Location: Normandy Park Wa. ........now in San Diego Ca.
My HJ-60....She is now a vegetarian
Got her running on B99.9.... 80% cornola / oil 20% soy oil. Buying it from a local Alternitive fuel station....Diesel reciently went up to around $3.18+ a gal. And the B99 is $3.14. Lately around here, gas went down, diesel went up....go figure.
Any hoo, She runs like a top on that sh#t. Been getting mixed results with diesel arond here lately. Wish they had better standards for diesel.....but for now she'll stay a vegie burner. Cant wait to see how she runs on that stuff once I install her pace maker (TURBO) __________________ 1985 HJ-60 (Dk.Gray) Turboed 2H & H55f 5spd, OME 2.5 ... (born a FJ now a HJ) 1980 FJ-40 (Red) w/135k orig and 0 rust 1974 FJ-40 (Green) Restored and sweet ![]() 1987 BMW 325i e30 (Dalphin gray) (my rocket) 1999 Volvo v70-R (Copper) (wifes rocket)
Nice work. I did the same. Carry a spare fuel filter. My tank/lines had a lot of crap in them. The injection pump seems to dig the B99 as well!
__________________ have wrench, will travel.... '85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer '08 Tundra 5.7iForce, leveled, with 305s '06 Audi S4 |
just did the same, milage is down a bit but well worth it.
__________________ 84 bj60 02 vw tdi 66 vw window bus 77 gmc lives in the bush |
Did you guys change the rubber fuel lines? Whenever I fillup at my regular place the guy is always trying to convince me to fill with B5 saying that it won't harm the rubber fuel lines.
__________________ '89 BJ74 '85 BJ70 - Sold (Frame rotted away )
#5 | |
I've been running B20 from the Norland UP cardlock for several months now and I haven't had any issues with it yet |
Maximum Yakpower
B99 will eventually eat up your rubber parts. That is fuel lines and IP seals. It takes 6-12 months to really cause a problem. Watch for softening of the rubber. I gets squishy and starts to "weep".
I've been running B20 for a while without any problems (other than less power and fuel economy), but won't go higher until I can do a proper conversion. Unfortunately Viton and IP rebuilds are pricey. __________________ Six Sigma Black Belt in Douchebaggery Turbo Yak - 1987 F(H)J-60 12H-T, H55F, 32 x 11.5 BFG, home-built stuff, Aussie stuff, JDM stuff. Bio powered. |
#7 | |
Three years later I'm at B-10, we'll see. I have not gone back through the bad engine yet, but it did have a broken ring and rust on all 6 pistons. So, while things may be blamed on Boid., it may have nothing to do with that particular engine failure. A lot of money and hassle later, I'm slowly moving back to biod. Bob |
Bio could not have been the culprit. A broken ring and rust on all 6 pistons sounds like water got in there. Bio SURELY could have een contaminated with water, but that's not bio's fault, that's a quality control (or filter) issue.
I have been running B100 for nearly 8 months, no new issues, no apparent weeping of lines (though I am swapping to Viton soon, just because). |
I second John M Galt's question: Anyone experience a breakdown of fuel lines due to bioD?
I ran B20 and B99 in my BJ for about a year with no issues but a precautionary fuel filter change after a few tanks. I understand the theory of bioD being a solvent, but can anyone confirm the fuel lines, et al., can be dissolved by the fuel? __________________ Timothy 1989 FJ62 1985 BJ60instein (for sale )1981 BJ60 RIP (engine kindly donated to the '85 )1984 Mercedes 300SD - biodiesel |
#10 |
I remember reading a how to on this guys page and at least on a 3B engine, switching to new lines doesn't seem like a huge job.
http://inertialabs.com/BioDiesel-FuelLineReplace.htm __________________ '89 BJ74 '85 BJ70 - Sold (Frame rotted away )
#11 |
Old "rubber" will be affected by high % biodiesel, there's no room for debate on that.. The question is, what "rubber" was used in 3B and 2H motors...
I don't know either. See this: http://www.biodiesel.org/pdf_files/f...patibility.pdf And this for sourcing tubing: http://www.mcmaster.com/ (click on "tubing" (the 5th link) under the fist heading (Fittings, Pipe, Tubing and Hose). What I DO know is that when I ran Sheila on dinodiesel, the fuel pump had no leaks that I could detect. I have been running B100 for a while now and now my fuel pump is wet on the outside... My hoses look perfectly fine though. What's the fuel pump gasket made of? I suppose a rubber-like material. I might have to fab a new gasket from Viton sheet. Last edited by Tofudebeest; 07-21-07 at 09:18 PM. |
#12 |
From McMaster, to fabricate Viton gaskets:
(I am unaware of anyone making Toyota viton fuel pump gaskets--or O rings for that matter). Not to scare anyone... Rubber and Foam 42 products match your selections Shape Sheets, Bars, and Strips Backing No Backing Composition Rubber Material Viton Rubber and Foam Rubber Viton Rubber and Foam Rubber Type High-Strength Viton Rubber Durometer Hard Durometer Rating 75A Lowest Temperature Range -24° to 0° F Highest Temperature Range +351° to +400° F Temperature Range 0° to +400° F Tensile Strength Range 1001 to 2000 psi Tensile Strength 1500 psi Stretch Limit Range 101 to 150% Stretch Limit 125% Density Range 100.1 to 116 lbs./cu. ft. Density 112-114 lbs./cu. ft. Compression Recovery Good Color Black Finish Smooth on Both Sides Tolerance Standard Specifications Met American Society for Testing and Materials (ASTM) and Military Specifications (MIL) ASTM Specification ASTM D2000 HK MIL Specification MIL-R-83248A, Type 2, Class 1 Properties Oil Resistant and Abrasion Resistant and Weather Resistant and Chemical Resistant and Electrical Resistant and Flame Resistant Thickness 1/32" | 1/16" | 3/32" | 1/8" | 3/16" | 1/4" Length 6" | 12" | 24" | 36" | Cut-to-length (per foot) Width 2" | 4" | 6" | 12" | 36" These 42 products match your selections Length Width 1/32" Thickness 6" 6" 8625K11 $12.26 Each 12" 12" 8625K21 37.99 Each 24" 12" 8625K41 64.33 Each 36" 2" 8999K11 20.16 Each 36" 4" 8999K31 36.50 Each 36" 6" 8999K51 49.77 Each Cut-to-length (per foot) 36" 8625K61 90.51 per Ft. 1/16" Thickness 6" 6" 8625K12 $19.98 Each 12" 12" 8625K22 67.70 Each 24" 12" 8625K42 110.79 Each 36" 2" 8999K12 34.81 Each 36" 4" 8999K32 60.54 Each 36" 6" 8999K52 78.96 Each Cut-to-length (per foot) 36" 8625K62 137.29 per Ft. 3/32" Thickness 6" 6" 8625K13 $26.41 Each 12" 12" 8625K23 87.81 Each 24" 12" 8625K43 151.88 Each 36" 2" 8999K13 50.48 Each 36" 4" 8999K33 87.81 Each 36" 6" 8999K53 114.53 Each Cut-to-length (per foot) 36" 8625K63 199.21 per Ft. 1/8" Thickness 6" 6" 8625K14 $34.84 Each 12" 12" 8625K24 110.91 Each 24" 12" 8625K44 192.89 Each 36" 2" 8999K14 63.76 Each 36" 4" 8999K34 110.89 Each 36" 6" 8999K54 144.65 Each Cut-to-length (per foot) 36" 8625K64 235.16 per Ft. 3/16" Thickness 6" 6" 8625K15 $48.95 Each 12" 12" 8625K29 159.63 Each 24" 12" 8625K45 277.64 Each 36" 2" 8999K15 91.73 Each 36" 4" 8999K35 159.52 Each 36" 6" 8999K55 208.05 Each Cut-to-length (per foot) 36" 8625K69 362.12 per Ft. 1/4" Thickness 6" 6" 8625K16 $61.85 Each 12" 12" 8625K25 195.00 Each 24" 12" 8625K46 337.29 Each 36" 2" 8999K16 111.50 Each 36" 4" 8999K36 193.94 Each 36" 6" 8999K56 252.98 Each Cut-to-length (per foot) 36" 8625K65 439.96 per Ft. |
#13 |
I've been running B99 exclusively for 5 months. I bought the Viton lines 4 months ago but haven't actually done the conversion yet. I check my fuel lines religiously and so far haven't noticed any adverse effects at all -- nothing but good experience here with it, but then I'm probably on the short side of my rubber lines' lifespan at this point. I also change the fuel filter much more often but I'll ease up on that as my fuel system should be completely 'flushed' by now.
It all depends on the condition of your rubber fuel lines when you start running high % biodiesel. I'll post up pics of my lines when I get around to the Viton swap in the next couple of weeks, but I don't anticipate any noticeable degradation. There's no doubt the B99 will eat the rubber over time, but it's not an overnight process. I don't think I'd worry at all with B20 or less. This is just my experience so your mileage may vary. I think a huge factor is the quality of the fuel you have access to. Here in Austin biodiesel is very popular and I know the source, but on a road trip I'd probably fall back on petro diesel before going with an unknown source of biodiesel. Talk to people in your area, possibly a co-op, and get first-hand accounts. Good luck! __________________ /ongoing . Green Hornet . 1987 HJ60 + 2H + A440f . 12HT exhaust manifold + turbo assembly in progress /new . BIO Silver . 1987 FJ60 + 12HT + H55f --> ~HJ61 . daily driver Last edited by integrin; 07-23-07 at 05:03 PM. |
#14 | |
Drinking the Kool-aid
http://forum.ih8mud.com/members/zander.html A wealth of info on his site too. __________________ '88 FJ62 - 12HT conversion, OME Lift, ARB front bumper, Roof Rack '04 Prius - stock '66 Pearson Commander - a hole in the water to throw money into. __________________________________________________ ________________________________________ And we are here as on a darkling plain Swept with confused alarms of struggle and flight, Where ignorant armies clash by night. |
#15 |
Yep, zander's site is where I got the numbers for the Viton lines. He's all over this stuff.
Changing the fuel lines is even easier on the 2H and 12HT since more of the lines are steel with only 3 feet of rubber to replace. I'll post a thread when I get around to doing this. __________________ /ongoing . Green Hornet . 1987 HJ60 + 2H + A440f . 12HT exhaust manifold + turbo assembly in progress /new . BIO Silver . 1987 FJ60 + 12HT + H55f --> ~HJ61 . daily driver |
#16 |
wait...you mean you just buy some canola oil from the grocery store, add out 9LITRES!!!! of it to a 90litre tank, and presto!?
__________________ 86 HJ60 - 2.5" OME 'Heavy' lift. 33 x 12.5 Goodyear MT/Rs. Customs designed 'Rust' spots (labour of love!). |
#17 |
Maximum Yakpower
Costs more than dino or bio around here.
I have to admit that I have not seen any adverse effects from using bio in my truck. I have filled with B99 a few times. It also should be noted that since mine is a conversion, I still have the gasser fuel lines. It turns out that most of the fuel system plumbing was the same. So my lines are likely different than your anyway. I'm surprised to hear that anyone from Oregon Fuel Injection would diss bio. They should be better informed. Even Cummins has certified their engines for bio use. __________________ Six Sigma Black Belt in Douchebaggery Turbo Yak - 1987 F(H)J-60 12H-T, H55F, 32 x 11.5 BFG, home-built stuff, Aussie stuff, JDM stuff. Bio powered. |
Read Techmeme News | Loans | Buy Shares | Internet Advertising | Homeowner Loans |
