84 350 chev to 96 chev 6.5 diesel in a 77fj40 conversion
I currently have a 84 350 chev motor in my 78 fj40. The rear main seal and head gaskets need to be redone. I'm wondering what type of modifications would be necessary to install 96 chev 6.5 diesel in my 78fj40. Thx
conncruiser
The engine will bolt right to the trans and the mounts should line right up but the exhaust manifolds may give you trouble. good luck
__________________ pat 79fj40 rebuild and 3B diesel conversion 85 fj60 gasser 00 Chevy 6.5 td 14' van 03 Camry 79 triumph T140 "It's a dogs life" aren't we all just dogs anyway? |
Diesel for blood
This might be of some help
http://cruisers.shoumatoffmedia.com/gm62joe.html __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
You'll probably need a diesel bell housing because sometimes the diesels starter nose is too big for the gasser bell housing. The HD truck gasser cast iron bell housings with the open botom will work too. You'll need a diesel flywheel. Your current clutch should work ok. Engine will need to mounted higher up in the engine compartment for left exh manifold clearance.
__________________ 81 HJ60 Costa Rica Cruiser 82 FJ60 Trail Rig. Convertible, 2F, H55, Toybox, SUA, 37" MTR's 83 JJ60. Daily driver, OME, 33's, 6.2 diesel, NV4500, WVO http://mysite.verizon.net/sbutman1/LC.html |
Hookahs | Debt Help | Remortgages | Mortgages | Salvage cars |
