3B starter died
So I replaced the contacts and plunger not too long ago and now it's dead. I can get it to turn over every once in a while. The 3b starter doesn't seem to crossover to anything locally in the states.
Reman didn't pull up in the Toyota system. New looks to be ~500 US. Any suggestions other than 4 wheel auto which looks to have remans or finding a local old skool shop to rebuild it? Thanks! __________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound ![]() Real Change is here --> Cato Institute |
Try www.toyotapartsales.com for a new one.
pn#: 28100-56191 it's around 400 from them. Before you order post what year and model your truck is as they have different pn for diff years. The one above is from 11/84 to 85/10. |
that's definatly the new superseed part # I need. Sorry for not posting it earlier.
Still 4 bones for a starter is hard to swallow. I'm sure I could take it to a rebuilder and get more power from the motor for less than half at least. __________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound ![]() Real Change is here --> Cato Institute |
I have a like new starter and magnetic switch assembly off a 1hd-t, 150.00.
Not sure if it would work. __________________ Come and visit us in Duncan, BC www.raddcruisers.ca --> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included --> 12HT & H55F combos available - complete & running --> in stock and ready to go. |
#5 | |
I have a 12v bj70. I appreciate the offer Rob! __________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound ![]() Real Change is here --> Cato Institute |
Just buy this and swap your nose cone onto it.
__________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
I'm guessing you guys have done that?
wes-
by far the cheapest solution is the -84 reman Toyota 2LT starter. 12v, does the job. swap nose cone to the reman unit and replace to return the core. $150 or so. 24v folks (like me) have to work with other sources. sorry, don't have number handy, look up a 1985 mini truck diesel starter. |
__________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound ![]() Real Change is here --> Cato Institute Last edited by wesintl; 05-25-07 at 10:07 PM. Reason: .. |
#10 |
Call moben motor clinic in Surrey BC. Thay have a number of cruiser heads go there to have there starters and alternators rebuilt. Thay are a full time rebuild facility and very reasonably priced.
http://mytelus.yellowpages.ca/busine...ound&pstype=si |
#11 |
Thanks Rick
I ended up getting a 2L and swapping the nose cone as you suggested. The US didn't have any so it came on the fast boat from Japan. Man is it a pita to remove/install a 3b starter in a 70. I had to pull the motor on the starter install the rest of the unit onto the bellhousing then put the starter motor on. btw the 28100-54090-84 which is a 2.5 kw gear reduction. WOW this new starter cranks this 3b over fast now. I should have bought one a while ago. __________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound ![]() Real Change is here --> Cato Institute |
#12 |
weintl,
I have replaced both batteries, all the cable collars, new ground cable and new rebuilt starter. Cranks at about 6 times a second. Must faster then it did before the rebuild. BTW my engine at times does take 10 seconds when cold to start. Even though the start/charing system is in top shape it takes a long time at times to start when cold. When warm it takes 1/2 second to start the truck. So if anyone reads this what else could be the issue? it has brand new glow plugs. |
#13 | |
Could be a number of issues; you need to provide more info.
When cold, once it starts, how does it run? Rough? Smokey? Smooth? Bad glow plugs, weak injector nozzles, incorrect inj timing, valve clearances... Quote:
__________________ 1978 FJ40 - parts vehicle - PM me 1987 HJ61 VX 5spd - loaded - daily driver 1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa |
#14 |
poor compression?
#15 |
Hey everyone,
Does anyone have the part numbers for the brushes and plunger for my 24 Volt B Starter? Thanks a bunch, it's starting to go on me :( __________________ -24 volt 1980 BJ40. -Five 24 Volt Hobbs heavy duty equipment lights. -32x11.5 GWrench AT's. |
#16 | |
#17 | |
Edit- looked again and still can find it. __________________ -24 volt 1980 BJ40. -Five 24 Volt Hobbs heavy duty equipment lights. -32x11.5 GWrench AT's. |
#18 |
I just had a local starter shop rebuild mine for $250.00 - works wonderful!
Mortgage Calculator | Online Advertising | Personal Injury Lawyer Los Angeles | Debt Help | Auto Loans |
