14BT injection pump ????
I have a 14BT build just around the corner , have just bought a 14B and building it as a 14BT using turbo rods ,etc - gettn this motor real cheap as a good builder ( complete minus alt & starter ). Does anyone know if the turbo version injection pump is a rotary or an inline ? would it be possible to modify a 13BT inline pump to suit a 14BT ( if the turbo is rotary aswell ) ?
i know the natural ( non turbo ) is a rotary but not sure about the turbo version |
retired maths geek huh
you can mod a na distributor "rotary" pump into a turbo compensated pump by just swapping the top covers.
__________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
oh so the turbo version is a rotary aswell ? is the top cover the aneroid & extra Volume delivery or something ?
I am looking at possibly boring & sleeving the 14B block out to 15B size 108mm ( 14B = 102mm) if the block is thick enough around the sleeves , not sure how to get the extra delivery volume from the injection pump or if i have to find another pump more suitable ????? |
I don't know what the stock pump is, I think there was a thread here with some pics, I suspect toyota disn't bother with 2 different styles on the same generation engine though, but I could be proven wrong.
The top cover is mostly a fuel limiter that works linear with boost, the total max volume is the same adjustment on the pump except its set much higher for full boost. HTH. You could always run a non-compensated pump with a turbo, if boost is fairly constant and comes early and you don't mind a puff of black smoke when you press hard. If you are used to it you can use your right foot as a fuel(smoke) limiter like I did on my LJ70 when I threw the turbo on with the stock pump. __________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
Can you report the numbers on your 14B pump ? If it's something like VE4/12 it's pretty much as big as it gets in the distributor family but you could probably outrun it with a lot of boost, it all depends if you want 200 300 or 400 hp I guess
organising frieght for it tommorrow , so hopefully hit my area early late this week - early next week . have details then & photos galore .
I wonder if you can pull an injection pump from another motor like a 4bT cummins ,etc with an inline pump & modify it to suit . I am planning of running around 20 psi boost as will have forged pistons with slightly lower comp raito to handle it (with a pair of Garrett GT25 VNT's modded to suit ) . Really want to "HOTROD" this engine to see what it can do & for gaining the experience & knowledge for the future . Last edited by xtremitys; 03-26-07 at 01:39 AM. |
Работа в Канаде | Loans | Mobile Phones | Short Bowel Syndrome | Loans |
