Old 05-31-07, 10:46 AM   #1 (permalink)
moondog's Avatar
Really really stupid question - checking engine oil
So when I check the oil on my HJ60 when its cold it is low - down by the low line, if I check it when it is warm it is up a couple of milimeters over the full line. Do I need to drain some of the oil out or put more in? When should I be checking it to get an accuarate reading? Sorry for the idiotic question, I just want it to be just right.
'87 HJ60 - Max
'85 FJ60 - future home of Max's drive train
moondog is offline   Reply With Quote
Old 05-31-07, 11:35 AM   #2 (permalink)
Otterav's Avatar
Hello,
Warm the oil has expanded, but most importantly the oil has aereated, causing it to expand in volume. Check the oil in accordance with your owners manual.
eric
Otterav is offline   Reply With Quote
Old 05-31-07, 03:35 PM   #3 (permalink)
RHINO's Avatar
its not THAT critical, as long as you have oil in the hi-lo range your good.
Clay
75 BDJ55- biopig
Old 05-31-07, 07:36 PM   #4 (permalink)
moondog's Avatar
Well, good to know....I think I'm kind of a hypochondriac when it comes to my landcruiser.
'87 HJ60 - Max
Old 06-01-07, 07:24 AM   #5 (permalink)
I believe engine oil should be checked when the engine is cold! The oil level should be close to the upper level mark.
Regards,
NCR
Toyota HDJ 80
Honda África Twin
Honda XR 650 R
http://ncr2006.blogspot.com/
NCR2006 is offline   Reply With Quote
Old 06-01-07, 12:03 PM   #6 (permalink)
moondog's Avatar
Having now checked it repeatedly and obsessively for the last few days, it pretty much seems to be right where it should be when it's cold and when it's hot. When I posted this though, it had sat for like a month 'cause I was out of the state and when I got back I checked the oil and it was down close to the low line. I figured since it was still within the F and L lines it would be ok to drive it to the parts store a couple of miles away to get some more oil, but by the time I got there I checked it again and it was up at the F line. (Yes, I was on level ground both times.) Since then, I've checked it every morning when its cold and at some point during the day when it's warm and its pretty much right where it should be. hmmmm..........
'87 HJ60 - Max
Old 06-01-07, 12:17 PM   #7 (permalink)
The oil is on the F mark with the engine cold AND hot???
Regards,
NCR
Toyota HDJ 80
Honda África Twin
Honda XR 650 R
Old 06-01-07, 01:46 PM   #8 (permalink)
RHINO's Avatar
yes, thats why i said its not that critical. when its cold it has been sitting, most of the oil has run down from the engine parts and back into the crankcase bringing the level UP, when its warm it has recently been run and all that "extra" oil is now up in the engine and since its warm it is expanded somewhat and the level will still read UP, give or take of course.
there is a reason you have an acceptable range on the dipstick and not a very specific mark to keep at all times.
some guys will tell you how important it is to check engine oil on a specific procedure, cold, hot whatever, but i bet i can go check the air in those guys' tires and find a couple PSI difference. if someone really wanted to argue, the anal retentive oil level on the dipstick would be the middle, not the top.
Clay
75 BDJ55- biopig
Old 06-01-07, 03:12 PM   #9 (permalink)
moondog's Avatar
yep.......changes slightly, but is within a half milimeter of the F mark in either case.
'87 HJ60 - Max
Old 06-02-07, 02:04 AM   #10 (permalink)
HDJ100L's Avatar
according to toyota delaer it is more accurate to check your oil when you start you engine in the morning until it reaches normal temp. do not rev or turn on the A/C in short dont operate anything.....turn off engine and wait for 2-3mins pull out the dip stick and wipe it clean. insert the dip stick and check for proper level.
2000 Toyota Landcruiser 100
1HD-T 147HP@0.82 Bar - SOLD
2009 Toyota Landcruiser 200
1VD-FTV 282HP V8 T/T - NEW
2009 Toyota Hi-lux 4x4
1KD-FTV 160HP - NEW
2008 Toyota Hi-ace Modelista ver.
2KD-FTV 102HP - NEW
HDJ100L is offline   Reply With Quote
Old 06-02-07, 03:03 AM   #11 (permalink)
I agree with HDJ100L. I think oil level must be checked within 1-2mins after the engine has been turned off.
This will get you a more accurate reading of how much oil is ready to be pumped back to the engine. Since the oil galley and oil filter is still primed with oil, unlike in the mornings where all the oil has drained back to the pan. But as long as oil is registering on the dip stick you are fine.
This reminds me of Toyota FSM on checking ATF vs. Honda FSM. Honda recommends normal operating temp. engine off while toyota recommends normal operating temp. engine running at P.
1984 PickUp SR5 XtraCab 4X4 22R
1985 PickUp Deluxe Std. Cab 2WD 2L-T
1997 Land Cruiser CE w/ Diff Lock
2006 LX470
2007 FJ Cruiser 4X4 AT (exported)
CivicFerio is offline   Reply With Quote
