LinkBack (7) | Thread Tools | Display Modes |
#31 | |
But a value of 0 is no intercooling, a value of 1 is perfect intercooling (cooled down to turbo intake temp). I use a figure of 0.6 most of the time. Inlet air conditions are standard temperature and pressure. That's 101,300Pa pressure and 20 deg C. The temps are all changed to Kelvin, so they read 273 deg higher. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#32 | |
then the spreadsheet u send me it was 0, its because no intercooler rite? thanks ![]() and after put in all information, how to plot line to the turbo map? |
#33 | |
As for plotting the information, the spreadsheet gives the flow in all of the different units you'll expect to find. Just print out your turbo map and draw these points on it. Draw a line to connect the dots and you're sorted. For the vertical axis, PR of 2 = 15psi boost, PR of 3 = 30psi boost. __________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#34 | |
#35 |
Dougal, i send u a email which included with the map of turbo. thanks
#36 | |
Tapage, Thank you for recommending this thread. Your research about your turbo install is exactly what I am studying. Preguntas: Will you please give us an update? What have you tested or changed? Are you running the same KKK turbo and intercooler? Did you fix the waste gate and test for max boost? Results? What is your max temp now? Conditions for max? What boost numbers are you achieving at 1000, 1500 and 2000 rpm? Thank you man, it is great to have your participation on this forum. Rick |
#37 | |
1. Yes I keep the same setup, same kkk turbo and same intercooler, the only thing that I upgrade it's the BOV and more diesel. 2. I can reach a max boost 15 PSI right now .. but this it's running at 100km or more and pedal to the metal. 3. My EGT never go over 1200 not at least I've seen until now .. and that it's sun/hot/rain/night .. conditions, so no matther what I can't get enought diesel yet. 4. 10 PSI aprox @ 2000 rpm but it always depends on my overal speed .. due to my short gearing .. 5. No operative wastegate. |
#38 | ||
If you were to drive Tencha up a steep hill at 2000 rpm, would you ever see 14psi boost? Rick |
#39 | |
Build boost in a turbo engine, it's directly related with the amount of diesel that you can push in the engine and the efford that this engine are doing at specific time. It means ( and I'm 100% psitive on it ) if would be posible to me deliver much more fuel at lower rpm, I where able to make more boost sooner in my powerband .. Like iin the 1HD-T sure yes .. if I'm over 100 km/h pedal to metal .. |
#40 | |
Could there be losses of efficiency in your intake installation (or assumptions in VE) that you have not accounted for that affect the building of boost? Believe me I am interested in solving this puzzle. Si la bomba injeccion esta el limitaccion por el produccion boost, es muy importanta a mi. Rick |
#41 |
There are 2 simple issues in the boost fact.
1. Load 2. Fuel With fuel and no load .. are not really much boost that you can see in your gauge ... with load and no fuel you only going to see the amount of boost that can your turbo can build with this amount of fuel. There is a point when you overfuel your engine and there is no more power, no more boost and only fast to the sky EGT. What I've seen it's the 1HD-T IP it's pretty much more capable to alow diesel than the factory ( or at least mine ) 2H IP .. Maybe my IP it's tired and too old or simple I don't know how proper adjust the 2H IP .. My intake ( including intercooler ) are anyway the most PRO setup that you can make .. it's a cheap home made setup that function for me .. |
#42 |
So what now? Are you satisfied or will you change the pump for more fuel?
Rick |
#43 | |
Now I'm been hable to drive it WH 2500 rpm and only pushing 4 - 5 PSI that I like or drive around the city with real lower boost numbers .. that allow my engine work relax and more life expectation .. |
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/161731-about-ve-flow-rates-turbo-maps.html
| Flujo de aire y Restricción Motor 3.3lts - TwistedAndes | This thread | Refback | 07-08-08 12:16 PM | |
| Pistones forjados - Pgina 2 - TwistedAndes | This thread | Refback | 06-23-08 10:41 PM | |
| Outer Limits 4x4 Board :: View topic - Turbo the 2H | This thread | Refback | 05-08-08 01:07 AM | |
| Outer Limits 4x4 Board :: View topic - Turbo the 2H | This thread | Refback | 03-24-08 06:55 PM | |
| Pistones forjados - Pgina 2 - TwistedAndes | This thread | Refback | 03-18-08 03:43 PM | |
| Outer Limits 4x4 Board :: View topic - Turbo the 2H | This thread | Refback | 02-22-08 07:48 AM | |
| Outer Limits 4x4 Board :: View topic - Turbo the 2H | This thread | Refback | 12-24-07 03:10 PM | |
Anime Episodes | MPAA | Wire Transfer | Credit Card | Fast Loans |
