BJ addict
Pyrometer issue
Idle the needle is steady, has soon has i raise the rpm it start to freak out and when the rpm gets higher it goes vertical down and stays there.
check this video, speak for itself. http://www.ericleblanc.com/files/eri.../Pyrometer.wmv I tough the ground was bad but the light in the gage use the same screw for the ground and the light is ok. Interferance? __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 Last edited by eleblanc; 05-04-07 at 09:49 PM. |
something is fked, either your wiring or the factorys. double or triple check your end, and then call the manufacturer.
what brand is it? __________________ 83BJ60,Merkur turbo+intercooled,SOA,aussie locker Custom bumpers,,4.88's, longs and poly rears.RDB's +4runner calipers, parabolics in front, 39.5 IROK's on DC-1's 92FJ80 stock with the damage multiplied. 350 tbi, ome3" (JUST WRITTEN OFF) |
BJ addict
Autometer
__________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#4 | |
TLCA# 16387
I'd check your wiring carefully first. __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
BJ addict
I did that again and it looks fine to me. And if the wiring wouldn't be ok, i thinkg i wouldn't be getting any reading at idle but i am.
My guess is there is some kind of interferance, maybe caused by my converter. __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
BJ addict
I must add that the gauge does work fine, i went for a ride yesterday and it went up to 700 deg F. But has soon has i starte to rev the needle goes balistic.
Autometer Pyrometer / Thermocouple Issue
Please see following thread with similar sounding issue and my comments within.
http://forum.ih8mud.com/diesel-tech-24-volts-systems/150018-12-24v-converter-question.html Search is your friend... __________________ Jim BTW '77 FJ45 "Borg" Why? Resistance (to buying more Landcruisers) is futile. 12/79 BJ40 "Morph" (Undergoing severe "Alaska" rebuild) 01/82 BJ42 Stock FOR SALE See Diesel & Parts Classifieds Calgary, Alberta, Canada Rocky Mountain Land Cruiser Association Universal law of Landcruiser Ownership:"The probability of having a running truck is inversely proportional to the number of Landcruisers one owns" "The most successful people are those who are good at Plan B."(James Yorke) |
BJ addict
Thanks, that has giving me things to check. But i can rule out the converter has i am running a 40 Amp ICT.
I also notice that my needle start to do crazy thing only past 250 deg F. __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#9 | |
BJ addict
I've done a few test, here are the test and results - I hooked the gauge directly to my Mitsu Montero and it worked perfectly! - I disconnected everything out of my converter and hooked only the pyro gauge.....same problem - I even tried with a other converter...same thing. Now obviously there is something incompatible here, unless you guys have other suggestion to test. I'll wait til autometer support answers me. __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#10 |
Mine did the same thing when I installed it, but...the needle deflects to the beat of the music on my CD player : )
I only have a 20 amp converter now, waiting for the second one to come in. I'm going to use one for the gauges only, the second for stereo and other 12V loads. Will post my results... __________________ Zekester SW Ontario, Canada 12/79 BJ40, 3B, Gozzard F/G body, Herculinered, 3" lift, SS snorkle, 8274 M101 Expedition Trailer I/P, but in service 1983 BJ60, slowly whittling it down to nothing 1997 BMW 328is 1957 Porsche 356 replica I/P 1987 Donzi Hornet III |
#11 |
TLCA# 16387
You're running the pyro through the 24-12v convertor? Why not just run a 24v pyrometer? Isspro makes them.
I could see issues with different grounds between the convertor and the truck (remember the probe is on the engine so it sees that as ground too). __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
#12 | |
BJ addict
#13 |
BJ addict
Because the last this i was expecting is to have problems running a pyrometer throught a converter. When autometer reply to me i will see if they have a 24V.
__________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 Last edited by eleblanc; 05-06-07 at 07:04 AM. |
#14 |
i wonder if you have your converter set up wrong some how.
kind of like a floating neutral on a ac system. im not very familiar with converters but maybe if there is a link between the negative terminals of the 24v source and 12v output side to ground. Anyone with a little more experience with converters know what i am saying? __________________ 83BJ60,Merkur turbo+intercooled,SOA,aussie locker Custom bumpers,,4.88's, longs and poly rears.RDB's +4runner calipers, parabolics in front, 39.5 IROK's on DC-1's 92FJ80 stock with the damage multiplied. 350 tbi, ome3" (JUST WRITTEN OFF) |
#15 | |
BJ addict
Like i said i tried a other 16 amp converter here and i had the same thing. __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#16 |
do you have the grounds connected on both sides? And are you supposed to? I think there might be a grounding problem somewhere in this setup.
#17 |
BJ addict
On the converter there is two ground, each are ground to the body of the truck. The difference with my older converter is that the first one had only 3 connector so one ground only. The new one has 2.
#18 |
why not try to grond one to the body and other to the chasis/engine :?
#19 |
BJ addict
I tried that with no luck, autometer is sending me a new probe/thermocouple, even with a outside source of 12V they think the probe is bad. I'm going to re-test with a outside 12V source (my other truck) and verify again that it does work perfectly.
#20 |
Thermocouple probe check
I'd be interested in results when checking the resistance of each of the 2 probe (thermocouple) wires to its sheath out of the box. There should not be continuity to the sheath.
With the other related post, I made the presumption that the thermocouple element should be isolated from the sheath (normal for thermocouples), and when it was measured that there was continuity to the sheath, that this was the reason for the odd pyro' behaviour for the other vehicle owner. If, after installing carefully, you get continuity between sensor wires and sheath, I'll bet you will observe the same issue as before the install. It doesn't take much of a tight bend or crimp to cause an internal short to sheath. Please consider being careful and avoiding tight bends and / or excessive crimping. Thanks in advance for the results. I'm interested whether my previous remote advice previously was on the money or not. __________________ Jim BTW '77 FJ45 "Borg" Why? Resistance (to buying more Landcruisers) is futile. 12/79 BJ40 "Morph" (Undergoing severe "Alaska" rebuild) 01/82 BJ42 Stock FOR SALE See Diesel & Parts Classifieds Calgary, Alberta, Canada Rocky Mountain Land Cruiser Association Universal law of Landcruiser Ownership:"The probability of having a running truck is inversely proportional to the number of Landcruisers one owns" "The most successful people are those who are good at Plan B."(James Yorke) |
#21 |
BJ addict
I will do that when i receive it.
#22 |
BJ addict
I'm not sure what you mean by sheath (outside of the probe?), but i've check continuity, form the exhaust pipe to both wires of the thermocouple and i had continuity on both. Un fortunatly i didn't check out of the box and only once installed. But i was very carefull, there is a sleeve the probe goes in and it is fit. But i f*** the probe again, i don't see how it could stay non conductive to the motor with all that vibration from the motor even if i manage to put it in without damaging it.
Anyhow i still have the problem even after changing the probe. __________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#23 |
i still think the problem has to do with the converter, sorry if i sound like a broken record. Could you try and connect the pyrometer to one of the 12 volt batteries (specifically the battery that is directly connected to ground) temporarily to see if anything changes.
Good Luck. __________________ 83BJ60,Merkur turbo+intercooled,SOA,aussie locker Custom bumpers,,4.88's, longs and poly rears.RDB's +4runner calipers, parabolics in front, 39.5 IROK's on DC-1's 92FJ80 stock with the damage multiplied. 350 tbi, ome3" (JUST WRITTEN OFF) |
#24 | |
BJ addict
#25 |
I have had a similar problem with my 70 and it turned out to be a loose contact within my fuse block that I wired up for 12 volt. Just an Idea...
Hope this Helps -Noah __________________ 86 BJ70 Turbo/Intercooled 33x9.50 BFG MT's OME ARB Bumper - 96 FZJ80 Locked Subtank OME '851/860 305 MT's Murdered Out Tornado Alley Cruisers |
#26 | |
BJ addict
