Old 03-12-07, 01:26 AM   #1
hard starting HJ60
My HJ60 has become a real bear to cold start. I know that my glowplugs are shot, but I keep the truck in a heated garage. Recently I turned the fuel down to reduce black smoke, could this cause hard starting? What are the most common causes for hard start? Once warmed up it fires right up.
have wrench, will travel....
'85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer
'08 Tundra 5.7iForce, leveled, with 305s
'06 Audi S4
Winslow is offline   Reply With Quote
Old 03-12-07, 01:40 AM   #2
cody c's Avatar
Did you check the Flux Capacitors?
On my BJ60, when the glow plugs were gone it would still have a hard start in cold weather even when it was plugged in. But it would start ok if it was running recently and the motor was still hot. I would try turning the fuel up a bit and see if it makes a difference, if not replace the plugs, or replace them anyway if they are gone.
83BJ60,Merkur turbo+intercooled,SOA,aussie locker Custom bumpers,,4.88's, longs and poly rears.RDB's +4runner calipers, parabolics in front, 39.5 IROK's on DC-1's
92FJ80 stock with the damage multiplied. 350 tbi, ome3" (JUST WRITTEN OFF)
cody c is offline   Reply With Quote
Old 03-12-07, 01:59 AM   #3
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
How bout replacing them plugs? How bout turning that fuel back up. It needs fuel to start... Maybe the colder it is the more fuel is required to compress to kick off?
2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got!
HZJ60 Guy is offline   Reply With Quote
Old 03-13-07, 01:20 AM   #4
Diesel for blood
roscoFJ73's Avatar
Fix the glowplugs 1st. Even in warm climates most diesels need a few seconds of glow to start smoothly.
How long since the injectors were done?
I dont think you need to turn the fuel up,just wind up the hand throttle or make some adjustment on the idle at the pump.
If your engine has umpteen thousand klms then the compression maybe dropping off and this will make them hard to start.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Loans | Internet Advertising | Mortgages | Internet Advertising | Mortgage Calculator
