H151F synchros I presume
My H151F doesn't like to shift into 2nd until it has warmed up, and won't go back into 1st unless you come to a complete stop or let your foot off the clutch a little.
Am I correct in thinking it's probably synchros I need? I presume this is not typical H151F behaviour? I'd like to order the parts *before* we pull the tranny apart. __________________ Jonathan Colvin Galiano Island, BC 1990 HDJ81 w. OME, 35'', intercooler, safari snorkel, locked all-round, viair 450 onboard air, deer-killer bumpa + train horns, milemarker hydraulic 1991 PZJ-70 factory lockers and winch. |
Diesel for blood
Its pretty normal for big gearboxes to be like that in the morning or has it gotten worse lately?
Thinner oil can help. Maybe its clutch related Do you use 1st for take off all the time? I always use 2nd unless its on a steep hill. All the H55f are hard to change from 1st to 2nd and back when cold or over about 10kph. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#3 | |
I have a 151 here, it's stiff when cold - minus 10 and lower. First gear is pretty low on them and is hard to go to first from second. Not wanting to go to 2nd from first is usually a sign of wear and higher kms, but I have also noticed the same tendancies on other toyota trannies from 1st to second - and they don't all have higher kms - maybe just poor maint by previous owner?
Like Ross said - try a thinner fluid - maybe a synthetic. Regards, __________________ Louis Check out my youtube videos at: www.youtube.com/lshobie Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/ |
#5 | |
#6 | |
#7 | |
Diesel for blood
Try the 2nd gear takeoffs,even a 1HZ has torque enough to chug away without laboring
Credit Card Debt Consolidation | Debt Help | Mobile Phones | Loans | Cheap Loan |
