Old 02-17-07, 06:58 AM   #1
Red face Power Steering Pump Compatibility
Looks like the ps pump on my BJ60 is just about dead. Stiff and choppy steering at low speed, fluid is up to normal. NAPA only lists a unit for the gas engine. Will the gas model fit on my 3B? Maybe someone has a part number?
Thanks for any help,
84BJ60 229 km
duckling is offline   Reply With Quote
Old 02-17-07, 07:17 AM   #2
i have a good used pump if your interested
$90 plus the ride
Best regards
Gord
exmodlad is offline   Reply With Quote
Old 02-18-07, 02:07 AM   #3
Garry's Avatar
Have you checked the drive belt, or changed the fluid? Also there is sometimes a filter gauze in the reservoir that can become blocked. If the pump isn't leaking then it is probably still ok.
1984 HJ60 Big Red Wagon!
Garry is offline   Reply With Quote
Old 02-19-07, 01:48 PM   #4
Belt is tight. Have never changed the fluid. Does it make that much difference? How do I get to the filter? Does the resevoir have to come off?
84BJ60 229km
Old 02-19-07, 01:49 PM   #5
Oh yeah, pump is not leaking.
Old 02-19-07, 02:02 PM   #6
Garry's Avatar
There's a good chance the fluid is original from the factory. Changing it may be a cheap fix to your problem If your reservoir is mounted remote from the pump, then pull it out and give it a good rince with cleaning solvent, and blow dry with compressed air. If the reservoir is mounted directly onto the pump, I would leave it alone (braking the seal may cause leaks). Change the fluid, I'm sure that will help
Old 02-19-07, 02:07 PM   #7
Not clear from the factory manual if I need to run the engine to drain the fluid or not. This is starting to sound like a stupid question…
Old 02-19-07, 02:21 PM   #8
Garry's Avatar
Raise the front so that both wheels spin freely. Remove the return hose from the reservoir and place in a suitable container. (you may need help for this) Then, with the motor not running, turn the steering wheel from lock to lock. This will pump the fluid out of the system. Once empty, connect the hose and top up the reservoir with fresh ATF (Dexron 3 or similar) and follow the bleeding instructions in the manual.
Old 02-19-07, 05:14 PM   #9
Diesel for blood
roscoFJ73's Avatar
I did my HZJ75 with the engine running last week .The old fluid stunk and was almost black and the pump was noisy.
I undid the return and pumped it into a plastic coke bottle. I turned the idle down real low but it still pumps pretty fast .
Allow some extra fluid for flushing to make sure all the old fluid is out
I also added some PS reconditioner 1st and let that circulate to clean the stator and vanes.
All went well ,steering is now super quiet
I used Dexron III ATF (Dexron II is obsolete here)
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
roscoFJ73 is online now   Reply With Quote
Old 02-19-07, 05:30 PM   #10
Wink
Thanks for the tips. Its about minus 20c outside here now. Hoping for better weather to do the procedure on the weekend.
Old 02-24-07, 07:07 PM   #11
Thumbs down It worked! But what about those vibes?
So I drained the fluid and replaced with new ATF today. Took a lot of turning on the ground and in the air to bleed it afterward. But it works perfectly! No more stiff turning. Now it remains to find the nasty driveline problem. Tried changing the fluid in the rear diff. to no avail. The rear diff. is actually fairly tight, but sounds clunky compared to the front, which has more rotational play, but is silky smooth. I'm thinking TC. When I had the driveshaft off and tried turning the flange, it turned quite a bit. If I wiggle it, it feels as if something is loose. Could there that much flopping around in the gears? Can the flange come loose on the shaft while the nut is still staked? It's all japanese to me…Taking apart the TC sounds like a scary proposition. Looking for wisdom.
84BH60 229km
Old 02-25-07, 02:57 PM   #12
Garry's Avatar
There is always a fair bit of backlash in the drive train, with all those cogs & bearings it can't be helped Have you tried greasing the telescopic joint and universal joints on the drive shaft? They could be dry or worn a little. The pinion flange is normally slightly loose, as long as the seal isn't leaking, I would leave that alone. The slack is taken up under load anyway. The only other thing it could be is your drive shaft may have taken a hit from a large rock or log and bent it slightly, unlikely though
Old 02-26-07, 01:59 PM   #13
Back to the drawing board
PS pump is back to stiff and choppy again. Looks like I may have to get another pump!!! Tempted to try mating mine with the parts of a mini-truck or van pump, as described in another post.
Online Loans | The eBay Song | Debt Consolidation | Internet Advertising | Hookah
