bj60 into fj62
hello
im a new member , and i heard alot about yuor site . i have a 1982 bj60 4sp and want to transfer the engine/tranny into a 1988 fj62 auto i was wondering if the chassis dimensions are differnet. i realise i will have to you my bj 60 mounts but is the width diffrnt? what other issues will i have to face thx alot for your input neetu |
Mod in Hibernation
frames will be the same. All the mounts will be different. You will have to use all the parts from your BJ60. Mounts, crossmembers etc...
Please do a write up as you build it. Welcome to the forum. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
bj60 into fj62
thanks,
does anyone know how i can get the exact measurements for the engine and tranny mounts to be welded into my fj62 frame ? im also thinking of doind the swap myself .'cause i was quoted 3K+ any advice would be nice neetu |
__________________ "if the asparagus is over 4 inches in height then you have to go for the broccoli spring over roll with oppressive shackle reversal" - PhilC64 |
#5 | |
Diesel for blood
If you also have the 3B radiator and shroud from a BJ60 you fan will be close to central. This how I done mine and when I checked it against a factory job ,it was close to perfect You just have to make sure the gearbox and tranny from the donor are the same length overall as the one you are replacing. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#6 | |
Diesel Trucker
Assuming the 62 he is converting is an automatic, the trans cross member will not be in the right spot. He will have to use the cross member and the mounts from the 60. Get those in the right spot, then use the transmission to align the engine. |
bj60 into fj62
thx all for the tips,
where do i take the measurements so that i can get the proper location to weld the tranny mounts , because the fj62 is an auto tranny and the bj is a standard 4spd. thx all |
Free Ringtones | Mobile Phones | Cash ISA | Homeowner Loans | Loans |
