03-18-07, 10:47 PM
| | Forum Regular
| 2H, A440f vs H55f RPM at highway speeds I've currently got an A440f and it's really not a bad tranny (for an automatic  ) in the 2H. At 2500 RPM in 4th I'm at about 72MPH (116KPH). I'm running stock tires/suspension.
I'm almost ready to start a frame swap and am contemplating switching from the A440f to an H55f (auto to manual) at the same time. Anyone with the 2H/H55F combo have any RPM numbers for highway speeds? Or how fast are you going at 2500 RPM in 5th?
__________________ /ongoing . Green Hornet . 1987 HJ60 + 2H + A440f . 12HT exhaust manifold + turbo assembly in progress /new . BIO Silver . 1987 FJ60 + 12HT + H55f --> ~HJ61 . daily driver |
03-19-07, 09:12 AM
| | Site Addict
| Quote:
Originally Posted by integrin I've currently got an A440f and it's really not a bad tranny (for an automatic  ) in the 2H. At 2500 RPM in 4th I'm at about 72MPH (116KPH). I'm running stock tires/suspension.
I'm almost ready to start a frame swap and am contemplating switching from the A440f to an H55f (auto to manual) at the same time. Anyone with the 2H/H55F combo have any RPM numbers for highway speeds? Or how fast are you going at 2500 RPM in 5th? | about 100 KPH. for me it turns too high with 4.11 gears, and I am swapping in 3.73s.
cheers,
j
__________________ turboed 84HJ60,
in San Diego. |
03-19-07, 09:42 AM
| | Forum Lifer
| H55F have .84 5th gear ..
__________________ HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul ! Join us at our local Panamá Off Road Forum Quote:
Originally Posted by crushers if you are achieveing the max boost then it isn't the boost that is going to kill your engine... it is your right foot. | |
03-19-07, 05:34 PM
| | Forum Regular
| With 31" tires (but 1/2 worn out) I get similar numbers to your 4 speed. I was running from Seattle to Vancouver yesterday and played a bit with Speed and Rpm. From memory, 100 kph was about 2100 rpm and 120kph was around 2700 - I'll be on the highway tonight and I'll check and repost. I also only got about 18 mpg - maybe I should lean more towards the 100kmph than the 120
__________________ 1986 HJ60 5speed 24V. - OME 2.5 Heavy/Heavy, Vattiiva's, Aussielocker, more weird wiring than a boat... |
03-19-07, 08:21 PM
| | 250+ Club
| My HJ60 with H55F, 4.11s, and 33" tires does about 65-70mph/105-110kph at 2500. Maybe a hair less. I don't normally cruise at this RPM, though the motor is very quiet at 2500 with wide open throttle.
__________________ have wrench, will travel....
'85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer (SOLD)
'90 FJ62 135K, OME, 4.88s, roof tent
'06 Audi S4
'09 Dodge 2500 Diesel |
03-21-07, 09:17 PM
| | Forum Regular
| Checking again
2200 RPM 100Km/h
2500 RPM 110Km/h
2700 RPM 120Km/h
1500RPM 70Km/h
All speeds in 5th gear
Stock axles and 1/2 worn 31" tires
Hope this helps
03-21-07, 09:49 PM
| | Stand and deliver
| Quote:
I'm almost ready to start a frame swap and am contemplating switching from the A440f to an H55f (auto to manual) at the same time. Anyone with the 2H/H55F combo have any RPM numbers for highway speeds? Or how fast are you going at 2500 RPM in 5th? | I think the final drive in A440 and H55f are the same or very close.
Try these online calculators to test your speedo and tacho. http://members.optusnet.com.au/~zerosin/gearcalc.html
__________________ You re not a protected species,you re not a f****** koala bear
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
HJ61 with slidin windas  regrettfully SOLD:(
Holden Commodore V6
Honda XR650L |
03-21-07, 10:44 PM
| | Forum Regular
| Thanks, guys.
So it sounds like going from an A440f to an H55f is really more about the lower first gear than the benefit of an overdrive. I prefer MT's, and it's definitely the route I'll go when the automatic eventually goes, but I think I'll let it die with dignity after all.
Here are those gear ratios: A440f 1st2.950 2nd1.530 3rd1.000 4th0.717 R2.678 Tfr L1.959 H55f 1st4.843 2nd2.619 3rd1.516 4th1.000 5th0.845 R4.843 Tfr L2.296 And, for good measure, H42(1981+) 1st3.555 2nd2.292 3rd1.410 4th1.000 R4.271 Tfr L2.276 H41 1st4.925 2nd2.643 3rd1.519 4th1.000 R4.925 Tfr L1.992
03-22-07, 07:34 AM
| | Forum Lifer
| I never know those numbers for A440 are great in 4th .. .717 sound great !
03-22-07, 09:58 AM
#10 (permalink)
| | Forum Regular
| Yeah, I didn't realize 4th gear was that long on the A440f either. Now I want a MT with a low first gear and a 0.717 top gear....time to start looking for a 6-speed.
03-24-07, 01:45 PM
#11 (permalink)
| | Site Addict
| "I never know those numbers for A440 are great in 4th .. .717 sound great !"
That explains a lot. my wife has the A440 and I almost thought it had an overdrive gear as it seems to 'double shift' from 3rd to 4th. Also, it is an absolute dog in 4th on hills.
__________________ 87 HJ60,2 x 86 HJ60 auto,73 FJ40, 82 BJ60, 89 FJ62, 89 300TD wagon and counting... |
03-24-07, 01:54 PM
#12 (permalink)
| | Forum Regular
| Yeah, I only race people downhill with my A440. I just pretend I'm sight-seeing when I'm going up.
