Noticably louder clatter
Whenever the 3B is at the stop and the revs are around 650-700ish, if the clutch is depressed, then there is this louder clatter that comes out but goes away after i press in the clutch or blip the throttle or turn the knob to about 800rpm.
Is this supposed to be normal? It's been like this since i got the truck but didn't know if it was supposed to be like this. And would there be any harm in just idling at 800rpm? |
Mod in Hibernation
Your exhaust is touching something..... at low idle the engine shakes more, bet it is contacting something somewhere....might even be on a skid plate.
I had a bad one from a slightly bent skid plate, always there when I left the intersection. Drove me nuts. I could not find it. I finially brought it to a shop and let them look. For the longest time I thought it was the rear brakes...... Look underneath for really tight spots. Also start the truck. (BRAKES ON, WHEELS BLOCKED, IN NEUTRAL) And slid around under there and look for the sound. Have the idle really low and see if you can spot it...... __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#3 | |
Diesel for blood
Most diesels,even when new,do it to some extent. Im guessing its because the engine has no load on it ,the engine components kind of ring like a bell on each compression stroke Its like bashing a piece of steel with a hammer,but when you place our hand on it ,the noise is dampened When you change the rpm speed or add even a small load like a clutch plate scraping,its enough to dampen the sound. Certainly no harm in increasing the rpm. Make sure it is nothing loose 1st __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
You know I had the same issue with my truck. It always has idled like a SOB but one day it was 10 times louder. Come to find out my tranny skid plate was just close enough to bump the tranny at low idle
ing. It just needed a little adjustment.
How did you adjust that problem?
Mod in Hibernation
My skid plate had to be hammered out where it contacted. Once done it was great.
Hammers are the original tool!!! There is hardly anything my mini-sledge won't fix- or at least make me feel better about!
__________________ have wrench, will travel.... '85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer '08 Tundra 5.7iForce, leveled, with 305s '06 Audi S4 |
Mod in Hibernation
Yup the mini sledge is a good tool. In fact with out it the birf job would be almost impossible..
#10 |
I'm Polish-don't taser me
My truck has a constant problem with the little exhaust bracket under the manifold coming loose all the time. When it does, a clanking sound can be heard, check to see if all of your exhaust brackets are tight. Also when is the last time you adjusted your valves?
#11 |
Umm I don't know. I bought the truck from ATEB at 163k, the truck is at 170k now after its first oil change. It's done that from that start. it'll be louder clattering at low RPMs and it'll go away if I blip the throttle or make it idle faster
#12 |
Mod in Hibernation
That's why I think it is external, the engine smooths out quite a bit off idle.
If you don't know when your valves were adjusted, just plan to do it. Get your tools /gasket etc ready and do it one weekend. Lots of info on the net, fsm etc to do it yourself. Seen this on the net............ http://www.dewit.ca/archs/3B/index.html __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#13 | |
There's the shims and wrenches... would i need to replace the gaskets too? |
#14 |
Mod in Hibernation
feeler gauges and a gasket.
the rest would be normal hand tools like wrenches and sockets. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#15 | |
EDIT: I noticed today when I was checking out the clatter, it wasn't coming from any parts of the exhaust knocking against it. It seems to come from underneath the engine. It sounds identical to the diesel clatter, but just higher pitched and... annoying |
#16 | |
HTH... __________________ 91HDJ81VX (The Beast), 4B JDM, since Nov 06 83BJ60 (The Old Faithful), Still Running, Gone to a New Home 83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out 76FJ40 (Big Red), April 87 - July 93 |
#17 |
X2 The gears in the gear box chatter together when free running at idle in neutral. Nothing to worry about!
__________________ 1984 HJ60 Big Red Wagon! |
#18 |
Loans | Mortgages | Loans | Free phpBB forum | Loans |
