Old 05-05-07, 11:44 AM   #1 (permalink)
Ron R's Avatar
Huh? Full Synthetic bad for diesel engine?
Spoke to a guy who makes a living of transporting strange objects.
He told me the following story
Uses 70-series LC's for this pupose. Trailers are in the 1600-4000 kg's (approx 3500 to 8500 lbs) range. Drives a total of several 100.000 k's a year (several cruisers/drivers).
Some time ago he decided to switch to full synth engine oil for one of his newer LC's after having it run-in for about 30.000 k's. Raised the oil-change intervals to 20.000 ks. After some time he found that engine performance dropped noticably around 18.000 k's. After oil-change everything was back to normal ...until 16.000 k's. Again oilchange all fine until 14.000 k. This he could compare because at that time he regularly had to do the same kind of load the same route that has a fairly steep incline at a certain point.
Not understanding this and asking around he was advised to switch back to dino and lo and behold after the second oilchange (at 10.000 k's) everything was back to normal!
Anybody ever heard a story like this. This because I have been thinking switching to full synth.
Ron R
1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500# with separate pump driven from crankshaft; home made roofrack and sliders; HST-Parabolics; Koni Heavy Track shocks; internal 120ltr aux tank.
http://www.ourwebspot.nl/English_index.html
Ron R is offline   Reply With Quote
Old 05-05-07, 01:56 PM   #2 (permalink)
83bj60's Avatar
This is worrisome, loss of power at 18,000, then 14,000, then 10,000... what engine is this 70 series running? What's its mileage? Is he burning oil? How is the injection pump? Have the injectors been serviced? What brand and grade of synthetic is he using? What are the temperature conditions?
With the kind of loads he's carrying, I find the mileage bewteen oil changes frankly excessive. That would definitely be classified under 'sever service' and require more frequent oil changes, not less...
91HDJ81VX (The Beast), 4B JDM, since Nov 06
83BJ60 (The Old Faithful), Still Running, Gone to a New Home
83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out
76FJ40 (Big Red), April 87 - July 93
83bj60 is offline   Reply With Quote
Old 05-05-07, 06:13 PM   #3 (permalink)
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
IF there is a problem that using synthetic brings to the surface, (it is VERY slick and often causes leaks in old engines) then that's a problem you NEEDED to fix in the first place. There is nothing bad about synthetic oil.... Save maybe the cost in comparrison to dyno oil. It has been being run in old and new diesel engines around here for twenty years!
2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got!
HZJ60 Guy is offline   Reply With Quote
Old 05-05-07, 10:26 PM   #4 (permalink)
20,000kms?? Whoa. That's pretty long for an oil change. I change my oil around 7,500km-8,000km and i'm running synthetic
Lantec is offline   Reply With Quote
Old 05-05-07, 11:49 PM   #5 (permalink)
I don't buy it. I've never seen a creditable study anywhere that showed a performance loss on synthetic for a modern engine. Some leaking, yes, but performance loss suggests something else is going on here.
90 VX Ltd, HDJ81 RHD, 1HD-T 4.2l turbodiesel, auto, BFG 285-75-16 AT's, 3" lift, 15mm spacers all round, OME heavy / medium springs, triple locked, JDM tube frt bumper, 3" mandrel bent exhaust, aeroturbine muffler, Safari Snorkel. SOLD - to backroads backpacker...
Martin White is offline   Reply With Quote
Old 05-05-07, 11:57 PM   #6 (permalink)
retired maths geek huh
denis's Avatar
what viscosity ?
'71MS75 5cyl crown coupe '74MS75 6cyl crown coupe '74MS75 4cyl crown coupe '75BJ40 DD '79FJ55 rostig schwein '80BJ40 never ending resto '82BJ45 project troopie 50% '83LN46 no engine '84BJ45 project troopie 50% '88LN65 getting closer '90HDJ80 the bear '92LN85 turbo ute '96LN108 rustbucket
Originally Posted by LandCruiserPhil View Post
there are a lot more single women available then nice low mileage Land Cruisers.
denis is offline   Reply With Quote
Old 05-06-07, 03:06 AM   #7 (permalink)
Ron R's Avatar
Will try to answer some of the questions, as I don't know all the details.
The engine is a HZ1, no strange things, just standard.
At the moment it has about 190.000 k's and doing well. I saw the rig myself. It looks well maintained and the engine doesn't leak at all.
Temperatures here in western Europe are in general moderate. We don't have excessive low or high temps and in this region we don't have any mountains. At best it's hilly.
The guy told me he had the IP and injectors checked because that was the first thing he thought of. Except for one of the injectors everything was fine. After repair problem persisted, then he went to dino.
I agree fully about 20.000 k's interval being to long. I would go for 7.500 k's as well. But he said he allways maintained his rigs like this and never had a problem before.
Because the story sounded strange I've put it here, but having said that, there is no reason he would lie about it. He doesn't sell any stuff to me, nor am I related to him in any way.
All I know about synthetics is that many use them. And with good results in general.
But asking around can shed some light every now and then
Ron R
