04-11-07, 12:21 PM
| | Forum Regular
| 1HD-T leaking injection pump Experts!
I have two leaks on the right side of my engine.
1. Power Steering pump resivoir - i am ordering the replacement
2. and this is the one I need help with - fuel pump. Here is the evolution:
a. in the colder mornings, the truck would not start, determined it was a fuel problem, pumped primer on the fuel filter, cruiser starts no problem. As I pump, I can hear air bubbles in the lines/filter
b. noticed liquid on the injector pump, but thought it was pwr steering fluid
c. sometimes, not all the time, when I over pump the fuel primer, i can see fuel leak from the cold start rod. Raj had mentioned once that these things were problematic.
Have not isolated the leak precisely, but can see that when I create pressure with the pump, see a fast drip from the bolt that holds the cold idle bar in, I but wanted to get a sense of how to proceed from the experts. I was thinking first thing, to disconnect the cold start function - never really needed it and replace fuel filter (i do that every 10K).. Is there a simple fix. Any schematics out there that show the exploded diagram of the pump? How do I disconnect it?
Thanks in advance for taking the time to help me out gents.
__________________ 1990 VX Limited Cruiser, 4.2 1HDT Diesel, Turbo, centre console stock fridge and icemaker, 285.75.16 and OME 2.5 Heavy lift. Racks all around.
04-11-07, 06:31 PM
| | 250+ Club
| Do a search for ACSD removal. Replace it with a blanking plate.
__________________ -Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
04-11-07, 10:54 PM
| | 250+ Club
| Quote:
Originally Posted by mac Do a search for ACSD removal. Replace it with a blanking plate. | Seconded, get rid of it. That thing is nothing but trouble. Since I removed mine, the ache in my back has gone away and I am having better luck with the girls too!!
__________________ Jonathan Colvin Galiano Island, BC
1990 HDJ81 w. OME, 35'', intercooler, safari snorkel, locked all-round, viair 450 onboard air, deer-killer bumpa + train horns, milemarker hydraulic
Mitsubishi delica for the wifee |
04-14-07, 09:05 AM
| | 250+ Club
| I also have the same leak. i think it is from my injector pump too!! I removed my acsd because they do really suck if they break!!
Raj tells me that I need my pump rebuilt.. .. should colst like $1000 or a bit more
crap, plus I have to send it to him because no-one has given me a good shop in Calgary!!
All the best,
__________________ Darren
97 FZJ80,OME J's, ARB, SLEE with Gas Carrier Swing Out, 38 Gal. Fuel Cell, Warn 8K, CDL & Pin7, 285 BGF AT's, Hella Lights, AO Roof Rack, Water On Board
1999 Ford Mustang SVT Cobra
Calgary, Ab. Canada |
04-16-07, 12:40 AM
| | Forum Regular
| Brutal. Sorry to hear that kup. I am x-ing my fingers now hoping I am not in the same boar.
G
__________________ 1990 VX Limited Cruiser, 4.2 1HDT Diesel, Turbo, centre console stock fridge and icemaker, 285.75.16 and OME 2.5 Heavy lift. Racks all around. |
02-14-08, 08:36 PM
| | Rookie
| Fuel delivery Hi, just joined from Prince George. The fuel delivery on my 1990 1HD-T is haywire. I have no idle but can start and run it if I keep the throttle feathered just right. It occasionally surges and also occasionally misses. I changed the fuel filter and if anything it got worse. As soon as it's below 1000 rpm it dies. All the linkages look okay and I don't see any loose fuel around the pump.
Any ideas.
cheers,
Bob |
02-14-08, 09:37 PM
| Quote:
Thanks in advance for taking the time to help me out gents.  |
I couldnt see the diaphram causing a leak, merely causing your engine to rev uncontrollably. |
02-15-08, 09:58 AM
| | Forum Lifer
| Welcome to MUD Bob. I suggest you start a new thread for your problems rather than tagging on to someone elses thread. On a short threads like this people miss seeing the post dates. |
02-15-08, 06:47 PM
| | Rookie
| Thanks, John. Will do. |
