02:44 PM   #53 (permalink)
Former regular
Gold Boy's Avatar
TLCA# 19478
matt.mcinnes
to confirm.
basically you are keeping the turbo air cooler by keeping the turbo cooler.... by keeping the turbo coolant cooler?
BJ74 & TUFT & U-AFPT
for Okanagan-Similkameen Toyota land cruiser meetings, click here.
Gold Boy is offline   Reply With Quote
Old 12-07-07, 02:53 PM   #54 (permalink)
Lifer with a 2F-ETI
Originally Posted by Gold Boy View Post
matt.mcinnes
to confirm.
Yes
But as I posted above I do have a concern that the Intercooler water may be too cold to cool the turbo, cold to hot quickly is not a good thing some times
Links
Mac's Space
On the rev limiter
Old 12-07-07, 02:54 PM   #55 (permalink)
nickw's Avatar
to confirm.
An intercooler cools the compressed air after the turbo back down to air temp.
Compressed air = hot air. Cold air = denser air = more power.
Colder air also means you can run higher boost which = more power.
EDIT: Just noticed you are also going to cool the water lines to the turbo. as you mention above, it could crack your turbo. I wound if that might also add to much heat to the system?
Old 12-07-07, 02:57 PM   #56 (permalink)
nickw's Avatar
Many reasons we use water to cool our engines.
But I just thought when it came to intercoolers, air/air was more efficient (for more typical applications).
Almost every intercooler I have ever seen (here in North America) are air to air.
As I said, I never claimed to know everything about it. Just learning. I find it very interesting.
After learning your application, your totally right, a water intercooler is the way to go. Not trying to offend.
What do you think of the idea about running it through another rad after with ice water in an ARB freezer? Think it would be worth the gains?
Cheers,
N.
Old 12-07-07, 03:01 PM   #57 (permalink)
Former regular
Gold Boy's Avatar
TLCA# 19478
Yes
depends on how constant the temperature of the coolant is.... give her a go!
tanks nick for the confirmation.......
Old 12-07-07, 03:03 PM   #58 (permalink)
Yes
Yeah that would concern me too.
My current turbo is water jacketed. I run it without coolant lines hooked up and haven't had a problem yet. My opinion is that it's only to prevent heat-soak on a hot shutdown and my EGT gauge tells me how hot it is anyway.
3000km since the last rebuild at up to 20psi boost and no issues. Last rebuild was due to the oil feedline coming apart.
I blame Australian Made hoseclamps.
Old 12-07-07, 03:07 PM   #59 (permalink)
Former regular
Gold Boy's Avatar
TLCA# 19478
Yes
this type of intercooler system must of been demonstrated before by other folk?
Old 12-07-07, 03:07 PM   #60 (permalink)
Lifer with a 2F-ETI
Cheers,
N.
There is a chance we can pressurize these cores and run Freon in them in conjunction with an air con pump now that would be interesting.
Sorry thinking allowed
No offense taken I'm learning just as fast as your are.
Links
Mac's Space
On the rev limiter
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/178335-home-brew-intercooler.html
Posted By For Type Date
inside intercooler - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-19-09 06:23 PM
Saturn Ion Cooling System, Saturn Intermittent Wipers Stop, Saturn Ion Mpg - Demonmax This thread Refback 03-08-09 04:14 AM
Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 02-21-09 06:05 PM
inside intercooler - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 02-15-09 01:51 AM
most hp out of the 4bd - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-29-08 09:41 PM
Water to air intercooler - Miller Welding Discussion Forums This thread Refback 11-27-08 11:01 PM
fj40-2f-eti-locked-n-loaded.com Blog Archive I see the light This thread Refback 10-26-08 07:36 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 10-01-08 12:03 PM
has anyone considered - Page 9 - Saturn ION RedLine Forums This thread Refback 08-28-08 09:03 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 03:01 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 01:44 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 12:36 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-28-08 12:28 AM
Outer Limits 4x4 Board :: View topic - 3B Middy with PWR water to air intercooler set up Post #0 Refback 06-27-08 11:46 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-25-08 02:26 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-20-08 08:17 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-18-08 04:20 AM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 09:09 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 07:42 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 05:19 PM
Outer Limits 4x4 Board :: View topic - Intercooler This thread Refback 06-17-08 05:12 PM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 08:49 PM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 06:10 AM
My version of a top mount TD42 intercooler. - Page 2 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 05-22-08 05:53 AM
has anyone considered - Page 8 - Saturn ION RedLine Forums This thread Refback 05-08-08 11:23 AM
