Old 08-05-07, 11:32 PM   #1
60 series diesel
is there a common "issue" with tranny oil or transfer case oil to drip while under load giong up hill ?
i cant seem to find the leak in my 82 bj60 4spd
id appreciate any advice.
neetu is offline   Reply With Quote
Old 08-06-07, 01:07 AM   #2
In2cruisers's Avatar
Location: Normandy Park Wa. ........now in San Diego Ca.
mine does NOT...Hj-60
1993 FZJ-80 (White) SOLD
1985 HJ-60 (Dk.Gray) Turboed 2H & H55f 5spd, OME 2.5 ... (born a FJ now a HJ)
1974 FJ-40 (Green) Restored and sweet
1987 BMW 325i e30 (Dalphin gray) my rocket
1999 Volvo v70-R (Copper) (wifes rocket)
In2cruisers is online now   Reply With Quote
Old 08-06-07, 08:07 AM   #3
Tapage's Avatar
not in mine .. determine where the drip start.
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Tapage is online now   Reply With Quote
Old 08-06-07, 10:25 AM   #4
The output shafts of my transfercase lost fluid, while turning, before they were rebuilt. it is a common issue.
I bet it only shows when you are going uphill because the fluid levels are low already.
Rigs
1986 HJ 60 5spd Con-ferr rack, Gozzard Flares, custom bumpers,
1982 BJ 60 Sold to IH8Mud member..
1983 BJ60 For Sale
1986 HJ60
Other
1984 Mercedes 300SDC, 1982 300D, 1987 300D, 1994 E420.
Icefire is online now   Reply With Quote
Old 08-06-07, 01:38 PM   #5
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
neetu, welcome the forum.
I suggest cleaning the trans/transfer case really well with degreaser. Then go for drive and check it out. Could be the output shaft seals. That is where my truck leaks.
Might be between the seams. How bad does it leak? If it is a little tiny bit and you don't have to top it up often I would live with it till you want to rebuild the cases.
-91 FJ80, wife's ride
Old 08-06-07, 05:17 PM   #6
cruiser_guy's Avatar
TLCA# 16387
It could be the tranny being over filled from the transfer. I've had that happen when the tranny/transfer seal goes bad.
It's a common '60 series thing not exclusive to diesels. You may want to search the '60 forum too.
www.wirrell.com
Old 08-06-07, 05:21 PM   #7
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
Mine does that.
I plan to "join" the filler plugs with a hose. Only because at 240K kms I highly doubt it needs a rebuild and I do not want to just do a seal job.
Although my output shaft seal on the rear is blown out. I have it sitting ready to replace.
Old 08-07-07, 06:34 AM   #8
TLCA# 16387
Yep, I've had the hose on mine for a year or so. I plan on a seal replacement in the next few months. Then the hose goes back into the tool box for next time!
www.wirrell.com
Old 08-07-07, 12:36 PM   #9
Tapage's Avatar
I bought the " kit " hose from MAF and remove the seal between .. not an easy job ( I do when change my t-case gears ) but peace of mind ..
Old 08-07-07, 02:02 PM   #10
fe sus's Avatar
t-case output seal perhaps?
  • 92 FJ80 - for sale
  • 85 FJ60 - mostly stock, dog hauler
  • 79 BMW R65 - for sale
  • 97 BMW R850R
www.rhodescreations.com
fe sus is offline   Reply With Quote
Old 08-09-07, 03:40 PM   #11
Rig of Mortis's Avatar
I've had the "hose" from filler plug to filler plug for years, untill recently, upon a rebuild of both the tranny and transfer cases.
The rear output shaft bearing was pooched which in turn tends to ovalizes the rear output seal, followed by gear oil creeping onto your rear driveshaft and spraying the underside of your truck as it rotates and/or dripping onto the ground.
The return "hose" was a great fix.
How do you know that it only does it uphill?
Rig of Mortis is offline   Reply With Quote
Old 09-28-07, 02:44 PM   #12
thx for all the input...neetu
Myspace Proxy | New York Hotels | Free Mmorpg | Free Myspace Layouts | Key West Hotels
