05-03-07, 04:03 PM
What the diaphragm does...
I got a PM asking what the diaphragm does and decided to post it up for all to see. Feel free to add corrections if need be.
I should post this somewhere because it's what makes 3Bs cool.
The system is based on an injections system called the Ricardo Comet Mk IV, invented in England. Typical diesels have a big pipe going into the intake manifold and no restriction on air. The speed of the engine is controlled by injecting more or less fuel. The air/fuel ratio sorts itself out once the engine meets the speed of the operator is asking of it. With the Ricardo system, there is a butterfly or throttle at the entrance to the intake and there is a pipe in the air stream above and below it. These pipes run to each side of the diaphragm which directly connected to the fuel rail of the injector pump. When the butterfly is closed, the engine is trying to draw air in and there is a difference in the vacuum on each side of the butterfly, that difference is transferred to the diaphragm and the fuel real is shut down. The engine runs very slowly. AS the operator opens the throttle, the difference in vacuum is reduced and the fuel rail begins to open. The engine begins to accelerate. All the while the air fuel radio is optimized. Once the throttle is opened completely there is no difference in the vacuum above or below the butterfly and the diaphragm moves to its natural position, maximum fuel. The engine accelerates until the throttle is let off or the centrifugal over speed limiter pulls back on the fuel at 4250 RPM. It’s a brilliant system considering its all mechanical. Computers need not apply!
05-03-07, 04:26 PM
Mod in Hibernation
That's a very good description. I basically understood it that way.
How do you think a turbo adding pressure to the intake changes this relationship of differential? Do turbo'd 3B's de-accelerate slower or anything like that?
That's why those lines and diaphragm are soo important.
-91 FJ80, wife's ride
05-03-07, 05:15 PM
Some of the first generation Nissan GQ Patrol TD4.2s had the same set-up with an inline IP before going over to the rotary VE IP. There was recently a thread on the Aussie Patrol forum where a guy in Ireland was modding his truck for comps - part of that being a turbo. The general feeling was that it was best to go with the standard GQ manifold and a rotary pump (modded with a bigger plunger) to get the best torgue & hp. Others had tried turboing the first gen system with the inline IP and butterfly w diaphrtam set-up but were not able to get very good hp and torque results. But that is all hear say until you see the dyno results of two trucks with the two different systems.
05-03-07, 06:32 PM
"I should post this somewhere because it's what makes 3Bs cool"
H series engines have the same system my friend, it's not just a 3B thing, fine motor though it may be.
Interesting reading - I didn't know it was an English invention.
05-04-07, 10:37 AM
So the Brits CAN make something reliable :P
Pretty interesting stuff
81 BJ60 300k kms hibernating for the winter
05-04-07, 11:31 AM
Great description, except.........my feeble gray cells are still having a tough time envisioning it. Pics PLEASE!
In the Heart of the Alaska Range -
www.denalihwy.com
'80 BJ40 - the Fun One!
'72 JD 450B - the workhorse: dozer, loader, backhoe
'96 Pisten Bully 280D - Biggest and best snow groomer in Alaska
'08 F-350 CC LB - the NEW! heavy hauler
'06 TDI Golf - when the F-350's not needed
Diesels only!
05-04-07, 11:42 AM
Mod in Hibernation
Oh the Brits have great engineering.... but the Japanese just build it better.
Must be something in the production part of the manufacturing. British designs are quite good in many ways. But the Japanese just have a way of using better quality control and closer tolerances etc when they build something.
Same with American designs. The American engineers do design and invent some really good things, but the like the brits they fail in the build process.
Why is the big question..................
05-04-07, 01:29 PM
What are you talking about? They have pretty reliably been making tea for centuries.
The best British things don't involve electricity.
05-04-07, 01:41 PM
Supporting Vendor
Bruce!
While your discription of the process is great, do you think you are confusing the pre-cup invention of Sir Harry Ricardo and his role in the developement of the engine for the British Mark V tank with the process you are discribing? (among his many achievements)
http://en.wikipedia.org/wiki/Harry_Ricardo
gb
05-04-07, 01:50 PM
#10 (permalink)
Originally Posted by Greg_B
Bruce!
gb
He invented the in direct injection, for sure. I have come to believe the butterfly control was a part of it but can't seem to find it referenced anywhere.
05-04-07, 01:55 PM
#11 (permalink)
Where's mah cruzah?
Hey brownbear, this is a good addition to the FAQ...
05-04-07, 02:14 PM
#12 (permalink)
Supporting Vendor
I've look and looked too. It would be an interesting piece of trivia to confirm or deny a link between the precombustion chamber invention and the butterfly control. RM might have an idea...
gb
05-04-07, 02:43 PM
#13 (permalink)
Mod in Hibernation
Added.....thanks.
Note; anytime someone see a note worthy thread that would be good in the FAQ let me know, or Stone.
Same thing in the 70 section..... I need good threads for that FAQ.
05-05-07, 02:42 AM
#14 (permalink)
retired maths geek huh
Bruce,
I think you're mixing up the Ricardo combustion chambers and Bosch diesel injection systems
BTW pneumatic governor pumps usually don't have a centrifugal governor (a.k.a. speed limiter)
'71MS75 5cyl crown coupe '74MS75 6cyl crown coupe '74MS75 4cyl crown coupe '75BJ40 DD '79FJ55 rostig schwein '80BJ40 never ending resto '82BJ45 project troopie 50% '83LN46 no engine '84BJ45 project troopie 50% '88LN65 getting closer '90HDJ80 the bear '92LN85 turbo ute '96LN108 rustbucket
Originally Posted by LandCruiserPhil
there are a lot more single women available then nice low mileage Land Cruisers.
05-05-07, 06:43 PM
#15 (permalink)
Originally Posted by denis
Bruce,
AS I said before, I can't seem to find any documentation that the Sir Ricardo came up with the diaphragm control. It's entirely possible that I have indeed mixed that up. In the case of the 3B Denso pump. It does actually have both pneumatic control and centrifugal speed limiter.
05-05-07, 08:57 PM
#16 (permalink)
The timing of this post couldn't be better.
I just tweaked my HAC on the injection pump to lean out my 3B. According to fuel economy (and my neighbors), I was running slightly rich. The engine was just rebuilt and by the looks of the wires on the adjustment nuts, the HAC was never reset. 1/2 turn to the lean side did the trick but it had me a tad confused. I always understood (wrongly) that the operator controlled the amount of fuel entering the cylinder directly. But based on the description of the diaphram, the operator directly controls air flow via the butterfly. The pressure differential across the butterfly controls the amount of fuel by loading the diaphram. Lastly, the HAC meters the maximumm allowable fuel flow.
Is that correct?
Jeff
1981 BJ42/Factory smurf blue/PTO Ramsey
03 Volkswagon wagon TDI
Stay razor sharp with EverAfterShave!
05-06-07, 08:02 AM
#17 (permalink)
british engineering , i guess none of you are familar with lucas  .
having owned an MG midget , i can atest to the brillance of british engineering
1993 Ford F250 Ext Cab XLT Diesel 4x4
05-08-07, 08:16 AM
#18 (permalink)
Correct, with the 3B you are not directly linked to the fuel rack of the injection pump. The diaphragm controls the rack position.
Adjusting the HAC or "fuel screw" (BJ60s don't usually have a HAC in Canada) changes amount of fuel delivered right across the full range of the fuel map. The HAC is the high altitude compensator and is supposed to adjust fuel delivery dependending on elevation.
Is that correct?
Jeff
1989 BJ74 LX - Extreme Valve body, Mark's gears, factory winch, custom 3" OME lift, 24V Warn VTC Compressor
1987 HJ61 VX 5spd - loaded - daily driver
1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
1990 HZJ73 ZX - PTO winch, lockers, 68k Kms
05-08-07, 03:02 PM
#20 (permalink)
Rookie
Originally Posted by Tapage
117 bar (1700Psi) with the 2H around 200 bar (2900Psi) with the 12 Ht.
Excuse me for my rookie english speach.
05-08-07, 03:18 PM
#21 (permalink)
Rookie
The HAC is supposed to drop down fuel flow on injection pump at high altitude.
Without HAC your engine will smoke a lot at high altitude.
This system is only for non turbo toyota diesel engine.
Turbo engine are less subject to smoke at high altitube.
05-08-07, 03:56 PM
#22 (permalink)
If you are adding at turbo to a rig with a HAC you can plumb the boost into the vent of it and it works a bit like a boost compensator Not great but better than nothing.
05-08-07, 08:29 PM
#23 (permalink)
So as the diaphragm develops holes, the engine slowly goes rich as the diaphragm deflection decreases. Eventually, with enough holes, there will be no metering (or pinching) off the flow as it thinks the butterfly is wide open and you have massive black smoke.
Cool. Like I wrote earlier, very timely.
05-08-07, 11:17 PM
#24 (permalink)
that's the injector opening pressure, it goes far beyond at peak injection rate
05-09-07, 05:22 AM
#25 (permalink)
Rookie
I'have check toyota 2h/12Ht engine repair manual.
You are right  .There is nothing about pump pressure.
Only fuel quantity with pump RPM on the bench.
05-09-07, 09:15 AM
#26 (permalink)
It actually ends up blowing grey (almost blue) smoke on descents. When the engine is getting a lot of fuel but no air. The same symptoms appear when your air cleaner is plugged. I once lost my snorkel top while traveling through thick alders and started to become concerned about the smoke I saw in my mirror. I eventially clued in and found my airbox completely filled with leaves.
05-09-07, 09:38 AM
#27 (permalink)
Turbo Diesel Lover
and the rate is .. ?
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
05-09-07, 11:17 AM
#28 (permalink)
Rookie
If your air clcleaner isn't plugged. It is a problem of mixture air/fuel.
Here in France some BJ owner with inline pump had same problems.
Pretty simple, The diaphragm was cracked, so air/fuel ratio wasn't good.
