Does anybody have any idea where to get illuminated toggle switches (24 volts) in the US? Im looking at putting some kind of light in the dash of my bj40 to know when my fog lights are on.
regards
__________________ 1975 BJ40 with 3B Diesel installed
1971 Gas to diesel conversion now sputtering!
I have Narva ones with an LED at the end......they are bloody bright though will light up the whole cab (with only one switch lit) got to annoying and disconected the light
p/n 60287BL note this is 20amp 12volt dont know what the 24 volt num is......
I'd try a truck parts supplier very common on western star trucks
__________________ Experience is something that you get just after you needed it!
It is better to ask a silly question than to explain a stupid f*** up!
Can't you just exchange the bulb for a 24V-type? Most of these switches have replace-able bulbs.
There is no problem to use a so called 12V switch in a 24V system (other than the bulb )
__________________ Ron R
1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500# with separate pump driven from crankshaft; home made roofrack and sliders; HST-Parabolics; Koni Heavy Track shocks; internal 120ltr aux tank. http://www.ourwebspot.nl/English_index.html
