Home Forum Gallery Wiki CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > Diesel Tech and 24 volts Systems
Old 06-10-07, 03:36 PM   2 links from elsewhere to this Post. Click to view. #1
Club 4X4 Panamá
Tapage's Avatar
Garage
2H Fuel Adjust
I saw some pics for fuel adjustment in the 2H inline pump but I can recognice the adjust nut in my pump ..
Here some pics If I can get some help here to know how I can adjust my pump.
Today I take a match with Tito ( - uhuru - ) with his 1HD-T @14 PSI and the diference with my engine was very impresiove ..
I ran 1100 EGT max at 3k rpm pedal to florr .. so I want more diesel ..
At 3k RPm I'm making around 14 PSI
HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul !
Old 06-10-07, 03:37 PM   #2
Club 4X4 Panamá
Tapage's Avatar
Garage
here the pics ..
Sponsor 06-11-07, 11:07 AM
Sponsored Link
advertisement
Old 06-11-07, 11:07 AM   #3
Club 4X4 Panamá
Tapage's Avatar
Garage
Here the pic that I found here .. but the pump looks a little diference in the adjust bolt.
If someone bring me a help in this issue .. would be very apreciated ..
Old 06-11-07, 11:31 AM   #4
wesintl's Avatar
Top pic has the alt adjustement on it. The bottom pic doesn't
Same principle for adjustment though..
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
wesintl is online now   Reply With Quote
Old 06-11-07, 11:46 AM   #5
Scoot Jockey's Avatar
Tapage,
Your injector pump has the high altitude compensator (HAC) on it. It is the big cylindrical part that sits below where the adjuster screw is in the third pic. To adjust your fuel I believe you need to turn the whole HAC to adjust it. I can't see it in your pic, but originally the HAC has a wire, and a lead seal on the shaft coming out of it. If it is still there, you will have to cut it, and install a new one when you are done adjusting. The FSM breezes through this procedure (pages FU78-FU79) during re-assembly of the injector pump. Good luck!
Scoot
1983 HJ60 GX Sahara
1984 HJ47 Troop Carrier
1973 FJ55 Rusty Wagon
2003 KTM LC4 Adventure 640
Scoot Jockey is offline   Reply With Quote
Old 06-11-07, 03:07 PM   #6
Tapage, I did this a while ago on my 2H. I have always heard to screw it down for more fuel, out for less. THIS WAS NOT TRUE. Screwing it down creates less overfueling, backing it out allows for more overfueling. Try 1/2 turn and drive, 1/2 turn and drive.
have wrench, will travel....
'85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer (SOLD)
'90 FJ62 135K, OME, 4.88s, roof tent
'06 Audi S4
'09 Dodge 2500 Diesel
Winslow is offline   Reply With Quote
Old 06-12-07, 02:25 PM   #7
Club 4X4 Panamá
Tapage's Avatar
Garage
Ok .. first thanks guys ..
I'm dealing with the HAC last sat. I can turn it ( the hole cilindrical part ) easy by hand .. and I thought it was related with the fuel adjustment, only I turn it to the right and have no changes in my fueling ( at least that I can see in my pyro )
This it's the turning way for more fuel . ..?
I thought I move the entire piece .? anycase my HAC not function .. coz last time that I go over 2000 mts over the sea level have ijection issues.
Old 06-12-07, 04:22 PM   #8
wesintl's Avatar
IIRC loosen the locknut. You turn the whole housing and screw it in further on the HAC. Then tighten the locknut. minor adjustments you won't notice. I had to turn mine 4-5 full turn revolutions IIRC at 5500ft to get any noticable difference. IIRC i'm pretty close to having it screwed all they way in. To see if it's doing anything at all unscrew it most of the way and see how black she blows
My .02
Rising Sun
; Former CLCC
Old 06-12-07, 07:35 PM   #9
Club 4X4 Panamá
Tapage's Avatar
Garage
Ja .. I catch the idea .. I'm not sure about the nut but I will so something sure on that !
Old 06-16-07, 07:21 PM
Sponsored Link
advertisement
Old 06-16-07, 07:21 PM   #10
Club 4X4 Panamá
Tapage's Avatar
Garage
Well after a week finaly I got the chance to make adjustments and ride tests.
Woooooohooooooooooooooooo ! I'm Faw**** happy guys !
Now I get the power
I make a 1.5 hole turn .. ( to the left, opposite to the clock ) and voila ! have pretty much more sooner boost, making 10 PSI at 2k rpm and reaching 1200F after 22 km of full throtle at 3K rpm producing 15 PSI
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/160362-2h-fuel-adjust.html
Posted By For Type Date
Outer Limits 4x4 Board :: View topic - fuel adjustment on 2H This thread Refback 04-27-09 08:15 PM
Outer Limits 4x4 Board :: View topic - fuel adjustment on 2H This thread Refback 08-18-08 03:57 PM
