02-16-07, 06:14 PM
| | 250+ Club
| Adding Mini Truck PS to a 2H diesel, which package from JTO to buy? Hello-
I am trying to determine which setup package from this page at JTO (see below) I need to buy to add Power steering to the 2H diesel straight 6. I have already bought the steering box and a complete setup (reservoir, pump, all lines, cooler lines) from a 1983 Toyota Mini Truck.
Here is the link to the vendor: http://www.jtoutfitters.com/index.ph...osCsid=7451c2d
It appears that there are several options. I have done mini truck conversions to a 1974 FJ40 before. It appears that things are a bit more complex for mini truck PS to a 2H. I used the search function and through four pages of 3b related applications.
thanks in advance.
Aaron Riddle
Spokane, WA
__________________ 1997 Toyota land Cruiser FJZ80 40th Anniversary
1975 Mercedes Unimog 416 Troopy
1967 Toyota Landcruiser FJ45 LPB |
02-16-07, 09:12 PM
| | Supporting Vendor
| Aaron, where did you get a 2H from? Where is it going into?
__________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame!
'67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
02-16-07, 09:15 PM
| | 250+ Club
| 2h adding PS Hi Charles:
The 2H is not mine. I am trying to help a guy in Denmark who doesn't speak the best English and needs help with adding PS. There is no sense in him reading on MUD as it is in English.
The 2H is in his HJ47 I think. He doesn't have PS and needs it.
thanks
Aaron
02-16-07, 09:38 PM
| | Supporting Vendor
| So he already has the mini truck power steering stuff? Otherwise I'd suggest Steve at Extreme Bends. He's got lots of 'Cruiser parts.
02-21-07, 09:38 PM
| | 250+ Club
| truck is 1977 HJ45 which bracket to add mini PS pump the truck is 1977 HJ45 ...I am trying to determine which bracket will allow the owner to add PS pump? He already has the bracket for the PS box from a 1983 mini.
Advice?
thanks
Aaron
02-22-07, 01:32 PM
| | Forum Lifer
| I thougght the PS box it's fine .. but your need to make a braket from scratch ( little complicated if you have AC compresor ) to run aditional belt for PS pump ..
in the 2H the PS pump are located front the injection pump .. in the lower and little complicated position in the engine ..
__________________ HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul ! Join us at our local Panamá Off Road Forum Quote:
Originally Posted by crushers if you are achieveing the max boost then it isn't the boost that is going to kill your engine... it is your right foot. | |
02-22-07, 08:59 PM
| | 250+ Club
| thanks Tapage thanks a lot.
Aaron
02-22-07, 09:19 PM
| | Tank Buster
| If youre going to do that, make it POST 1996 IFS steering.. That set up is WAY superior to earlier stuff!!!!
__________________ 2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got! |
