Old 02-10-07, 12:30 AM   #1 (permalink)
moondog's Avatar
What size wrenches do i need to remove my fuel injectors?
Sorry guys, I know this is probably an idiotic question, but I was wondering what size wrenches I need to remove my fuel injectors on a '87 2H? I know, I should probably just get a whole set, but I don't have one, and my car is stored a ways away so I can't just go outside and measure it. Thanks.
'87 HJ60 - Max
'85 FJ60 - future home of Max's drive train
moondog is offline   Reply With Quote
Old 02-10-07, 01:27 AM   #2 (permalink)
retired maths geek huh
denis's Avatar
You will need a 27 super deep socket, for the injector body itself, a 19mm for the return line retaining nut and a 17mm wrench for the feed line nut. The upper half body is 24mm should the return nut be seize. be careful to not tear the return line apart, $$$.
'71MS75 5cyl crown coupe '74MS75 6cyl crown coupe '74MS75 4cyl crown coupe '75BJ40 DD '79FJ55 rostig schwein '80BJ40 never ending resto '82BJ45 project troopie 50% '83LN46 no engine '84BJ45 project troopie 50% '88LN65 getting closer '90HDJ80 the bear '92LN85 turbo ute '96LN108 rustbucket
Originally Posted by LandCruiserPhil View Post
there are a lot more single women available then nice low mileage Land Cruisers.
denis is offline   Reply With Quote
Old 02-11-07, 12:15 PM   #3 (permalink)
moondog's Avatar
So after taking them out should I cover up the holes where they go and with what? The truck is stored outside and it's been raining.
Many thanks.
'87 HJ60 - Max
Old 02-11-07, 12:18 PM   #4 (permalink)
Mod in Hibernation
brownbear's Avatar
I would take rags, and cover the holes. Ensuring nothing falls in. You can stuff them slightly in the holes, but I would be careful not leave any rag in there.
The hood closes right? So rags work in the rain.
-91 FJ80, wife's ride
Old 02-11-07, 01:16 PM   #5 (permalink)
moondog's Avatar
Yup, the hood closes. Any pointers on how to remove the return line without damaging it?
'87 HJ60 - Max
Old 02-11-07, 07:47 PM   #6 (permalink)
Supporting Vendor
cruiser_guy's Avatar
Remove the lines from the injection pump to the injectors first. Don't bend them out of the way! Remove the retaining nuts that hold the return line in place making sure you don't turn the injector or the return line when doing so. When all the retaining nuts are off the return line should come off.
www.wirrell.com
Old 02-13-07, 09:56 PM   #7 (permalink)
Garry's Avatar
Make DOUBLE sure you don't twist those return lines, very easy to break!
1984 HJ60 Big Red Wagon!
Garry is offline   Reply With Quote
Old 02-14-07, 05:53 AM   #8 (permalink)
brisveganbj42's Avatar
im in the process of doing this with my 3b .. just remove and refit (i have two 3b's one with freshly reco'd injectors to go into the other 3b)
from what I could tell it appears the main injector body requires a 24mm spanner or super deep socket.. is this correct in the case of teh 3b?
thanks!
'84 BJ42 with all the fruit - fun to drive 7 days a week!
Got a BJ42? Join the crew @ PHAT42!
my 'shed'
3rdrock4x4 club
QLD 4WD Spares and Repairs
brisveganbj42 is offline   Reply With Quote
Old 02-14-07, 08:19 AM   #9 (permalink)
Supporting Vendor
They both need a 27mm deep socket. The 24mm will dismantle the injectors and you DON'T want to do that.
The order of bolt sizes in you picture are 17mm for the injection tube (nut is up the tube in your picture), 19mm for the overflow pipe, 24mm on the injector (DO NOT REMOVE THIS ONE), and 27mm for the injector body.
www.wirrell.com
Old 02-14-07, 09:48 AM   #10 (permalink)
iron_giant's Avatar
Don't forget 10mm to remove the clamps on the injection pipes so you don't have to bend the pipes themselves. Also, a 10 or 12?mm to loosen the heater pipe across the injectors so that you can move it out of the way as well. Other than that it's all covered.
1984 JDM Hj60, RHD, ARB & limited slip, high roof, Alcans, 35's, 4.56's and a whole lotta fun
Remflex Exhaust Gaskets for Land Cruisers.
Gas and Diesel.
2f EGR flange gaskets.
2F, 22R/E/EC, 2H, 3B
Manifold gaskets
http://shop.fundametalism.com
iron_giant is offline   Reply With Quote
Old 02-14-07, 03:52 PM   #11 (permalink)
Yep.. I haven't undone the 24mm and figured it was the injector internals.. I'll have to wait to finish this until I can get my hands on a 27mm super deep socket..
All I have access to at the moment is a shifter and i can't even get that in there to get a decent grip on it so im not even gonna try..
Thanks for the re-assurance guys..
my 'shed'
3rdrock4x4 club
Old 02-14-07, 08:52 PM   #12 (permalink)
Garry's Avatar
I managed to loosen mine with a 27mm ring spanner, but borrowed a socket to torque them back up again
Old 02-14-07, 09:31 PM   #13 (permalink)
hmm.. I'm having trouble locating a socket of that size.. continuing to ring around though..
$45AUD for a 27mm spanner!!
my 'shed'
3rdrock4x4 club
Old 02-15-07, 04:46 AM   #14 (permalink)
found one for $20 and used that successfully to undo the injectors..
On the weekend i'll be swaping them between 40's..
so thanks for your help guys.
my 'shed'
3rdrock4x4 club
Old 02-16-07, 05:07 PM   #15 (permalink)
moondog's Avatar
On the 27mm super deep socket, does it need to be a 6 point or a 12 point?
'87 HJ60 - Max
Old 02-16-07, 05:14 PM   #16 (permalink)
moondog's Avatar
Ok, sorry again, I'm confused. . . . so what size drive would a
super deep socket be? I'm assuming that it is not the same thing as a regular 27 mm deep socket?
'87 HJ60 - Max
Old 02-16-07, 09:14 PM   #17 (permalink)
Supporting Vendor
A deep socket is the same drive as any other. My 27mm is a 1/2" drive. I'd get a 6 point 'cause you get better grip on the injector.
www.wirrell.com
Old 03-12-07, 03:07 PM   #18 (permalink)
I did this job over the weekend after refering to this thread. I found a set of Metric Crowfoot Wrenches from Harbor Freight to be invaluable for this job:
http://www.harborfreight.com/cpi/cta...emnumber=93138
Add they're only $6 right now.
Finding the 27mm deep socket was a bit tougher. Sears has them online at the best price:
http://www.sears.com/sr/javasr/produ...id=00950775000
All the white smoke issues went away with the swap. I bought the injectors on eBay from a seller on Australia.
warfin is offline   Reply With Quote
