Location: Normandy Park Wa. ........now in San Diego Ca.
2H.... 24volt ....help...
I reciently did a FJ to HJ-60 swap (1986). I have three warning light slights I cant get to go out. #1 filter light #2 (!) light and #3 the battery light. Origionally all were out, then they popped on. Then about a week ago I pulled 1 battery and reinstalled it and the lights stayed out for a couple days...now back on. Someone suggested a bad or going bad Alt., but the dash shows its putting out some good power. Could it be a bad or disconnected ground somewhere? or not enough ground? Everything works great....I just cant call the job "done" till I get everything working.
Thanks __________________ 1985 HJ-60 (Dk.Gray) Turboed 2H & H55f 5spd, OME 2.5 ... (born a FJ now a HJ) 1980 FJ-40 (Red) w/135k orig and 0 rust 1974 FJ-40 (Green) Restored and sweet ![]() 1987 BMW 325i e30 (Dalphin gray) (my rocket) 1999 Volvo v70-R (Copper) (wifes rocket)
Think this is related to the parking/emergency brake.
Check for a switch near the bottom end of the handle. Light should go out when the handle is fully released. __________________ Ron R 1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500#; home made sliders; HST-Parabolic springs; Koni Heavy Track shocks. http://www.ourwebspot.nl/English_index.html |
Wery true. The (!) light comes on when the parking brake is engaged, or when you have too little brake fluid in your container (indicating leak).
I changed my temperature sending unit and all three of these lights were on for the first 5 minutes of running afterwards, then they went out.
__________________ 87 HJ60,86 HJ60 auto,73 FJ40, 82 BJ60, 89 FJ62 and counting... |
HUh??? Was this just a coincidence or did you do this on purpose?
What, let my truck run for a few minutes? (five would be an exageration I guess)
Yes, I did. Enough time to take the brake off, set the brake a couple of times, then get out and look under the hood to check anything I touched. Back in to the truck, took the brake off and the lights went out. Why? __________________ 87 HJ60,86 HJ60 auto,73 FJ40, 82 BJ60, 89 FJ62 and counting... |
#7 | |
?????? was that an answer to ..............? __________________ 1985 HJ-60 (Dk.Gray) Turboed 2H & H55f 5spd, OME 2.5 ... (born a FJ now a HJ) 1980 FJ-40 (Red) w/135k orig and 0 rust 1974 FJ-40 (Green) Restored and sweet ![]() 1987 BMW 325i e30 (Dalphin gray) (my rocket) 1999 Volvo v70-R (Copper) (wifes rocket)
#8 | ||
Did you replace it because you knew it would solve the problem or was the fact that the lights went out just a coincidence? Quote:
The little switch is only activated when things are properly set. And then the handle has to be fully released to make it work so the light goes off. If I have the handle only one or two clicks up, the light stays on. __________________ Ron R 1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500#; home made sliders; HST-Parabolic springs; Koni Heavy Track shocks. http://www.ourwebspot.nl/English_index.html |
#9 | ||
#10 |
Huh? it was my understanding the lights wouldn't go out ???
#11 |
I'm sorry to confuse you Ron.
No, the 3 lights in question were NOT on prior to changing the sending unit. Once I changed the sending unit, the lights were on and took a few minutes for them to go out. I only mention it as it may apply to in2cruisers situation, maybe not. __________________ 87 HJ60,86 HJ60 auto,73 FJ40, 82 BJ60, 89 FJ62 and counting... |
Mortgages | Bad Credit Loan | Equity Release | Property for sale in Spain | Loans |
