04-25-07, 05:48 AM
| | Forum Regular
Join Date: Oct 2006 Location: Bruthen, Victoria, Australia
| Glow Plug Light Doesn't Work G'day Guys,
I have a 1986 60 series with the 12ht motor. The glow-plug light on the dash board doesn't come on and then to turn off to signal that the motor is right to turn over (I sort of hold the key in the semi-on position for about 5 seconds or so). I've had the truck for about 12 months and in that time it has never worked.
Any suggestions?
Cheers,
Ben |
04-25-07, 09:41 AM
| | Forum Lifer
Join Date: Aug 2004 Location: Normandy Park Wa. ........now in San Diego Ca.
| Quote:
Any suggestions?
Cheers,
Ben | Check the fuse, bulb..........you should hear a "click" if its working anyway
__________________ 1985 HJ-60 ( Dk.Gray) Turboed 2H & H55f 5spd, OME 2.5 ... (born a FJ now a HJ)
1980 FJ-40 ( Red) w/135k orig (work in progress)
1974 FJ-40 ( Green) Restored and sweet
1987 BMW 325i e30 ( Dalphin gray) (my rocket)
1999 Volvo v70- R ( Copper) (wifes rocket) |
04-26-07, 10:40 PM
| | 250+ Club
Join Date: Sep 2006 Location: Koksilah, Vancouver Island, BC
| You won't see the light unless it's quite cold out... like hovering around 0C or lower (I don't recall the glow curve for the 12HT based on outside temps) and then it will only be on for maybe a second or so (longer if below 0C).
It it runs fine, don't sweat it. The volt gauge also offers a clue to when the glow screen is in operation. The glow light is really just your indication that it's ready to crank over... not whether the system is glowing or not.
__________________ 1989 BJ74 LX - Extreme Valve body, Mark's gears, factory winch, custom 3" OME lift, 24V Warn VTC Compressor 1987 HJ61 VX 5spd - loaded - daily driver 1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
1990 HZJ73 ZX - PTO winch, lockers, 68k Kms
Land Cruiser parts & service: www.raddcruisers.ca |
04-27-07, 10:33 AM
| | Site Addict
Join Date: Jan 2004 Location: Montréal area, Qc., Canada
| Quote:
Originally Posted by In2cruisers Check the fuse, bulb..........you should hear a "click" if its working anyway | X2. I like to see my light go ON... but I always start the truck after the "click". I don't care about the light for starting the truck.
__________________ BJ42 1982 * The Primitive Beast BJ70 1985 * The Green Machine 1992*Corolla*All-trac* Le tacot qui refuse de mourir !! Si je dois aller en enfer... ce sera en Landcruiser |
04-29-07, 03:46 AM
| | Forum Regular
| Thanks guys. I might check the bulb to be on the safe side.
Ta, Ben |
