Diesel 3B Question
The crankcase ventaltion pipe That always spits out a tiny bit of oil normally on to the garage floor, is there anyway to either reroute this pipe or any other ideas
Cheers Dazz |
Spit my last breath
Re:Diesel 3B Question
that's your .... sh!t i knew the pipe name, it's to do with having blowby
they can suck oil up via the hose on the rocker cover and suck this oil into the intake manifold, ... i think it could be it, or put up with a couple of drops on the ground... the hose is to stop a vacum forming in the crankcase and sucking the seals to death |
Diesel 3B Question
The Pipe going down the middle part of the Block on the right is a Breather and will drop Oil at the same time the Dip Stick gets to the high line.
Oil lands on the Slip Yoke of the Proppel Shaft. 8) Bad, You're thinking of Positive Crankcase Ventilation.
Spit my last breath
got you...
Diesel 3B Question
[quote author=Jonathan_Ferguson link=board=21;threadid=15425;start=msg145984#msg14 5984 date=1083061582]
The Pipe going down the middle part of the Block on the right is a Breather and will drop Oil at the same time the Dip Stick gets to the high line. Oil lands on the Slip Yoke of the Proppel Shaft. 8) Bad, You're thinking of Positive Crankcase Ventilation. ![]() [/quote] Yeah thats the one But how do ya fix it ![]() Please help me otherwise my wife wont let my truck sleep with her car in the garage :P
Spit my last breath
re route it with some hose to your air intake? that's what newer cars do.
The 13BT's, 12HT, 1HZ, etc all have routed crank case blowby into the air intake, to be burned. The valve covers are plumbed so the tube enters the air intake post air filter. In the turbo models, it is plumbed pre-turbo/post air filter.
I have not done this mod to any of my 3B's, however I've known of a few that have: Cut the blowby tube to a 1" nipple, and route it into the air intake tube, post filter. You could also shorten the pipe a little, and attach a double cup, one can inside the other, reversed orientation, then attached to the tube. (Poor explaination, sorry, and no pictures to help). This would catch all the oil, and also have the benefit of creating an air pocket around the end of the blowby tube if you stall in deep water. gb |
Here's a story from the farm....We had an old Cockshutt tractor that had so much blowby it sucked a litre of oil every hour and all of it was coming out that venting tube. We hooked a hose from the vent right back into the intake manifold. Problem solved and there was more power due to better compression with the oil getting in there
Geoff |
[quote author=Greg_B link=board=21;threadid=15425;start=msg146089#msg14 6089 date=1083080058]
The 13BT's, 12HT, 1HZ, etc all have routed crank case blowby into the air intake, to be burned. The valve covers are plumbed so the tube enters the air intake post air filter. In the turbo models, it is plumbed pre-turbo/post air filter. I have not done this mod to any of my 3B's, however I've known of a few that have: Cut the blowby tube to a 1" nipple, and route it into the air intake tube, post filter. You could also shorten the pipe a little, and attach a double cup, one can inside the other, reversed orientation, then attached to the tube. (Poor explaination, sorry, and no pictures to help). This would catch all the oil, and also have the benefit of creating an air pocket around the end of the blowby tube if you stall in deep water. gb [/quote] Haven't I read this some where before
#10 |
Diesel 3B Question
Thanks guys
does anyone have a pic of a 13bt showing this blow pipe. Cheers Dazz |
#11 |
#12 |
Diesel 3B Question
Another option is to attach a filter 'case' w/o element to the end or middle of the tube to catch the oil and allow ventalation. You can use an in-line filter for air lines, air tools, and compressors-I think Campshell makes some?. I did this on my 3fe'd 80 series to prevent my TPS sensor and plenum from getting gunked up from the valve cover vent hose.
#13 |
Diesel 3B Question
[quote author=fj803fe link=board=21;threadid=15425;start=msg155199#msg15 5199 date=1084369718]
Another option is to attach a filter 'case' w/o element to the end or middle of the tube to catch the oil and allow ventalation. You can use an in-line filter for air lines, air tools, and compressors-I think Campshell makes some?. I did this on my 3fe'd 80 series to prevent my TPS sensor and plenum from getting gunked up from the valve cover vent hose. [/quote] Thats a good idea.............Cheers Dazz |
#14 |
Oh, and my brother takes the credit for my air-oil-separator-with-filter-removed thing I had to once do on an old Honda Accord as the breather fed PRE air cleaner and would gunk it up in there!
Actually, this inexpensive trick does work quite well
__________________ Scott (Pskhaat) UZJ100, FZJ80 |
#15 | |
Cheers, Michael |
#16 |
Thanks mate, you raised this thread from the dead
I have recently changed my brand of oil from Penzoil to Motul on a recomendation seems to have eased the problem. Good idea running it to the chasis rails.Dazz P.S Incase you are getting confused, I used to be brock05 but can't log on under that name Last edited by bj42turbo; 09-13-05 at 03:17 AM. |
#17 |
Crankcase vent photo
http://forum.ih8mud.com/diesel-tech-24-volts-systems/39188-crankcase-vent.html post 14
Here is a pic of how i did my vent... |
#18 |
13Sep2005 (UTC +8)
Wonder if I a 14B engine will bolt right in a BJ-40? They're pretty common here in Manila on Toyota Coaster buses, and still have 3661mL displacement, and the similar to Land Cruiser Prado and Hilux diff code of A03A. I think they're selling it here for US$3,000 or less. __________________ Drexx Laggui - TLCA; 4x4PH UZJ-100; FZJ-80L; FZJ-80; HZJ-80L; LN-166 Metro Manila, Philippines Action and adventure pics! UZJ-100W; FZJ-80L; HDJ-80L specs |
#19 |
14B match fine with H42 tranny, not sure about H55F.
#20 | |
TLCA# 16387
__________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
#21 |
which imput shaft will it use?
the HZ has a different imput than the PZ which is different form the 3B which is different from the 2H... cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#22 |
I'm pretty sure that one 3B or B don't match with H55F input shaft. Not sure about 14B or PZ ( I thgought the last one is for sure diferent )
#23 |
3B,2H, 1HZ, 12HT, 13BT all came with the H55f as an option
but there are different imput shafts the 2F and the 2H and the 12HT all share the same imput shaft the 3B, 13BT share the same the 1HZ is a one off PITB cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#24 | |
now letme know .. 14B and 15B-T I thought are compatibles with H55F . ? If I buy an 1HZ or 1HD-T engine can swap it with my actual H55F ( inout shaft ? ) |
#25 | |
I am looking into the 14B and 15B engines right now and what they bolt up to. I think I am going to find that the 14 and 15 bolt up to R151's not the H55F's they are newer. I will let the group know what I find out. Cheers, Michael |
#26 |
16Sep2005 (UTC +8)
Just an FYI The 14B on Coaster buses here are mated with the M152 manual tranny.
#27 | |
