First of all, excellent site! My name is Dylan and I have been a long time lurker due to my computer illiteracy.
This is the first forum I have ever been a part of so please bear with me until I get my feet wet
I am a long time fan of cruisers and decided to take the plunge on an 87 HJ60 last july to use for some travelling and daily driver duties. My truck is auto, 24V and has 235km on what seems to be a very healthy 2H.....the electrical on the other hand has had its share of sickness.
Over the past 3 months I have had the voltage regulator replaced, 2 toyota 850cca batteries and my starter rebuilt (after it would not disengage). Approximately a week before my starter issues, my batteries started going flat and I remedied this by charging my low side battery. Since the rebuilt starter, I topped up the low side and it seems to be holding alright for now but its too early too tell if these problems were related or separate issues.
Now my latest mystery...When I started the truck I noticed that the voltmeter stayed lower than normal, even after driving. It was just below half when it would normally be closer to the top (around 28 or so.)
I started getting a little worried when I had been driving for 20 minutes and it still had not moved. All of a sudden my battery and filter lights flashed, the voltmeter returned to normal all at the same time.
The next day it did the exact same thing, even the length of time it stayed low was the same???
To make a long story short, I am trying very hard to be keep loving this cruiser but this electrical is scaring me. This truck is my daily driver and I'm hoping it will continue to be. I have used the search function extensively and have spent hours reading about similar occurences and 24V in general. I just cannot find anything definitive...
Anyways, thanks for reading my first(LONG) post and thanks in advance for any knowledge you could throw my way
PS Could anyone suggest a cruiser mechanic in southern Ontario?
Thanks again, Dylan
.PS Could anyone suggest a cruiser mechanic in southern Ontario?
Thanks again, Dylan
! the cruiser salute but at a poor time. get a voltage reading at the batteries with truck running. if below 25 volts then it could be brushes or faulty regulator!
disconnect the batteries and remove the regulator holder on the alternator. undo the regulator and check the brushes, it should have good spring return(1/4" or more) distance(if not, the brushes need replacing).
