Few questions re BJ40 Hello All,
I have a few questions about some work I am doing on attempting to renovate a BJ40. I recently bought two which will make one fairly good one. I know that one has a B engine (from ID plate) and I am fairly sure the other has a B also.
1. The fuel filter is simply attached by a few cable ties to some of the electrical cables. Is there supposed to be a mounting bracket or frame of some kind for it?
2. How do I know if the 2nd LC has a B engine? I looked for the usual signs (as in FAQ). There's no frame number that I can find, no ID plate or VIN plate, and no engine number that I can find. There is a number printed just under the air intake on block. It is of the form 5digits-5digits. Is this a unique ID number or an engine code?
3. Is synthetic oil ok in this engine? Does it matter? A recent thread came up about loss of performance, leaks using synthetic but on a different engine type.
4. Did these machines come with sun-roof as an option? One of mine has one.
5. When I was having a look underneath I tried to twist the drive shaft from the transfer case to front wheels, also to rear wheels. There is about an eighth of a turn of play in both. Is this normal?
Apologies for all the different types of questions. I am sure that I will have many more over the next while. I had a look at search but no success. Any information is greatly appreciated.
Thank you,
Michael |
