Old 03-08-07, 07:53 PM   #1
...put you in an FJ today
jsaltlick's Avatar
TLCA# 17094
Price of a 2H diesel
How much should a fully rebuilt 2H diesel engine cost? All parts included. I have the opportunity to buy one and want some input. There are 3 engines available in all different states of repair. I would have the seller rebuild one completely with Toyota parts.
How much would you pay for a completely rebuilt 2H????
1983 VJ47 Crew Cab "The Great Pumpkin"
1992 M-101
Finally I can get what I've always wanted....a used Toyota.
jsaltlick is online now   Reply With Quote
Old 03-08-07, 08:58 PM   #2
bigbrowndog's Avatar
What is your actual meaning of "fully rebuilt". This can vary greatly depending on the rebuilder and the engine needing repairs. Some may re use the pistons others will not do this also if the oil pump is making pressure before it is pulled down it is often left as is but some of these motors will be described as fully rebuilt. Toyota parts are good but usually more expensive, some after market parts are better quality and cheaper. Many variables.cheers
bigbrowndog is offline   Reply With Quote
Old 03-08-07, 09:07 PM   #3
TLCA# 30390490
That is a difficult question. I have been on the hunt for a 12HT "1st choice" then a 2H. A complete rebuild kit for a 2H from Oz is about 1K. That is only the motor parts. Injectors, pump, oil pump, h20 pump and head rebuild not included. A running 2H or even a good core from Oz before shipping is in the area of 2K "please let me know if there are others cheaper" The boat ride to Seattle is about $500.00. If you are doing a conversion? You need quite a bit more then just the motor. Used 2H motor and tranny combos from Canada seem to be 5K plus and they are 24V. I provided a complete list of what I thougnt I would need to change my 60 over. 2H about 4K and 12HT about 6K. Motor, H55F with shifter transfer, 180ishKM with good compression, air cleaner, radiatgor, frame pearches ect. That quote was from Oz.
For a complete rebuild, I have no idea?
Jim
BigGun J is offline   Reply With Quote
Old 03-09-07, 02:33 AM   #4
Garry's Avatar
I spent NZ$3700 reconditioning my 2h. Rebore, pistons, crank grind, bearings, cam grind, several valve seats & guides, built up rocker faces, new radiator core & hoses, new clutch, and reco'd injector nossels, the whole 9 yards I plan to keep driving it for a very long time Might even pop a turbo on one day or maybe not.
1984 HJ60 Big Red Wagon!
Garry is offline   Reply With Quote
Old 03-09-07, 04:32 PM   #5
Tapage's Avatar
I spend about 5K ( USD ) including labor
Injectors, piston, rings, oir pump gears, valvles, BEBS etc .. ( and clutch )
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 03-11-07, 10:06 AM   #6
hobiesbestfriend's Avatar
Well, If you wanna pay to get a new head, or repair the old one, I have an 86 HJ60 with 2H,cracked head, It's stuck in Peterborough, Ontario, but you can have the whole truck for 2k
81 BJ60 Completely Gutted, Bobbed 33"
85 Toyota 4Runner 5" Lift, 33 BFG's, OBA, Custom F/R Bumpers with Swing out Tire Carrier, Warn 8274.
Misc other stuff
hobiesbestfriend is offline   Reply With Quote
Old 03-11-07, 03:43 PM   #7
Landshark's Avatar
2H Rebuild
My rebuild was similar to the materials that Garry stated, I had about 5 new rockers the other were ok, new clutch, all Toyota parts, new pistons etc etc. No new head. Cost in BC Canada was about $6,000 parts and labour.
Nothing like the smell of Diesel in the morning!
1987 HJ60 500,000 kms
Belton Suspension
Prince Rupert, BC
Landshark is offline   Reply With Quote
Old 03-11-07, 03:51 PM   #8
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
I'd look for a 1HZ were I you. Parts availability 100%. Current engine and current technology.
2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got!
HZJ60 Guy is offline   Reply With Quote
Old 03-12-07, 09:22 AM   #9
jsaltlick's Avatar
TLCA# 17094
Great info! Would the 1HZ engine or other diesel options besides the 2H be significantly more expensive? I figured the 2H would fit with little mods and would be the easiest swap. Maybe buying a 2H from Canada would be cheaper?
1992 M-101
Old 03-12-07, 12:30 PM   #10
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
Yes a 1HZ would be more money than the 2H. It's a current engine. It would be LESS than a 1HD though.
2001 VW TDI Bora
1987 Toyota HZTJ-60
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/142127-price-2h-diesel.html
Posted By For Type Date
Untitled document This thread Refback 02-09-08 12:35 AM
Cheap Loan | Cell Phones | The eBay Song | Loans | Remortgages
