Old 02-25-07, 05:25 AM   #1
lshobie's Avatar
1HZ oil pressure video
Hi Guys,
Some people have asked about diesel oil pressure, so I installed a mechanical guage on my 1HZ and video taped it on my cell phone, quality is ok but you can see the operating pressures.
The engine has 4200 hours on it, my odometer is broken. At idle when warm it is steady at 27 pounds pressure, when at highway speeds it is at about 70-80 pounds.
Here is the video:
http://www.youtube.com/watch?v=k3UgaGu5MxQ
Regards,
Louis
Check out my youtube videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 02-25-07, 05:40 AM   #2
Eric Winkworth's Avatar
is oil pressure a tell tail sign of the life left in a motor? or just in the oil pump?
1986 BJ70, 24v with a 3B
Eric Winkworth is online now   Reply With Quote
Old 02-25-07, 05:49 AM   #3
Diesel for blood
roscoFJ73's Avatar
Both ,but its how it does it is the difference.
Very high oil pressure when cold that drops away to nothing 5-10 mins later can be a sign of worn main bearings.
A slow gradual loss of pressure can be the pump or the bearings but if it can hold pressure it doesn't have to be high for the engine to be safe.
My old 3F was beginning to get the former symptom.
My 1HZ was touching 80 after the rebuild I think Louis' engine reached 60 which is very respectable
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 02-25-07, 06:40 AM   #4
lshobie's Avatar
I just took note this morning when driving to work, the pressure gauge was up to 80lbs at highway speed. I didn't check it out when I started it this morning though - it was about minus 12 or so, but i think it is usually up around 40 or more when it is cold like that at idle.
That is not a rebuilt engine either - just looked after well.
Louis
Old 02-25-07, 12:49 PM   #5
Ron R's Avatar
Must be well looked after, because the engine repair manual says:
At idle RPm: 29 kPa = 0.3 kg/cm2 = 4.2 psi = 0.29 bar
at 3000 RPM or more: 245 kPa = 2.5 kg/cm2 = 35.5 psi = 2.45 bar
as minimum pressure for warm engine.
As a note: connecting a mechanical gauge to find the real pressure is *the* way to go.
Don't believe the in dash-gauge. During a trip some years ago I saw the pressure slowly degrade over three days. Where the normal indication was about three quarters of full scale it now showed hardly 1/4. Checked the oil filter, no shavings or whatever.
Got really worried and then found out it was the sender.
Put in a new sender, but never got the same (high) indication. Got used to it. AFAIK the pressure is fine.
Ron R
1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500#; home made sliders; HST-Parabolic springs; Koni Heavy Track shocks.
http://www.ourwebspot.nl/English_index.html
Ron R is offline   Reply With Quote
Old 02-25-07, 12:59 PM   #6
lshobie's Avatar
Yes, has been well looked after, I recently changed the conrod bearings and they looked very good - I just did it for the heck of it.
Louis
Old 02-25-07, 01:09 PM   #7
Ron R's Avatar
Parts must be cheap then!!
I really would't do that just for fun. []
Ron R
Old 02-25-07, 01:15 PM   #8
lshobie's Avatar
Conrod bearings cost about 80 canadian, and my labour at 2 hours - very easy to do.
Louis
Old 02-25-07, 02:32 PM   #9
83bj60's Avatar
Hi Guys,
Here is the video:
Regards,
How do I make it work if I'm on dial-up? It stutters and when I reload, it wants to download again, and I can't find a way to save it so I can view it off-line.
Dang&^#$&$%##& the connection just went down :(
OK, got it to work. I sure wish I could simply download it so that I could view it full screen instead of in a small 2 inch window.
91HDJ81VX (The Beast), 4B JDM, since Nov 06
83BJ60 (The Old Faithful), Still Running, Gone to a New Home
83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out
76FJ40 (Big Red), April 87 - July 93
83bj60 is offline   Reply With Quote
Old 02-25-07, 03:37 PM   #10
Ron R's Avatar
80 CND???????????? for all of them????????? You must be kidding!!!!
Never needed them but I guess that's what I have to pay a piece. times 6 is 480 CND = 300 euros.
Labor, I doubt they would charge me only two hours, but at approx 70 euro/hr that's 140 euro's is 224CND.
So at least 440 euro's or 600 CND. That's more than a weeks wage....
Ron R
Old 02-25-07, 07:55 PM   #11
83bj60's Avatar
The whole set of ACL bearings, reputed to be tougher than the Toyotas, can be had for as little as US$12 in Minnesota from Hastings, who distributes ACL bearings in the US. I know that from another member here who was shocked how expensive our Cannuck supplied bearings were.
As usual, price is not in any way related to quality, but to marketing deception and the number of people involved between the manufacturer and the consumer.
I just wish that member had posted an address where we could have ordered these bearings.
Chris
OK, I found the name of the member, 'danamotors' and don't know if he's still around. The post was from april 13th, 2004, and I can't tell you where he posted, possibly not on MUD, perhaps on 80's cool group.
The Hastings distributor was in Michigan, the bearings were bought approximateley 16 months before that post.
Figuring inflation, it would be surprising if the bearings had more than doubled in price between 2002 and 2007.
Now could the real 'danamotors' make himself known and join the conversation?
Old 02-26-07, 03:09 AM   #12
Ron R's Avatar
Maybe we should take this to new thread, but talking about parts costs.
I know they can differ tremendously.
Even here within, say 30 km's around. For commonly availbe parts it's even worse, looking at the dealer's.
I needed 5 sets of wheelbearings in preparing the rig for my trip to Kazakhstan last year. Went to the dealer. Asked the price and my jaw almost fell on the floor.
So I went to a shop specialised in bearings and bought the same bearings for less then half the price and maybe a better quality.
At the moment I'm in need for replacement bearings for the transfer. I ordered them in Ozi. Bought THREE bearings and some small parts, paying 110 Euro's incl shipment. That's less than 10 euro's more than I had to pay here for just ONE bearing on it's own.
So every now and then it's good to look around before buying unless you need the parts instantly.
Ron R
Old 02-26-07, 12:16 PM   #13
70sguy's Avatar
OK, I'm calling BS. We (G&S) stock ACL con rod bearings for 1HD-T/1HZ engines. We have bought ACL bearings through Hastings and now buy direct from ACL. They cost a whole pile more than $12 per set. Perhaps the low price was because 5 years ago the USD was at nearly 1.6 to the to the Canadian dollar, and worth even more yet to the dollar in AUS where ACL bearings come from. Factor in inflation and other factors over the 5 years I can see em going up.. but $12 usd, I still don't buy it. If you call ACL today, their Jobber price is just under $50 CAD for 1HD-T/1HZ bearings. Factor in shipping from the Eastern US warehouse, and if you have to ship them across border, add some rubber stamp fees, duty etc.
Sheldon
93 1HD-T powered FZJ80-Extreme valve body-Walbro-ARB- Snork-OME- SOLD!
97 FZJ80 Antique Sage 40th, bone stock. 1HD-FT 5spd conversion starting soon
VW A4 Jetta TDI
My other diesel is a Locomotive
www.gscruiserparts.com
70sguy is offline   Reply With Quote
Old 02-26-07, 12:37 PM   #14
83bj60's Avatar
I can empathize with you about the outrageous markups most dealers and parts stores apply to these things. It's always best to find suppliers with decent prices before the parts are needed, and stock up when a deal is available. I've got 16 dual element OEM filters for my HDJ81 for $160 from a Toyota dealer in Maine, four times cheaper than the dealer in Canada.
I'm still looking for the Hastings bearings at this time. I can't understand why the same set of bearings should cost 4 times more in Canada than in the US. Twice, I can see that, but four times, it's simply unacceptable.
Old 02-26-07, 01:25 PM   #15
Ron R's Avatar
Originally Posted by 70sguy View Post
OK, I'm calling BS. We (G&S) stock ACL con rod bearings for 1HD-T/1HZ engines. We have bought ACL bearings through Hastings and now buy direct from ACL. They cost a whole pile more than $12 per set. Perhaps the low price was because 5 years ago the USD was at nearly 1.6 to the to the Candadian dollar, and worth even more yet to the dollar in AUS where ACL bearings come from. Factor in inflation and other factors over the 5 years. If you call ACL today, their Jobber price is just under $50 CAD for 1HD-T/1HZ bearings. Factor in shipping from the Eastern US warehouse, and if you have to ship them across border, add some rubber stamp fees, duty etc.
Sheldon
I don't know or I'm understanding this correctly, but I think you're still talking about a 'set' and that's 6 bearings or one pair?
If it's a set of 6 it's still extremely cheap in my opinion.
Ron R
Old 02-26-07, 02:35 PM   #16
70sguy's Avatar
A set of ACL Con rod bearings for 1HD-T/1HZ consists of 12 separate halves to do all 6 of the big end con rods. So for $80cad you are set, and we include a strip of plastigauge, ya not a big bonus but it saves you having to go out and buy it.
VW A4 Jetta TDI
Old 02-26-07, 03:41 PM   #17
Tapage's Avatar
I take this image of my gauges in a long run ( this one after 4 hours running ) around 2400 rpm .. in my 2H -T
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 02-26-07, 05:21 PM   #18
Diesel for blood
roscoFJ73's Avatar
I like the Lev O Gage Probably works better than a inclinometer
33 in BFG A/T
Volvo 740 GL
Old 02-27-07, 12:38 AM   #19
tmarx's Avatar
This thread has got me wondering.I only have the OEM gauge so please bare with me.When the vehicle has reached normal operating temps the gauges indicates presure halfway up the scale @ idling and rising to about three quater(max) when driving .After reading this thread I have noticed that when cold @ idling the gauge indicates slightly above half on the scale but still rises to about the same level when driving or maybe a little less than three quarter on the scale.When normal operating temps are reached she goes back to normal.Is this due to the cold oil not having reached its optimum viscosity or should I be concerned?
Theo
105 1HZT I/C
BJ 42 LX 11/83 - 3b H55F P/S 3 wipers and slidin windas
tmarx is offline   Reply With Quote
Old 02-27-07, 12:56 AM   #20
Greg_B's Avatar
TLCA# 7091
The stock gauges seem to reflect more often then not a difference between vehicles. The only way for sure to know what pressure your needle gauge is reflecting is to hook up a mechanical gauge and get a datum. Until then, the rest is speculation.
hth's
gb
Old 02-27-07, 01:43 AM   #21
tmarx's Avatar
Ok, thanx Greg.
Theo
105 1HZT I/C
Old 02-27-07, 03:56 AM   #22
Ron R's Avatar
What happens is that when the engine is cold - and therefore the oil is cold - at idling the pressure is higher then warm.
See it as a matter of the oil not being able to flow through the oil galleries and lines as easy as when warm and 'thinner'
At idling the oilpump is delivering at it's full capacity for that RPM.
When rev's go up, at a certain pressure, the pressure regulator kicks in at a certain value. This happens because the oilpump now is able to deliver a higher pressure at a higher flowrate.
Because of this valve, the pressure will be restricted to the same value, either cold or warm.
(If you would look at a very precise pressure indicator you would find a very small difference but that's hardly noticable on your OEM-indicator)
So no, what you see is quite normal. You should get worried when you don't see this behaviour anymore
Ron R
Old 02-27-07, 05:06 AM   #23
tmarx's Avatar
Thanx Ron, makes sense
Theo
105 1HZT I/C
