LinkBack (46) | Thread Tools | Display Modes |
#31 |
yeah I know Steve, reread the post
Anywhoo, it is still pretty cool. I have a good friend who is leaning towards this for his FJ62. Will keep posted if he gets it! Andre
__________________ - Cummins 4BTswaps.com Forums - Diesel Conversion Website TLCA# 9439 Since 1999, Wasatch Cruisers '89 Toyota Pickup V6, OME, 32's '69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300 |
#32 |
http://www.isuzudieselswapper.com/ posted earlier
#33 |
My dad had an Isuzu NPR for about 15 years. He always had a spare 4bd1. That thing looks really big and heavy. Anyone know the actual weight and dimensions of that engine? How does it compare to say a 2F or even a 3B?
#34 | |
I haven't found a weight but plan on weighing mine when I get it pulled from the truck. You state that your dad always had a spare 4BD1T. Is that because he had a lot of problems with the engine? Andy __________________ Stock FJ62 SOA Samurai Tintop Ford E-350 4x4 Diesel M-29 Weasel |
#35 |
Thanks for the link. He NEVER had any problems. Always changed all filters and kept everything new. Was used everyday with full payload. The reason he had a spare was cuz the engine blew an oil line on his way back from Needles, CA. He threw another 4B to get back home and rebuilt the blown one and kept it as a "back up". He sold the NPR and the spare engine for $3.000. Now my dad owns a Hino.
#36 | |
4BD1T in a 88tlc
I may take you up on that ! Looked at a 4BD1T the other day, out of the truck, with the 5spd tranny attached. I would like to consider a swap of the engine only, and marry it up to the Automatic tranny in the TLC (4 speed overdrive). Same bolt pattern? This would be a town car of course. not a lot of lift, good efficient tires. |
#37 |
The rear view photo of the engine shows an exhaust brake. You can raise hell with the neighbors late at night!
#38 |
4BD1T hooked up to a toyota auto transmission, A440F
yeah a very cool exhaust brake. Utilize that for sure.
Still looking for more info on connecting an isuzu 4bd1T, to the toyota a440F automatic transmission? this transmission has an overdrive, and cruises at 2000rpm/60mph. Can i get that hooked up? Seems like guys hook up the auto transmission to GM, V8 350s (same bolt pattern as a GM transmission). Measure twice, cut once. bill |
#39 | |
I'm going to be tied up with work-related projects for at least the next couple of months so I don't expect to get the 4BD1T pulled until this Spring at the earliest. __________________ Stock FJ62 SOA Samurai Tintop Ford E-350 4x4 Diesel M-29 Weasel |
#40 |
Am I the only one who's noticed that the NPR auto transmission is an Aisin A450? I've seen pictures of them on eBay. The A440 and A450 both have a detachable bellhousing. Am I the only one who's wondered if the front side of the A440 and A450 might happen to have the same bolt pattern? If so, you *might* be able to use an NPR auto bellhousing on the front of an A440. Of course, you'd still have to deal with flex plate and torque converter issues, but it's a possibility...you'd probably have to have an A450 and an A440 next to each other to figure it out.
Steve P.S. Google never ceases to amaze me. This quote: "AW450-43LE is a replacement for the JR403E truck transmission and is similar to Toyota A442F." comes from this .pdf, which seems to indicate a lot of parts shared between the A450 and A440/442: http://www.shinseiauto.com/japanese/.../ata440f04.pdf Also, according to George (orangefj45) it may have only been used in NPR's from '98 up, so you might not have one in your back yard... __________________ TornadoAlleyCruisers Last edited by theSherpa; 01-26-07 at 11:26 AM. |
#41 | |
to you if you are correct!
#42 |
check my "p.s."
__________________ TornadoAlleyCruisers |
#43 |
The 1988 Isuzu manual that I have is very vague on the model of automatic. The one in my back yard with the automatic is a 1994. I'll crawl under it this weekend and see if I can id the transmission.
#44 |
how do you like that. Nice work Steve.. I have been on the back end of figuring this out too, very cool...
#45 | |
I found a transmission cross listing which confirmed what George said that the Aisin 450-43L was introduced in 1999. In 1999, the 4HE1-TC engine was being installed in the Isuzu NPR and that engine, according to David of http://www.isuzudieselswapper.com/, has a totaly different back end so transmissions are not interchangeable with the 4BD1/2 engines. Here are some photos of the JR403E case that happens to be listed on ebay: __________________ Stock FJ62 SOA Samurai Tintop Ford E-350 4x4 Diesel M-29 Weasel |
#46 |
4bd1 swap
I bought a couple of these engines (one NA and the other turbo) to hopefully swap into cruisers....the kit a few months back to mate to a chevy automatic ran pretty steep (something like $800) so it is not cheap but probably the easiest route although I don't know what it takes for the chevy tran to transfer case???
I doubt I will be able to try to figure this out till after summer because of lack of $$$....these engines are real quiet which is great and they are sleeved and can run along time with great mileage. |
#47 | |
Isuzu box trucks built mid-1998 and later are equipped with the new Aisin Warner / Toyota
450-43LE transmission. This replaces the Nissan JR403E previously used in this application. The unit is a derivative of the A442F unit used in Landcruisers up to 1995. __________________ Stock FJ62 SOA Samurai Tintop Ford E-350 4x4 Diesel M-29 Weasel |
#48 |
nice find there.....
I wonder what engine models from mid 1998 forward?? And if earlier models such as the 4bd1 or 4bd2 would mate??? I am unsure if 4bd2 was still producted at that time?? Do you know if the LC transmission shared will fit 40 series with the original axels as to the offsets?? thanks |
#49 |
Georg... you haven't posted in your thread in a few days...
Have you seen the light and renewed your original idea of a 12HT? Mine is here and waiting to be uncrated... Maybe if I had posted the pics I promised a while ago your slip to the 'other' side would have been averted [hijack off] Great tech guys. Phil __________________ 1973 FJ40, beeropener 1966 FJ45, (the 12HT has arrived.... )1995 4Runner, AT with dual cases TLCA #9166 TLCA Delegate, Mountain Transit Authority, San Jose, CA |
#50 |
bellhousings for landcruisers
great work on some great information! Looking promising.
I found these guys in Australia that may have some bellhousing options that can help. http://www.rodshop.com.au/bellhousings.htm they have a long list of possibles that I am checking on. bill |
#51 |
Short of it not having OD and figuring out how to make a shifter work the stock zuzu 5 sp with a divorced TC would probably be a nice set up. ..and its already bolted to the block.
I just bought a 86 NPR with a slung rod for $500 but it has a new turbo and starter . Didnt think I did too bad. Came with the factory rebuild manuals also. Missed a deal on a running 93 the other day for $1200...
#52 | |
#53 |
Where's mah cruzah?
I have a CAD drawing for a divorce plate, but haven't had the plate made yet. Once I get the plate made, we'll figure out seals and get an input shaft made. I'll try to remember to post up here (and in my own diesel conversion thread!) when that's done. It'll be a few weeks at least.
__________________ 84 FJ60, locked and lifted and dismantled with Mercedes diesel 1982 BJ42 loud and slow daily driver on 33s Horsetooth 4-Wheelers |
#54 |
which T/c would you use with the divorced plate?
didn't AA use to use a plate years ago for Mini truck 4wd conversions? |
#55 |
Where's mah cruzah?
It's the divorced FJ60 case. Not sure on the AA plate. That'd be nice to see, if they did make one...
#56 |
Newbie here,
Please do a quick recap I am blueprinting (in my head)an Isuzu swap. I have just purchased a 92(A440F) Fj80 and a 3Fe that for obvious reasons will NOT be joining the LC in the future. My thoughts are since I have herd the Izusu has the same bellhousing bolt pattern as the chev. I was going to get an adaptor, an adaptor I have herd was discontiued but not impossable to find. P.S The answer has got to be out there some where, the government had to have slipped up some where letting the diesels imported to this country in. You cannot tell me there is not a diesel some where that will fit in my Toyota, PLEASE dont make me have to custom make an OLD 4.3 diesel with custom headers, intercooler and twin turbo's or Damn, a 6.5 heavy chevy. SOME ONE in this forum must have access to CAD/CAM and a Flow jet. I WOULD PAY DEARLY for this (bellhousing) I know how to buy parts and could probobly source an engine free, or heck just pay for it. I H8 9 MPG !!!!!!!! Last edited by tntoyota; 02-19-07 at 03:19 PM. |
#57 | |
Diesel for blood
![]() They are quiet and powerful and enhance the resale $$ __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#58 |
88tlc who posted above just got a 4BD1T that is at my shop now for an install sometime this summer or spring.. As it comes along we'll post lots of pics and I'm sure he'll have plenty to input. Here are a couple pics of it though. Definetely big IMO, but much shorter vertically than the 4BT hence the lack of need for lots of lift. Pretty neat, can't wait to install it.. |
