Old 02-20-07, 11:00 AM   #1
FJ60 radiator in hj60?
My HJ60 radiator has seen better days. I have two fj60 radiators, one is a reman original, the other an aluminium job from Man-a-fre. Will either of these work in my HJ? Can I retain stock hangers and shroud? Thanks.
have wrench, will travel....
'85 FJ60 ramjet 350, atlas 3.8, NV4500, Dana60s, 39.5" Swampers,hyrdo steer
'08 Tundra 5.7iForce, leveled, with 305s
'06 Audi S4
Winslow is offline   Reply With Quote
Old 02-20-07, 12:58 PM   #2
Maximum Yakpower
Mountain Goat's Avatar
I can't answer your question directly, but I did install a HJ-60 rad in a FJ-60. It bolts right in. The only possible problem is the right hand vs. left hand drive issue. The rad fittings will be mirrored.
Six Sigma Black Belt in Douchebaggery
Turbo Yak - 1987 F(H)J-60 12H-T, H55F, 32 x 11.5 BFG, home-built stuff, Aussie stuff, JDM stuff. Bio powered.
Mountain Goat is offline   Reply With Quote
Old 02-20-07, 08:56 PM   #3
In2cruisers's Avatar
Location: Normandy Park Wa. ........now in San Diego Ca.
Im running a Fj rad. in my Hj....got to find a good and cheap rad shop to make it worth while.
Need to swap neck, drain and bib placements.....and Fj is a tad smaller in volume....need 45 deg bib to clear below
1985 HJ-60 (Dk.Gray) Turboed 2H & H55f 5spd, OME 2.5 ... (born a FJ now a HJ)
1980 FJ-40 (Red) w/135k orig and 0 rust
1974 FJ-40 (Green) Restored and sweet
1987 BMW 325i e30 (Dalphin gray) (my rocket)
1999 Volvo v70-R (Copper) (wifes rocket)
In2cruisers is offline   Reply With Quote
Old 02-22-07, 03:22 PM   #4
Tapage's Avatar
The only issue in the F and H rad are the inlet ( upside ) are in diferent side. It means longer host .. but no other issue ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 02-22-07, 06:12 PM   #5
I don't think it is worth it. they are substantially different, as in2cruisers mentioned.
it will bolt into the same brackets though, so the outside dimensions are the same.
j
turboed 84HJ60,
in San Diego.
Jan-78FJ40 is online now   Reply With Quote
Libros más vendidos | Credit Cards | Virtual pets | Advertising | 3dge Viral Emails
