Old 08-20-07, 07:55 PM   #1
bj60 into fj62
hello
im a new member , and i heard alot about yuor site .
i have a 1982 bj60 4sp and want to transfer the engine/tranny into a 1988 fj62 auto
i was wondering if the chassis dimensions are differnet. i realise i will have to you my bj 60 mounts but is the width diffrnt?
what other issues will i have to face
thx alot for your input
neetu
neetu is offline   Reply With Quote
Old 08-23-07, 10:01 AM   #2
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
frames will be the same. All the mounts will be different. You will have to use all the parts from your BJ60. Mounts, crossmembers etc...
Please do a write up as you build it.
Welcome to the forum.
-91 FJ80, wife's ride
Old 09-24-07, 10:25 PM   #3
bj60 into fj62
thanks,
does anyone know how i can get the exact measurements for the engine and tranny mounts to be welded into my fj62 frame ?
im also thinking of doind the swap myself .'cause i was quoted 3K+
any advice would be nice
neetu
Old 09-25-07, 12:27 AM   #4
mel lowe's Avatar
http://forum.ih8mud.com/60-series-wagons/139849-bj60-fj62-turbo%3D-bjt62.html
82 Fj60 TurkeyWizz THXAL
88 BJ62 Family Truckster
http://nfcruiserheads.org/forum/index.php
mel lowe is offline   Reply With Quote
Old 09-25-07, 12:33 AM   #5
Diesel for blood
roscoFJ73's Avatar
Originally Posted by neetu View Post
thanks,
neetu
If you have the gearbox bolted to the engine and bolt the gearbox into place on the crossmember ,and then lower the engine,the engine mount frame brackets will be in the correct spot.
If you also have the 3B radiator and shroud from a BJ60 you fan will be close to central.
This how I done mine and when I checked it against a factory job ,it was close to perfect
You just have to make sure the gearbox and tranny from the donor are the same length overall as the one you are replacing.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 09-25-07, 09:34 AM   #6
Diesel Trucker
Assuming the 62 he is converting is an automatic, the trans cross member will not be in the right spot. He will have to use the cross member and the mounts from the 60. Get those in the right spot, then use the transmission to align the engine.
lynchmob is offline   Reply With Quote
Old 09-28-07, 01:16 PM   #7
bj60 into fj62
thx all for the tips,
where do i take the measurements so that i can get the proper location to weld the tranny mounts , because the fj62 is an auto tranny and the bj is a standard 4spd.
thx all
Credit Card | Advertising | Compare | Personal Loans | UK Hotels
