| 1992 HDJ81 fuel not pumping Hello,
I am having troubles with my HDJ81. Long story short I disconnected the fuel line at the filter and no diesel was in the line and none came out when i cranked the engine. Is there a fuse for the fuel pump? Or a relay that I could check?
Is the pump inside the tank on these models? If so how can I access the tank? I found a small access hatch under the carpet in the cargo area but all I found was a good view of my spare tire mounted underneath!
Thanks in advance. (Also yes I there is diesel in the tank, I added 20 liters just to be sure) |
