What size wrenches do i need to remove my fuel injectors?
Sorry guys, I know this is probably an idiotic question, but I was wondering what size wrenches I need to remove my fuel injectors on a '87 2H? I know, I should probably just get a whole set, but I don't have one, and my car is stored a ways away so I can't just go outside and measure it. Thanks.
__________________ '87 HJ60 - Max |
retired maths geek huh
You will need a 27 super deep socket, for the injector body itself, a 19mm for the return line retaining nut and a 17mm wrench for the feed line nut. The upper half body is 24mm should the return nut be seize. be careful to not tear the return line apart, $$$.
__________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
So after taking them out should I cover up the holes where they go and with what? The truck is stored outside and it's been raining.
Many thanks. __________________ '87 HJ60 - Max |
Mod in Hibernation
I would take rags, and cover the holes. Ensuring nothing falls in. You can stuff them slightly in the holes, but I would be careful not leave any rag in there.
The hood closes right? So rags work in the rain. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
Yup, the hood closes. Any pointers on how to remove the return line without damaging it?
TLCA# 16387
Remove the lines from the injection pump to the injectors first. Don't bend them out of the way! Remove the retaining nuts that hold the return line in place making sure you don't turn the injector or the return line when doing so. When all the retaining nuts are off the return line should come off.
__________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
Make DOUBLE sure you don't twist those return lines, very easy to break!
__________________ 1984 HJ60 Big Red Wagon! |
im in the process of doing this with my 3b .. just remove and refit (i have two 3b's one with freshly reco'd injectors to go into the other 3b)
from what I could tell it appears the main injector body requires a 24mm spanner or super deep socket.. is this correct in the case of teh 3b? thanks! __________________ '84 BJ42 with all the fruit - fun to drive 7 days a week! 1GB Free Image hosting @ PHAT42.COM! Join the crew @ phat42! my 'shed' 3rdrock4x4 club |
#9 | |
TLCA# 16387
The order of bolt sizes in you picture are 17mm for the injection tube (nut is up the tube in your picture), 19mm for the overflow pipe, 24mm on the injector (DO NOT REMOVE THIS ONE), and 27mm for the injector body. __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
#10 |
Don't forget 10mm to remove the clamps on the injection pipes so you don't have to bend the pipes themselves. Also, a 10 or 12?mm to loosen the heater pipe across the injectors so that you can move it out of the way as well. Other than that it's all covered.
__________________ 1984 JDM Hj60, RHD, ARB & limited slip, high roof, Alcans, 35's, 4.56's and a whole lotta fun |
#11 | |
All I have access to at the moment is a shifter and i can't even get that in there to get a decent grip on it so im not even gonna try.. Thanks for the re-assurance guys..
#12 |
I managed to loosen mine with a 27mm ring spanner, but borrowed a socket to torque them back up again
#13 |
hmm.. I'm having trouble locating a socket of that size.. continuing to ring around though..
$45AUD for a 27mm spanner!! __________________ '84 BJ42 with all the fruit - fun to drive 7 days a week! 1GB Free Image hosting @ PHAT42.COM! Join the crew @ phat42! my 'shed' 3rdrock4x4 club |
#14 |
found one for $20 and used that successfully to undo the injectors..
On the weekend i'll be swaping them between 40's.. so thanks for your help guys. __________________ '84 BJ42 with all the fruit - fun to drive 7 days a week! 1GB Free Image hosting @ PHAT42.COM! Join the crew @ phat42! my 'shed' 3rdrock4x4 club |
#15 |
On the 27mm super deep socket, does it need to be a 6 point or a 12 point?
#16 |
Ok, sorry again, I'm confused. . . . so what size drive would a
super deep socket be? I'm assuming that it is not the same thing as a regular 27 mm deep socket? __________________ '87 HJ60 - Max |
#17 |
TLCA# 16387
A deep socket is the same drive as any other. My 27mm is a 1/2" drive. I'd get a 6 point 'cause you get better grip on the injector.
#18 |
I did this job over the weekend after refering to this thread. I found a set of Metric Crowfoot Wrenches from Harbor Freight to be invaluable for this job:
http://www.harborfreight.com/cpi/cta...emnumber=93138 Add they're only $6 right now. Finding the 27mm deep socket was a bit tougher. Sears has them online at the best price: http://www.sears.com/sr/javasr/produ...id=00950775000 All the white smoke issues went away with the swap. I bought the injectors on eBay from a seller on Australia. |
Loans | Connecticut Flags | Shares | Online Loans | Property for sale in Spain |
